Bought a 550 Ford TLB
/ Bought a 550 Ford TLB #1
sd455dan
Super Member
North Idaho
Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
Posted some questions in another 550 Ford thread.
Thought I should start my own for this high hour used TLB
I got it home with my nephew's help.
Never would have got it on my 80 inch wide trailer but his flat bed worked Great.
I have to say Very impressed with how their 2015 gas hemi 2500 RAM pulled the load.
We calculated that gcw was right around 24500 lbs.
( assuming the rear tires are not loaded-something that needs checked as well) And other than revving a bit higher than my 5.9 Cummins 1 ton it handled it just fine.
This thing has a huge One yard bucket
Pic of the load
WoHoo!
Some success. spent a good day using engine cleaner and a pressure washer getting things cleaned up a bit. Engine has a slight miss at idle and thought maybe an exhaust valve might be a bit tight checked the clearances , which were loose if anything . head work will have to wait... Running more than well enough to do some work, especially what needs done soon.
Changed oil and filter also cleaned out all of the radiators. Topped up the fluids. Still need to grease the tractor but just had to try it out on a decent sized stump.
The backhoe controls are a learning experience for sure but after digging was able to pin the stump to haul it to the burn pile with the hoe and fill in the hole and smooth it out.
Started ordering some parts that are needed like a new dash (Tach fuel gauge, coolant temp, and idiot lights) adding a voltmeter and still need a good wiring diagram /schematic- for some reason the 660+ page service manual is weak on the electrical items.
/ Bought a 550 Ford TLB #3
550s are old, but still get the work done. I have one and it does more than I can ask it to do. It has paid for itself many times over!
/ Bought a 550 Ford TLB #4
Looks like it is going to work out well. The picture makes it look like a LONG reach. Very Nice.
Thanks ,
The 550 models were apparently available with a few different Hoes. This 550 has the 755 model which has a 216 inch reach from the pivot
I am liking the power of the hydraulics although compared to the large Ford / NH TLB's with another step up in hoes this unit is still on the small side.
But I am still really happy for the initial $8k to get these kind of specs.
Bucket force and dipperstick beat what I would have got with a mini/midi ex I was going to bid on, although I doubt the mini ex would have any weld repairs on the backhoe like this old Ford does.
here are the hoe specs from tractordata
Digging depth184 inches
467 cm
2-Foot flat digging depth177 inches
449 cm
Reach from pivot216 inches
548 cm
Loading height120 inches
304 cm
Bucket Rotation186
Swing Arc185
Bucket force8300 lbs
3764 kg
Dipperstick force6190 lbs
2807 kg
Hi TractorTech. Hoping you can help me with a couple questions on the 550.
First from running into a problem of a restricted screen possibly on the hydraulic pump.
The pump whines a bit more than I think it should.
I read in another forum that the tank has a mesh screen in the outlet tube and that in some cases when older they will cave in and restrict flow. Not sure on "how" to pivot the oil cooler forward to gain access. Is the tank on swivel connectors or do the connections need removed or loosened some way to get to the hydraulic tank lower fitting?
Secondly I did get a 600+ page digital service manual with the tractor. After scanning through it only found passing mention of the wiring.
What I need is a full wiring diagram with color codes. Maybe that is in the standard operators manual which I have ordered. The wiring that actually functions is limited to the starting circuit right now, and I would like to get the charging circuit and gauges and some lights up and functional.
Third question on the 201 three cylinder Ford diesel. I thought this engine was basically a bored and stroked version of the 3000 175 cubic inch engine but have found reference to cylinder liners. Have also found reference to multiple oversize bore pistons. Do you happen to know whether this is a parent bore engine or if it is in fact a linered engine block from the factory?
Thanks for any info you might be able to help me with.
So far really impressed with how solidly built the 550 is and what a game changer the power reverser torque converter shuttle shift transmission is.
Beats the daylights out of my Rhino's non syncro manual.
/ Bought a 550 Ford TLB #7
The cooler swings forward after loosening the hydraulic fitting locknuts. The tank is supported by 2 brackets on either side mounted to the front cowl by carraige bolts. Remove the oil and lines, then remove the mounts.
