sd455dan
Super Member
- Joined
- Oct 23, 2012
- Messages
- 6,291
- Location
- North Idaho
- Tractor
- Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
Checked them late last night. Sure enough loose and Not long for this world.Be sure you grease the two fittings on that front pump driveshaft, two of the most neglected ones on a hoe, can cost thousands to repair the damage that shaft can cause if it lets go!
I tried looking them up but what I found not sure it is the correct U joint for the pump drive shaft
Found this number
New Holland Spider Part # 218353
replaced by this number84355036
I would like to get the set with the injection point on the end cap as well
to make greasing much easier.
Have not been able to confirm these numbers are correct but do want to have u joints in hand before taking the front of the TLB apart.
Don't want to spend $3-4 hundred on a complete shaft.
Edit : Sometimes the obvious escapes me.
Messick's has a complete parts look up and order set up .
I will get some parts ordered later today.
