sharpening mower blades
   / sharpening mower blades #11
Whatever floats your boat!
I personally sharpen my Gator mulching blades every 30-35 hours or so, along with greasing my zd mowers. For me, that works out to be once per week.
I also gave up trying to keep a 30 degree edge by hand with an angle grinder. I have been using a commercial jig that keeps the edge correct.
I am interested in the grinding wheel the op is using. I'll look it up eventually...
   / sharpening mower blades #12
I personally sharpen my Gator mulching blades every 30-35 hours or so, along with greasing my zd mowers. For me, that works out to be once per week. RjCorazza
you're mowing that much per week? almost a full time job...that much per month seems about right, can't imagine spending that much time on mower every day, maybe you're in the business?
sounds like you have a system though, regards
   / sharpening mower blades #13
That's lot of sharping,after 3-4 mowing I touch up the blades also deck couple inches from ground.
   / sharpening mower blades #14
As cheap as blades are, I NEVER sharpen them. Just replace every fall. I get all my blades from ASC. Save the old ones to make knives from. Good tempered steel.
   / sharpening mower blades #15
Retirement gig, plus I really enjoy cutting grass. I mow 18 rural lawns within a 1/2 mile radius of my house.
   / sharpening mower blades #16
what equip & size are you using? weed trimming too, or just mow?
   / sharpening mower blades #17
If I had 18 neighbors within 1/2 mile I'd have to move. I have 2 that close. One on 80 acres the other on 2 acres split from this property many years ago. Not my doing. Mostly I'm almost surrounded by National Forrest.
   / sharpening mower blades #18
ZD326 60", ZD1211 72", Bobcat hydro walk behind, Stihl trimmers and blower.
The 326 is setup as a bank mower with ag style chevron tires that are fluid filled. I have a set of wheel spacers ordered to widen the stance by 4". The 1211 is my primary mower, and the 36" walk behind is used on really steep banks and gated areas.
I trim half of those 18 lawns, the others trim it themselves.
When I let it go that long I notice the difference in fuel, in energy, in speed I can go, in cut quality, especially if I let it get tall, and I do that rather a lot.
I've never paid attention to things like that. I'm, fairly consistent but I have never once bothered to check the angle.
PFERD
This video made me want to try them, And Oh man~!!!
They are spendy but man oh man do they last and last and last I have thrown all my flap disks away. I bought 'em in Jyly 2021. I put one on my 4.5 angle grinder and many welding projects ago. I prefer to descale any steel I'm going to paint so this one disk I've been using has seen a lot of use between the little Metabo grinder and my bigger porter cable 8". So far I have only used the two disks, one for each grinder and they are still going strong.
   / sharpening mower blades #20
Pretty sure OSHA killed it. Toru once made a 2 cycle push mower that had a disk with 4 sickle bar points for the blades. You could push the handle down to angle mower deck and walk thru waist height weeds.
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
2023 INTERNATIONAL MV607 21FT ROLLBACK (A54607)
2023 INTERNATIONAL...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
2017 GMC SIERRA 1500 (A55745)
2017 GMC SIERRA...