I can get you a copy of the wiring diagram, but may not be anything more than what you have.
The Ford BSD engines were parent bore from the factory. The liners were service parts OR you could bore it out and install oversize pistons. Anymore, they are sleeved and a standard piston installed as the oversized pistons are not stocked. Also, the rebuilt engines are usually sleeved as cylinder pitting is sometimes the reason for the overhaul. The older block design however, had more meat than the newer blocks so this wasn't as common
TractorTech Thanks for the info.
Greased the multiple zerks yesterday morning and then dug out our trench burn pit.
The controls did get easier to be smooth with after an hour or so.
Decided to add a fixed thumb for the backhoe. After using the grapple on the Rhino so much, think it will be a nice addition
/ Bought a 550 Ford TLB #9
Be sure you grease the two fittings on that front pump driveshaft, two of the most neglected ones on a hoe, can cost thousands to repair the damage that shaft can cause if it lets go!
Thanks,
and I have not greased them yet...
My 3000 Ford's FEL had a front Vickers pump with the flex joint. When it had lots of hours pretty much everything including the pumps own splined shaft had to be replaced.
I will DIG into the tank outlet and screen soon and will also get the main axle pivot and inner tie rod to ram zerks as well. Need to order a selection of zerks as well the lower boom pivot one and a couple others are snapped off as well.
Owners manual should be here early next week which should have some helpful info as well.
Thanks again
Checked them late last night. Sure enough loose and Not long for this world.
I tried looking them up but what I found not sure it is the correct U joint for the pump drive shaft
Found this number
New Holland Spider Part # 218353​
replaced by this number
84355036
I would like to get the set with the injection point on the end cap as well
to make greasing much easier.
Have not been able to confirm these numbers are correct but do want to have u joints in hand before taking the front of the TLB apart.
Don't want to spend $3-4 hundred on a complete shaft.
Edit : Sometimes the obvious escapes me.
Messick's has a complete parts look up and order set up .
I will get some parts ordered later today.
/ Bought a 550 Ford TLB #12
the 218353 crosses in NAPA to these two that they might can get in a cap greased fitting
Part #: UJS UJ861
Part #: NPJ P861
if you GOOGLE the 218353 or it's replacement 84355036 there are lots of choices out there
Update or two,
Ordered up some parts from Messick's and also Yesterdays tractors.
Hopefully here in a few days.
Correct u joints to tighten up the main hydraulic pump shaft
Seal for the left brake rod where it enters rear differential to stop a drip.
hydraulic screen filter/gasket and connecting hose for the hydraulic tank to reduce pump whine-maybe
rubber coated metal seals for the hydrostatic rams for steering drips
engine temp sender
trans cooler
tach drive gear housing and drive cable
What has already arrived to be installed main gauge cluster. hydrostatic steering tie rod end
Voltmeter, seat cover, hydraulic seals for stabilizer that leaks down
Also ordered a Titan extreme 36 inch weld on fixed thumb for the backhoe and Gland Nut wrenches.
This 555 vid Hooked me.
Thanks to members for Very helpful info on the electrical system and pointer on the hydraulic pump drive.
This may sound crazy ,but I am really finding resti-fying this old 550 very enjoyable and also satisfying.
ps. also ordered and received the reprint of Owners manual and even an original 12 page Ford 550 sales brochure
More parts showed up for the 550, but need to remove maybe 2 stumps first, So I can get the site inspected for a DIY car port between our converted chicken house to small she-shed and larger Newer she-shed on other side.
Really just need a day or two... to do most of the repair work at once.
Did get a new tie rod installed and also ordered a new king pin kit as well.
Yesterday did get the brake actuator shaft seal replaced. No leak there now, Yay.
duplicate
More Progress
parts and mods so far:
Titan 138lb fixed backhoe thumb- 36 inch installed - may have to carry some weight in the FEL to get the most out of it.
