Remove gravel from yard.
/ Remove gravel from yard. #1
Jack32878
Nashville, TN
Kubota BX25
We had a pool built a few weeks ago. The builder used 1/2” gravel to install the fiberglass shell. They then used 3/4” gravel for the concrete patio pour.
They dumped the piles of gravel in my yard. Now my back yard has gravel everywhere. A good bit of top soil was moved around. I’ve brought in some more dirt to get it looking good around the pool.
Having said that, I need to figure out how to get rid of the gravel so my mower doesn’t constantly sling it through windows. I used a 6’ landscape rake but that doesn’t help much for gravel this small.
Any advice on how to get rid of gravel?
/ Remove gravel from yard. #2
These work very well,make pile than square shovel clean up...might be able to rent one
/ Remove gravel from yard. #4
Suck them up with a shop-vac. that has a 2.5" hose. I do it every spring after the snow melts.
/ Remove gravel from yard. #6
A manure fork works, the tines are close together.
/ Remove gravel from yard. #7
Regular hand rake, but get one that has relatively narrow spaces between the tines. Rake it into a flat bottom shovel, dump into a 5 gallon bucket and/or FEL to move it out of the yard.
/ Remove gravel from yard. #8
Front brush on tractor. Like is used to clean asphalt prior to paving.
/ Remove gravel from yard. #9
That looks like a lot of gravel. Just loader scoop it up and get it the F outta there. Replace with topsoil, re-seed. My 2c.
Thanks for all the suggestions.
I ended up trying the power broom. It works but not the greatest.
I clean out the gravel but as soon as I use a landscape rake to loosen the dirt for planting grass more gravel comes to the surface. It’s a losing battle. It may be time to just order a couple pods of topsoil and spread a thin layer.
/ Remove gravel from yard. #11
It's a pain. I remember picking up small rocks by hand and throwing them in a bucket when I built my house. Others....had to be moved with a backhoe.
/ Remove gravel from yard. #12
Put some grass seed down on it and let it grow. Run a roller over it. My grass grows really good in the gravel I have and the mower rides over it nicely. :LOL:
/ Remove gravel from yard. #13
If you cover it up with top-soil it will work its way back to the top. It will take some time but eventually it will reappear, almost magical.
2019 Chevrolet Silverado 2500HD Crew Cab Pickup Truck with Liftgate (A61573)
2019 Chevrolet...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
2 Row cole planters (A64119)
2 Row cole...
1062 (A63291)
1062 (A63291)
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
