Ideas for cannon ball extraction?
/ Ideas for cannon ball extraction?
Regarding the hole(s) in the ball. So far, I've only seen a single hole. I've stuck a rod into it (some steel wire) and it appears to be maybe an inch deep or so.
Stuck magnet on it, magnet falls off. I talked to a gunsmith guy (to find out about how/where to buy powder) he said it was likely made of lead.
I have no idea.
The cannon doesn't come apart. Let me rephrase that.....the METAL part of the cannon is one piece. It has the stubs that allow it to hinge inside the wooden frame but there is no breech to open up to have access to anything.
The cannon itself appears to have a muzzle that is then, surrounded by another metal (bronze?)
The liner appears to be roughly 1/4" thick. You might be able to see it in the pictures. I'm guessing they take this liner, then cast the cannon around it (but I have no idea). Not a hint of rust on the exterior. The liner in the pictures is what appears to be crusty looking.
I hadn't thought about putting water in. I can put that into the barrel, it will seep behind the ball, then I can use my air. That might be enough to dislodge the ball. It will also push it out but not as easily as the air itself passing by the ball.
Nice idea!!
/ Ideas for cannon ball extraction? #22
It is possible that the ball is lead, if so it is easily scratched. Try an iron rod and scrape the surface, if it scratches, you will see a shiny surface and it's probably lead. However, that appears to be a "real" cannon and cannon balls were made of iron not lead back in the day. The "pounder" nomenclature, as in a 6 pound cannon referred to the weight of an iron cannon ball. (Yours is smaller than that, but not sure what size it would be.)
Note: hollow cannon balls were used as fragmentary munitions just like grenades.
/ Ideas for cannon ball extraction? #23
This won't help get the cannon ball out so unless you just want to read my cannon story ignore it.
After the Civil War, a couple of my relatives went north to retrieve the body of a brother. They didn't find the brother but somewhere got possession of a tiny Revolutionary War cannon. My cousin still has it. The kids in the family are said to have loaded it with fireworks and fired it in the early 1900's.
/ Ideas for cannon ball extraction? #26
I've had a post hole auger stuck in a hole, thought it was hung on a root until all I dug out was dirt and clay. Had a tube within a tube hung only by corrosion that nearly caused me to destroy the outer tube before I got it out, and have rung off many bolts when all that was preventing the nuts unscrewing was a tiny bit of rust. It's amazing how little it takes to stick something in bore hole.
/ Ideas for cannon ball extraction? #27
I have no idea.
Nice idea!!
I normally don't really worry about outcomes for posters with problems but you REALLY need to report back how you got this out. It is an interesting problem to have.
/ Ideas for cannon ball extraction? #28
Yes, please respond with your solution. This is interesting.....
/ Ideas for cannon ball extraction? #29
Good luck but I think that will not come out in one piece unscathed unless you do your ether idea with fuse to ignite it. I have also used household alcohol sprayed into combustion chamber to get engines to fire.
Try small amounts gradually increasing if it moves at all. You could even tamp it back down each time to give each new shot a running start at the crusty bore.
/ Ideas for cannon ball extraction? #31
Summer heat may be your friend. Get the darn barrel CLEAN. Get some grease or lube behind the ball. Try on the hottest days, after it's sat in the sun, maybe assist it with anything you have that will throw a flame. Then when hot lift it so you CAN drop it with a serious whack on a piece of wood (so as not to damage the barrel), but start off with gentle whacks.
Videos are required!
/ Ideas for cannon ball extraction? #32
I have no idea whether this is good or bad advice but it is LOL funny. thanks for that.
/ Ideas for cannon ball extraction? #34
Like others have said step one get the bore cleaned out.
Then start trying to get the ball free.
/ Ideas for cannon ball extraction? #35
If you can find something like this in the right diameter, just a little less than the hole, it might clear to bulk of the junk out fairly well.
Creating an ultimate Sanding drum!
The follow with a wire wheel.
Or maybe the other way around.
/ Ideas for cannon ball extraction? #36
I’ve been told ammonia will break a cold weld. Or fill with water behind the ball and freeze it some how?
/ Ideas for cannon ball extraction? #37
ACME Company might be a good resource...
/ Ideas for cannon ball extraction? #38
Maybe a lag bolt on the end of a rod, screw it into the lead ball and pull.
Any chance there is a powder charge under that cannon ball? If so, proceed with extreme caution.
I found an old cannon ball and I questioned a local museum about the cannon ball. I was warned about "live" cannon balls. The museum had a cannon ball that was "questionable" and not taking any chances they had a bomb squad remove the cannon ball.
While mine was a cannon ball and not a cannon, If you are not 100% sure there is no charge behind the ball do not attempt to remove the ball.
2025 Auger Bit Skid Steer Attachment (A64553)
2025 Auger Bit...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
MAXILATOR SQUARE BALE ACCUMULATOR GRAPPLE (A64277)
MAXILATOR SQUARE...
(2) New 27X8.5-15 turf tires in John Deere 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 27X8.5-15...
2010 MACK TITAN (A65643)
2010 MACK TITAN...
2006 Utility 53Ft T/A Reefer Trailer (A64194)
2006 Utility 53Ft...
