sharpening mower blades
/ sharpening mower blades #21
ZD326 60", ZD1211 72", Bobcat hydro walk behind, Stihl trimmers and blower.
The 326 is setup as a bank mower with ag style chevron tires that are fluid filled. I have a set of wheel spacers ordered to widen the stance by 4". The 1211 is my primary mower, and the 36" walk behind is used on really steep banks and gated areas.
I trim half of those 18 lawns, the others trim it themselves.
interesting. i also have a hydro walk 36" walk behind for steep dam banks, excellent companion to my rider zero turn. sounds busy, regards
/ sharpening mower blades #22
Pretty sure OSHA killed it. Toru once made a 2 cycle push mower that had a disk with 4 sickle bar points for the blades. You could push the handle down to angle mower deck and walk thru waist height weeds.
Check out cutting disk on this machine.... It popped up on local yard sale site just today
y...
/ sharpening mower blades #23
Seems like a lot to sharpen them after every mow, but I do have to say that the first cut with freshly sharpened blades does tickle my fancy as well.
I mow about 2 acres worth, generally I scrape out my deck every 3rd or 4th mow or so. So that's when I check the blades, if they need it I pop them off and run a flap disc on em with the angle grinder. Good to go.
/ sharpening mower blades #25
Agreed. I clean my d4eck every mow but then I have a front deck that flips up 90 degrees so it is easy to do. Sharpen my blades every 4-5 mows cutting 2+ acres each time with a 72" deck.
/ sharpening mower blades #26
Unless you're cutting heavy turf with sticks and typical debris etc...you should not need to sharpen blades that often...
...It is recommended to have a smooth cutting edge of about 1/16"...they should not be knife sharp...
Why a 1/16" edge? That seems very dull to me. A sharp edge gives a cleaner cut, the duller the edge the more shattering of the blade of grass you are cutting.
/ sharpening mower blades #27
The blades are meant to SHEAR the grass...not cut it like a knife...all one has to do is look at the cut edge of the grass...if the tops of the fresh mowed grass blades are jagged or shredded it is a sign of a dull or damaged blade...
1/16" may be a little blunt for many lawns...but they will hold up better when cutting grass where there is a lot of loose sand, small stones etc...or really tough grass like Bahia...
Some people buy new blades and think they have to be sharpened because they have a proper blunt edge...
/ sharpening mower blades #28
my understanding is that 90% of the cut on a blade occurs on the 1st few inches from the end of blade. that's where most of the wear occurs & becomes rounded. but i cannot empirically verify, just to note where most of the wear occurs.
in addition, one item often overlooked that leads to a poor cut: bent blades, even slightly, can lead to an uneven cut. so next time, check blades with a straight edge. regards
/ sharpening mower blades #29
I have set up a way to sharpen, balance and check for bent blades that works well for me. A jig that is adjustable for the angle using a 4.5 inch grinder makes perfect grinds on the blades and a rotating hub with magnetic sleeve holds the blade to check for balance and check for run out to see if the blade is bent. Also a high lift floor jack and stands gives quick access to the blades underneath. An impact wrench set for the right torque makes it easy and quick to take the blades off and torque to spec so there is no rotational slips. Makes for smooth running mower and saves fuel and gives a good looking cut
/ sharpening mower blades #34
/ sharpening mower blades #35
Front deck would not require the jackstands and lying on your back reaching underneath. Makes blade removal/install much easier, nicer, and safer.
I have never ground with a handheld grinder on the edge like that. Seems like a good idea but a llittle slower than laying the wheel down on the face of the cutting edge rather than using the wheel's edge.
/ sharpening mower blades #36
A front deck mower is ideal changing blades for sure. I my case it is too slow due to mowing around trees
/ sharpening mower blades #37
I really do not understand that statement - unless you are referring to a front deck rear wheel steer. I much prefer my front deck zero turn to mid mount because I put the deck under the trees without me being in the tree.
/ sharpening mower blades #38
Try to do that on 6000 trees and you will find it is slower to mow
/ sharpening mower blades #39
A "shearing" action requires a double blade like a scissors and typically both edges are very sharp like stamping die to get a good clean cut not a drawn out one. The other option is the old reel type lawnmower but I do not think that is what we are talking about here. Since there is only a whirling blade I do not understand your explanation.
I do agree that a blunted edge will hold up better but you can do the same with a sharp edge and mow a few times - the grass will wear them round. - the longer I go between sharpenings the rounder they get and the more the blade is beating it off instead of slicing it off. So again - why blunt it - do you think the square edge with a small face provides for less wear?
/ sharpening mower blades #40
Nice set up m7040.
Use belt grinder to bevel and blunt the edges. Easy to remove metal without getting blade too hot. Sharpen Gator G5 blades once/twice a year. Yards, berry patches and orchard. Fall mulch leaves down my 1/2 mile gravel green tunnel driveway.
TAYLOR 2R MULTI-PASS HARVESTER (A64278)
TAYLOR 2R...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
