Help - Extreme Nubie Flux Core
   / Help - Extreme Nubie Flux Core #11
I just looked on Amazon. $1,150.
For a 50 lb 110v MIG welder.
That's over 10x more than the cheapest equivalent.
Did you win the lottery? That's real top quality pro grade equipment, while for just amateur puttering around I think something similar on Amazon around $200 will do flux core nearly as well. And weigh under 20 lbs. And have dual-voltage to get the maximum out of it.
I wish I were rich like that! :)
As for dual voltage I think in concept something like the Hobart Handler 210MPV is a really good option for home and small farm and comes in at about the price of the Miller 142.... If I had as good foresight as my hindsight I would have gotten a dual voltage machine, but when I was looking around who would have thought there would be instances where I needed a bigger machine.... Seems welding mid range on 240 volt machine is better than at top end of a 120 volt machine... Since I am a Hobart fan I wish they would come out with a inverter version of the 210MVP...
   / Help - Extreme Nubie Flux Core #12
I have a couple 120 volt Lincoln MIG welders. They are both easily 30 years old and still work like new. Lincoln makes good machines. For practice if I was you I would buy some 1/8 and 3/16 material just start laying down beads. You will notice as the metal heats up it starts to weld differently. But before you try to weld anything that matters just start laying beads. Watch Welding Tips and Tricks on YouTube and compare your beads to what is shown on YouTube. It doesn't matter if your practice material is a little rusty, you are just laying down beads to get comfortable and learn how to make good beads. Weld a lot, burn 5 pounds of wire. And more. Get confident and add to your skill set. After you think you can weld flat then try fillet welds. Then, when you think you are making good welds try to break them. MIG welding is the easiest type of welding to make what you think you are good welds because they look good but the weld really has lousy penetration. So make fillet welds and try to bend and break them. MIG welding is easy but like anything it takes practice so don't think you are going to make strong welds right away. Since MIG welding is so much fun it should be no problem to practice a lot. As a side note, some folks, me included, use MIG welding as a generic term, whether it is flux core, which uses no gas, or actual MIG welding which does use gas. I should really say wire feed welding which encompasses flux core, gas shielded, and dual shield which is a flux cored wire that must also be used with shielding gas. Just to be more pedantic, MIG, Metal Inert Gas, is an obsolete term.The welding you will be doing is called FCAW, which stands for Flux Core Arc Welding. MIG is now called Gas Metal Arc Welding, or GMAW. And GMAW is actually more accurate because not all gasses used for shielding wire feed processes are inert. CO2 is an example. It is called an active gas because it participates in the welding process, it doesn't provide just shielding.
Eric
   / Help - Extreme Nubie Flux Core #13
Grats on your new welder. I bought a hobby welder during Covid. Had not welded since shop class in high school and that was stick. I got the Century FC90 inverter welder which is an off brand of Lincoln. I chose FCAW because I weld outside and it’s more tolerable than MiG with wind. The beads may not be as pretty as MIg, but they’re not terrible by any means. It’s a great way to get into welding without having to buy gas. I found some old bed frames in the attic and turned them into little work tables. Good luck !
   / Help - Extreme Nubie Flux Core #14
decades ago, I started out with O/A and coat hangers for welding rod.
O/A is a good lead up primer for TIG which is my now favorite process.
Still have a soft spot for a glue gun however and own 2 Hobart transformer machines that just keep on ticking. Both run shielding gas.
You can do light years more with TIG, but it's a slow process and takes a lot of skill and time to master.
One thing about TIG and that is, if it conducts electricity and you have the correct filler rod and shielding gas, you can weld just about anything metal.
Just TIG welded a cracked magnesium chainsaw case the other day.
Thanks to all for the comments. To California: I am sure I could have purchased a much cheaper welder ! But, we have a local dealer who I know and it was a retirement gift to myself. :D
I *believe* the manual says JOG mode is 3 seconds without the machine detecting contact to weld. Shuts off the gas and goes cold.... I think
Again thanks to all. Now just need some time to set things up and try out.
   / Help - Extreme Nubie Flux Core #17
Still a flux wire newbie of 6 years. I use blue devil brand, and they make a single pass wire and multiple pass wire. I was using single pass for multi pass. When I discovered that, I changed. Didn't make me a better welder, but looks better.
   / Help - Extreme Nubie Flux Core #18
In my way of thinking, cheap and good welders are not synonymous with each other at all. You get what you pay for and cheap Chinese machines are poorly built, have poor duty cycles and are prone to inaccurate controls and their torch heads are also poorly made. I'd never buy a new Hobart anything... all made in China now.
   / Help - Extreme Nubie Flux Core #19
I agree that you get what you pay for with welders, generally speaking. My newest Lincoln machine is made in Mexico. Unfortunately, I don't think there are any welders that are made in the US any more.
   / Help - Extreme Nubie Flux Core #20
I believe Lincoln Electric in Euclid, Ohio still assembles larger commercial units there using parts and components sourced 'worldwide' of course. I know they do still draw their wire there and produce SMAW electrodes as well.
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
2018 Kubota RTV500 4x4 Diesel Utility Cart (A59228)
2018 Kubota RTV500...
CATERPILLAR 255 SKID STEER (A60429)
CATERPILLAR 255...
2007 TEREX ADVANCE FD3000 FRONT DISCHARGE AWD MIXER (A59575)
2007 TEREX ADVANCE...
SUV (A59231)
SUV (A59231)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
