welder on crack
/ welder on crack #21
Oh, by the way I do know some welder on crack.
/ welder on crack
Pekabu, I wouldn't want to work for anybody that would hire me. /forums/images/graemlins/smirk.gif (appologies to G. Marx)
/ welder on crack #23
Did anybobdy know that a welder is the machine that does the welding and the person doing it is called a weldor.
/ welder on crack #24
</font><font color="blue" class="small">( Did anybobdy know that a welder is the machine that does the welding and the person doing it is called a weldor. )</font>
Yep. And I'd rather be the weldor than the weldee. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif John
/ welder on crack #25
Heard that,,,but where I come from,you say them both the same way,,,plus........how about micro and macro,,,,,,,wonder how the crack repair is going? thingy
/ welder on crack #26
Hi
I don't believe Weldor is a word. The person doing the welding is the welder and he is using a welding machine. Now the man using the machine could be a wielder. but I could be wrong.
Charlie.
/ welder on crack #27
I think the latter is right. Lincoln calls a welding person a Weldor.
Wielder makes weight lifting equipment, right?
As long as you aren't the weldee or the weldor has a rod in a weldee's sensitive place, then the weldee is okay. If not, the weldee better take the weldors rod from the sensitive place and turn off the "juice". /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/shocked.gif
That's all I have to say about that.....Forrest Gump.
/ welder on crack #28
Hi
wield ( P ) Pronunciation Key (wld)
tr.v. wield·ed, wield·ing, wields
To handle (a weapon or tool, for example) with skill and ease.
To exercise (authority or influence, for example) effectively
Charlie.
/ welder on crack #29
Wonder how that amature welder,who has the crack in his bucket is doing?One thing for sure his welding machine should be able to handle it,alls he has to do is put a nice gorilla weld on that crack,,,,thingy
/ welder on crack #30
I'm sorry Rich, no monster passes, small stringer beads. Lot better heat control and lot better fusion, not so much of a chance of the puddle rolling in front of the puddle where you want all of your penetration. and that the name of the game, PENETRATION. Molton slag can roll in front of puddle and create a pocket or void.
/ welder on crack #31
Bell,,are you sure this time? Speaking of weldor/welder,,,,,the meaning of a gorrila weld is,,,,,ugly but strong,,,some beginners,,,can't even do that,,,,they make bralle welds,,,,looks like a blind welder welded it with his welding machine. thingy
/ welder on crack #32
If you read what I wrote, it all makes sense think about it. If you ever done any welding on flat or in a groove butt, if you go to slow with travel speed the puddle will build up and start to flow around the arc, now when your welding all your penetration is directly under the arc, we call that the cone, you can actually see a cone in the arc the bottom of the cone is the amount of penetration your getting. you should have the gun at a slight angle into your puddle and pulling away from the molten metal, and slag. Your path is always clear of any thing but the metal your fusing together. If the puddle gets in your way, there goes your penetration. That is what happens when you put down monster beads. And also your heat input stays down cause your moving along faster and spreading the heat. Not so much warping, and some times if you get a weld so hot it can actually suck in oxygen into the weld and make it porris, or called porosity. AKA: Swiss cheese.
/ welder on crack #33
mr. bell,,,,put many a root bead in,pipe/plate,,mig, stick,little with tig,,,,and I kinda know what you are saying,,,and of course you don't want to put a big giant bead down,,if its not the right thing to do,,,in most cases its not,,,,you get your root in,,hot pass,fill,cover,,,some cases your fill cover may be the same,,etc.,etc.,,I was just kinda telling the guy,,,this,,grind the crack out,,weld it up the best he could,,both sides,,,he said he wasn't that experienced. There is never any need to use more heat,,,put more weld on,than you need,,,,once you have made two pieces one piece,,,its as good as it gets,,,putting a big cover will not make weld stronger,,,will probably make it weaker,,,,dime high,[thickness of dime],,,nickle wide,[width of nickle],,,is an old saying for down hill pipe welding,sch 40 pipe,,,,,but like I said a good gorrila weld,from an inexperienced welder,,is alot better than it being broke,,and in fixing a cracked bucket,,,may be just what the doctor ordered?? thingy
/ welder on crack #35
Well,the man his self,,,its all down hill now,,,,all this advice has got to have taken 10 times as long as it will to patch up that crack,,,,thingy
/ welder on crack #36
I think he should buy a new bucket.
2017 Dodge Ram Promaster 2500 Van (A63116)
2017 Dodge Ram...
2011 Jacobsen T-700 Commercial Reel Mower (A61567)
2011 Jacobsen...
Margaritaville Mini Decorative Truck (A61569)
Margaritaville...
2019 Ram 5500 4x4 Utility Truck, VIN # 3C7WRNFL0KG646154 (A61165)
2019 Ram 5500 4x4...
Trava Long Gooseneck Livestock Trailer (A64047)
Trava Long...
(INOP) 6' FINISH MOWER (A62130)
(INOP) 6' FINISH...
