Ideas for cannon ball extraction?
/ Ideas for cannon ball extraction?
Ok, so today's (non-update)
Perhaps a scenario/question first.....
I am rather OCD about trying to be safe on things. I have, do and will take chances, perhaps even push my luck a bit but, because I'm so OCD I (like to think) that I've analyzed all the outcomes (note: I did not see TWO, possibly three balls, so what does that tell you about my thinking process.....sigh.)
Anyway, I'm pretty firm in my belief that if gunpowder gets not wet, but SOAKED, it's not going to ignite. If this is true, then I've never had a worry with this. If this is NOT true, then I've been playing with danger (if in fact, it has gunpowder in it which I can't swear to either way)
Seeing how this is developing, I do NOT see my father dropping a ball in there to show someone how it works. With the advent of two balls, possibly three..... with nine more to go.... well.....yes. I COULD see him scratching his head thinking where the heck do I put all these balls????? Meh...I'll just drop them down the barrel so they're out of sight/mind.
I worked in it for about 6-10 minutes, ball didn't seem to be budging so I got the drill back out and had at it. The bit was buried and I got an idea.
How can I extract it using a threaded rod when what I have buried in it is a hex head with no threads?
I think I'll make a lever! I don't know if I can describe this very well (haven't taken any pictures yet) Grabbed a 24" 2x4. Drilled a hole near the end in the middle of it. Removed right angle drill from extension, slipped this piece of wood over the extension, put drill back on. NOW I've got a backstop that will keep the drill from moving forward. Prior to trying that though, I thought I might be simply able to use the lever against the drill chuck which will then pull the extension which will then (hopefully) pull the ball.
Nope. Simply pulled the bit out of the ball. This bit isn't buried as firmly as the first one. So, put all back together again, let the drill proceed deeper into the ball but, since the head of the drill was butting up against the 2x4, it wouldn't give and with the lead being soft, it DID give and reamed the bit right back out of the ball.
Clouds came in and it started to rain so I shut it all down. The current situation is, the ball hasn't budged nor rotated a bit. I might just drill to the end (presuming another ball) and once a hole is in the middle, start another one offset to one side, then the other side. Just drill the ball(s?) to weakness and either break/bend them into submission.
Looking ahead, (as I'm typing this, I just thought of something) a lever (think crowbar) might be helpful when the time comes to work in there on the balls. I don't have something like that and this might be a great reason to go get one that might be long enough.
Actually, THAT now has another thought in the back of my head.... I'm thinking out loud, but will ask.
Do they make a chisel that is 24-30 inches long to fit an air chisel or, just to beat on with a hammer? That might be a nice way to section the ball once I get the hole complete.
That might harken back to...what was it called... a ball worm? Cannon Worm?
/ Ideas for cannon ball extraction? #204
I am not there and you have the expertise now but I did wonder about making a slide hammer/drill bit combo IF the bit bites good enough. You could just add the hammer before drilling? anyway, you have a good grip on it and good luck.
/ Ideas for cannon ball extraction? #205
/ Ideas for cannon ball extraction? #206
Fascinating thread.
I keep having flashes of what could happen if there is residual powder in there, so if it were me, I wouldn't want to be generating heat or friction without the breech flooded with water. Black powder that gets wet and dries is more powerful than powder that hasn't been through the process. ("Corning")
You could always drill a hole in the ball, thread it, and use threaded rod through a plate at the muzzle end as a home made gear puller. I wonder though if getting the barrel ground/honed bored might not pay dividends once the ball is loosened, as the ball would promptly transition to a low friction area of the barrel once it was partially dislodged. However, I would grind/hone/bore with the muzzle significantly lower than the breech to have any grit or debris wash out during the process.
And, yes, I think your cop/machinist/armorer is a very good guy to get to know, especially if he is super keen on black powder.
All the best,
Peter
/ Ideas for cannon ball extraction? #207
A tractor site and no one, not one person has suggested hooking it up to the PTO and swinging it around by its tail like a dead cat to let centrifugal force work it's magic ! May need to back up to a loading dock to get proper clearance, and don't forget to use a counter weight or it could be dangerous!
/ Ideas for cannon ball extraction? #208
Just checked: there are 341,539 members now. I wonder how many of those members have a problem with a stuck cannonball, or have a cannon but don't yet know if there is a ball inside.
I've learned that if I find that I have a cannon, there may be a ball or two inside.
Maybe this thread will be brought back every years or two by someone with a stuck cannonball.
Good entertainment!
:D
Bruce
Imagine how much fun a pallet can be.
/ Ideas for cannon ball extraction? #209
Drill and tap the flash hole for a small pipe, screw on a fitting, then divert one of your hydraulic lines to it.
It is now a single action hydraulic cylinder with a free piston.
Bruce
/ Ideas for cannon ball extraction? #210
/ Ideas for cannon ball extraction? #211
I didn't catch the drill size, but if it's not too big, I'd make an ez out with a big lag screw and a chunk of 1/2-13 all thread. Weld the lag to the thread, get a chunk of flat bar with a hole in the middle to pull against, put that on, then a nut behind it, then weld another nut on the end so you can get on it with a socket. When the lag has a good bite, run the nut down to where the bar is in contact with the bore and then keep turning. It should pull it out with any luck.
/ Ideas for cannon ball extraction? #212
Clean the oils out. Clean the barrel with at least a wire brush. Apply some jb weld to a rod and stick that sucker onto the ball. You could probably pull it out then. If it rolled deeper than I’m guessing it will pull out with out to much trouble.
Too funny. I have both, should I use the 1000 or 540?
I have a 36" 3/4" Bosch SDS hammer drill bit, and they make a SDS chisel bit 18" BUT, IMO a hammer drill and a 3/4" bit may provide the hammer effect to loosen it up. https://www.amazon.com/Bosch-HC2129...locphy=9002459&hvtargid=pla-523861698414&th=1
I never thought about a bit like that. I might already have one too.
I like the idea, especially with the bit being smaller, I can maybe be more precise with it's location
(Am working today and tomorrow, 100 miles from home so will take a couple days to be sure)
/ Ideas for cannon ball extraction? #217
Don't know if this has been suggested, but maybe load it with dry ice to shrink the cannon ball and loosen it? Might need to insert a pvc pipe section inside the barrell in contact with the ball and then load the dry ice inside the pvc pipe so the dry ice doesn't touch the barrell and shrink it too. Could even heat the barrell to expand it while the dry ice shrinks the ball?
/ Ideas for cannon ball extraction? #218
Personally, I would be concerned that since lead is a soft, soft metal that any amount of hammering on the ball will cause the ball to mushroom out in width, further cementing it to the barrel.
They used to sell concrete anchors based on the same principle and they were wonderful anchors.
Just kibitzing from the arm chair...
All the best,
Peter
/ Ideas for cannon ball extraction? #219
JethroB --
You should post your story to the Groan thread. Absolutely hiilarious.
2002 Mitsubishi Lancer Sedan (A64557)
2002 Mitsubishi...
Pemberton Inc 416469 Hydraulic Dual Cylinder Grapple Bucket (A64194)
Pemberton Inc...
New/Unused Wolverine Mini Quick Attach Pallet Forks (A65583)
New/Unused...
2012 Jeep Compass (A64194)
2012 Jeep Compass...
72in. Skid Steer Bucket (A65640)
72in. Skid Steer...
621B PAN 300Hrs on Engine 3406 Offsite Danville VA Everything Works (A62613)
621B PAN 300Hrs on...
