LittleBittyBigJohn
Platinum Member
- Joined
- Jun 7, 2021
- Messages
- 934
- Location
- Central Arkansas
- Tractor
- John Deere 1025R, Spartan SRT-XD 72" zero turn
I just got my 2013 Ram 1500 back from the shop 5.7 Hemi. Symptoms were ticking, lack of power, and check engine light. After a week in the shop they finally located a burned valve. The shop had the heads sent off to a local machine shop who repaired the burned valve, not sure the details. I'm sure they replaced the valve and seat, not sure what else. Put everything back together and it ran fine under light load but CEL would come back on under heavy load. Timing was found to be advancing too far. Timing set removed and the phaser for the VVT adjustment was found to be broken. That was replaced as well as the water pump and all timing components. Same issue. Heads come off again, damaged lifter found and it had damaged a cam lobe. Re-assembled and 3 oil changes, declared fixed, and it's running like new and sounds fine. Repairs ended up taking about 2 months.
Here is the dilemma. I drive a beater car for fuel economy most of the time. The truck usually sits until I need it for truck stuff, however I try to run out a tank in the truck about every 4-5 in the car so it's getting some use. When I do use the truck, lots of times I'm pulling a trailer or otherwise have it loaded. Back in the day I had a 3/4 ton and I liked it a lot for doing truck stuff. Full size bed, and also a full size 4d cab for when I also needed to haul more than 2 people any distance. It pulled trailers better, blah blah. You that have or had them understand the difference.
I had planned on just keeping the current truck until the end of time. But with the engine history, I assume a motor replacement is in it's future and I don't really think it would be worth the cost. I'm tossing around the idea of selling it and buying a newer 3/4 or 1 ton. Not that I need it and for sure don't need a dually... But I like the idea that if I'm going to be keeping a truck around for a long time for mostly just truck stuff, that it easily be able to do anything I would need to do with it for the foreseeable future.
But holy crap are they expensive! Then there's the diesel vs gas debate and which manufacturer has time bomb motors or transmissions in what year... Ugh. I'm not sure if I need advise or just someone to pat me on the head and tell me it will all be fine....
