Adding grab hooks on front bucket, 2 or 3 hooks?
   / Adding grab hooks on front bucket, 2 or 3 hooks? #51
Pros or cons to adding the bolt on hooks?
I added bolt on hooks at the outside edges of the top and welded up a 2 inch receiver that bolts to the tractor frame for spotting a trailer or heavy pulls. The pull is more in line with the axles. Too easy to bend the top of the bucket with a center hook.
   / Adding grab hooks on front bucket, 2 or 3 hooks? #52
I bought some bolt on hooks from Amazon. They come with reinforcing plates and bolts. I am currently deciding where to locate them on the tractor bucket.
https://www.amazon.com/dp/B09T5TYHKH?psc=1&ref=ppx_yo2ov_dt_b_product_details
   / Adding grab hooks on front bucket, 2 or 3 hooks? #53
   / Adding grab hooks on front bucket, 2 or 3 hooks? #55
It's easy to lift from the center with 2 side hooks if you have a hook on your chain. Think triangle with the chain end hook in the center.
   / Adding grab hooks on front bucket, 2 or 3 hooks? #56
Yep. And the "load" on the hooks becomes a side load, rather than a straight pull in the direction of the hook load. No big deal if it's a light load.
   / Adding grab hooks on front bucket, 2 or 3 hooks? #57
Yep, that's how I lift heavy loads if I only need one hook!
I'd written in an earlier post (on this thread) about pulling spilt rail fence posts...that's exactly how I rigged the chain...
   / Adding grab hooks on front bucket, 2 or 3 hooks? #58
It should not have to be a light load. If the hooks cant take an side load equal to what they can take straight on then they are substandard or improperly installed. Sorry but it's true and I'm not going to argue it.
I had my Terex 640 14 yrs using the hooks the same way, even lifting the rear off the ground many times against a chained load. Very heavy 14k pound tractor - no hook problems.
   / Adding grab hooks on front bucket, 2 or 3 hooks? #59
No argument here. Simple physics. :)
   / Adding grab hooks on front bucket, 2 or 3 hooks? #60
USA made ones...Support small business and not Bezos and China:
I got your hooks man, I like them a lot. I also like that you engage here, share info and stuff, and contribute...as opposed to just being on here to sell your stuff. :)
1429 (A54756)
1429 (A54756)
2012 International 4300 Reefer Truck (A55301)
2012 International...
John Deere 325G Compact Track Loader Skid Steer (A55787)
John Deere 325G...
2024 AGT LRT23 Mini Stand-on Track Loader Skid Steer (A55787)
2024 AGT LRT23...
2008 FORD F450 SERVICE TRUCK (A54607)
2008 FORD F450...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