New gauge cluster partially installed, Now have a working proof meter with new drive housing and cable
Basic charging system functional
pull stop wire replaced with a real cable and knob
Added some restore to the fresh T-6 Rotella- starts easy now
Coolant temp sender installed
Kats inline coolant heater installed
Front 26GPM pump driveshaft rebuilt
New hydraulic tank filter installed and tank tube Mig welded instead of soldered in place (solder joint was cracked and leaking- 4 failed attempts to re-solder) with new flex tube installed No more leaks up front hydraulic system
Transmission cooler and lines installed in front of main hydraulic cooler
Rear axle brake seal installed and not leaking- rear axle fluid dumped and re filled with new fluid
Grille painted black
brakes adjusted
Original heavy duty floor mat scrubbed, pressure washed, and reinstalled
Most of the TLB engine cleaner sprayed, scrubbed and pressure washed causing 5 extra showers for me.
Don't like working on dirty caked on greasy machinery
More to be done
new king pin bushings and shaft to be installed,
Voltmeter, temp gauge hook up, charge light, fuel gauge, instrument lights, 4 LED front and rear Flood lights to install and other assorted electrical to be re juvenated.
May install tire studs for winter still thinking on that
power steering leaks at the rams connectors
Outrigger seals to be replaced right side
The digital manual disappeared off of my Phone so found an ebay original factory service manual with "grease smudges and all" ordered and on the way.
ps. The manual is for 550 and 555 TLBs.
starting to think the 550 weights listed may be for the FEL installed with no ROPS and just rear weights installed No backhoe ( shows rear weights as 4000 lb).
All of the 555 weight listings are ~ 13,000lb or above when the ROPS and backhoe are listed, so maybe with this 550 having the larger 755 backhoe , largest 11L x 16 front tires the heavy duty front bucket ROPS and a 24 inch rear bucket does not weigh 11500lbs but is actually closer to 13-14 klbs?- that would mean we were likely "a Bit" over weight on the trailer and nephews RAM hemi 2500
Did some more work to the 550
Finished a job at another property and now need to dig a 120 foot power line trench. I could just get it done but the 3 cylinder exhaust on these Fords are LOUD. I think they may be one of the loudest stock exhausts of the tractors I have heard,
Did some looking and seems some Folks pull the round short muffler and add an Oval muffler from a 6000 series Ford diesel.
I got one and sure enough it got rid of most of the loud poppy exhaust note, brought the db's down considerably.
May add a removable muffler support that runs to the roof. Probably leave the hood off and do some more wiring and add some new LED flood lights also but now with some ear muffs on, the engine is much quieter and can get some more digging done without my ears bleeding.
It is a fairly large muffler but the sound reduction is more important than looks to me.
Was given an old boat which ended up being more trouble than it was worth so saved the trailer and turned it into a flat bed utility trailer.
Needed to get rid of the boat and knew trying to cut it up with a saws all was going to take a lot of time so had a patience my a--
I am going to kill something with the 550.
Was able to crush the hull with the fixed thumb and especially grabbing against the thumb and then crowding in against the boom.
Second pic was taken before crushing the last piece of hull by crowding in.
Actually picked the entire boat up and then dropped it a few times to remove the 4 cylinder engine outdrive.
Backhoes are FUN.
Still amazed at the hydraulic power and reach these old industrial machines have
Really saved a lot of time and hard manual labor have it all piled in metal for the recycler and pieces under 4x4 for the refuse disposal and regular wood for the burn pit.
Adding hydraulics to the thumb
16" stroke 3" cylinder 1.5" rod
Remounted the cylinder and then got to use the Arboga drill press
What a step up from the old small drill press
Annular cutters are wonderful.
Lots more to do.
The extreme actuation position will only be for light grabs with the thumb.
Tightened up the main bucket pivot pin.
The center bushing was in pretty good shape but PO had used a 1 1/2" pin with the bushing being 1.75" I took a 2 1/2" axle shaft and turned it down to fit.
Took a while on the small 12 x 24" lathe but it got it done.
I will probably turn some end bushings for the bucket as well to get rid of the slop that is left and also turn a center groove and some spirals in the bucket pin to help distribute the injected grease.
