Remove gravel from yard.
   / Remove gravel from yard. #1
Jack32878
Nashville, TN
Kubota BX25
We had a pool built a few weeks ago. The builder used 1/2” gravel to install the fiberglass shell. They then used 3/4” gravel for the concrete patio pour.
They dumped the piles of gravel in my yard. Now my back yard has gravel everywhere. A good bit of top soil was moved around. I’ve brought in some more dirt to get it looking good around the pool.
Having said that, I need to figure out how to get rid of the gravel so my mower doesn’t constantly sling it through windows. I used a 6’ landscape rake but that doesn’t help much for gravel this small.
Any advice on how to get rid of gravel?
   / Remove gravel from yard. #2
These work very well,make pile than square shovel clean up...might be able to rent one
   / Remove gravel from yard. #4
Suck them up with a shop-vac. that has a 2.5" hose. I do it every spring after the snow melts.
   / Remove gravel from yard. #6
A manure fork works, the tines are close together.
   / Remove gravel from yard. #7
Regular hand rake, but get one that has relatively narrow spaces between the tines. Rake it into a flat bottom shovel, dump into a 5 gallon bucket and/or FEL to move it out of the yard.
   / Remove gravel from yard. #8
Front brush on tractor. Like is used to clean asphalt prior to paving.
   / Remove gravel from yard. #9
That looks like a lot of gravel. Just loader scoop it up and get it the F outta there. Replace with topsoil, re-seed. My 2c.
Thanks for all the suggestions.
I ended up trying the power broom. It works but not the greatest.
I clean out the gravel but as soon as I use a landscape rake to loosen the dirt for planting grass more gravel comes to the surface. It’s a losing battle. It may be time to just order a couple pods of topsoil and spread a thin layer.
2005 PETERBILT 357 TRI AXLE DUMP TRUCK (A51222)
2005 PETERBILT 357...
2019 RBR Venturi 380 (A51039)
2019 RBR Venturi...
2012 Big Tex T/A 20 ft. Gooseneck Trailer (A50860)
2012 Big Tex T/A...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2015 Chrysler Town and Country Van (A48082)
2015 Chrysler Town...
