Our barn build
/ Our barn build #21
What length post did you use, and what was your method for setting them? I am getting ready to do a barn build and am putting 20' post in the ground and am wondering if I should make a boom pole for the front end loader to set the post. My tractor bucket will go 13' off the ground on it's own.
Whenever I set vertical tube steel we rig it to be just bit heavy on the ground end. One person can normally one hand guide it into position.
/ Our barn build #22
Fiber does not replace rebar. It could be considered an added bonus, but overall, it doesn't really accomplish much. Rebar holds the slab together and increases the overall strength of the slab. The bigger the slab, the more important rebar set on chairs is.
The rebar needs to be in the middle, to lower third of the slab. You have to use chairs to keep it in the air while the concrete is being spread. The biggest lie in concrete work is that they will lift it while spreading the concrete. This is done at first for pictures, and then quickly abandoned when they really start working. Then the rebar is walked on and pushed to the bottom of the concrete, where it's almost worthless.
More important then rebar is water. The bigger the pad, the more likely it is to add more water to the mix so it spreads faster and easier. Excess water is why concrete cracks in the first week. Cracks from the soil take years to happen. When the excess water evaporates, there is less volume to the concrete pad. This forces the concrete to crack. If you have enough rebar in place, this will hold the concrete together so you don't see the cracks. If you don't add extra water to the pour, the cracks will be so insignificant that you won't be able to see them.
To know if you have too much water, you can do a slump test. But for residential work, just making sure that the concrete will stand up on it's own is a good enough test. If it spreads out from it's own weight, you have too much water. When it comes out of the chute, it should just pile up on to of itself and slowly spread out.
/ Our barn build
Have two concrete quotes so far, awaiting one more.
Meantime, continuing the framing that won't obstruct a concrete truck. Beautiful weekend for hammering nails. And I wasn't alone...carpenter bees out in droves, saying thanks for the buffet.
/ Our barn build
Side shed rafters done and starting on the purlins. Once the concrete gets poured and cured enough (at least a couple of weeks out), we'll start on the center loft joists, and from there, the rafters for the center aisle.
A neighbor who is building a house cleared a bunch of hardwoods from his lot, and had the contractor drop the logs off at my place. There's a lot of white oak in the stacks of logs. The wife is lobbying for white oak siding rather than pine. She can run the sawmill same as I would, so I suppose it's her call. :)
/ Our barn build #25
looking good, nice Score on the logs. I’m looking foreword to seeing the wood siding. There’s a barn in my area that has wood siding and red metal roof, really looks good.
Mike
/ Our barn build
Had to take a few weeks off for family obligations and spring cleaning chores around the property. Just not enough hours in the day, particularly Saturday and Sunday!
Anyway, got started again, putting up the purlins for left shed roof. Going smoothly, one more 38' run and that will be done. In the meantime, I'm getting some unsolicited help from a pair of pileated woodpeckers, who are inspecting the holes made by the carpenter bees.
Argh!
Filled the holes with polyurethane adhesive. As I'm writing this, I realize I shouldn't waste the excellent, Locktite PL3X on this, and instead use the cheap Liquid Nails adhesive. Perfect for this use.
There were three or four areas like this, including one rafter right at the mating point with the support plate. Had to cut a piece of board to make a sister for it. And I found one carpenter bee hole in a piece of treated 6x6, used as a brace. You would think the bees would have better taste than that.
Anyway, project underway again.
/ Our barn build #29
That's a first. I never heard of a wood pecker going after framing during construction. I've had jobs where they went through the cedar siding on a house and the homeowner would cover the hole with a piece of wood, just to have it happen again. When I fix the holes, I use metal cover plates for electrical junction boxes. Then I paint it to match.
/ Our barn build #30
I procured a new insecticide for carpenter bees this week as they found time to bore three holes in my massive cedar pergola.
Man… that stuff kills. Anything landing on those timbers really regrets it.
Good luck with the barn. Hoping to get mine started soon.
/ Our barn build #31
Yes, rebar, rebar, rebar. The only alternative worth considering would be wire slab mesh - looks like steel cattle/hog panels. Concrete is great for compressive forces, but weak on tension. The steel compensates for the tension part. Every time I see a slab that has cracked because someone saved a few bucks by skipping the steel, I feel a desire to interview the person who made the decision to ask how much they regret their decision.
/ Our barn build
Can you share what the insecticide is?
/ Our barn build #33
I’d like to know also. I’m trying permethrin this year, I sprayed down my pavilion and I do think it has helped.
Mike
/ Our barn build #34
BioAdvanced Carpenter Ant and Termite Plus…
It definitely kills more than just those… and carpenter bees are also listed. Haven’t seen a bee near the pergola since, but have seen other various insect victims daily under the pergola… I can only presume from contact with the treated wood. The concentrate goes a LONG way… it will last me years.
/ Our barn build
Appreciate you sharing that!
/ Our barn build
Side shed purlins finally done.
Starting to work on the loft joists and framing the opening for a stairwell.
/ Our barn build
Loft joists and blocking complete. Joist blocking is one of those slow, repetitive, nearly invisible tasks. But it sure stiffens a floor.
/ Our barn build #38
If I may ask, what is your projected cost going to be? .... basically for the framing and roofing. I understand you will be cutting your own siding.
Looks great! Making good progress too!
/ Our barn build
I should be at about $16K to $18K when done, including grading, concrete pad, and roofing. Some variability based on cost of concrete and roofing when I place those orders. And some variability for windows, as well. May be able to get those second hand, as we have a great local retailer who sells builder returns pretty cheap. Also, as of right now, I've got a branch 20A circuit nearby for lighting, but I may go whole hog on electricity and have the power company put a meter in, since it's only about 75 feet away from the pad transformer in our yard. Haven't priced that yet, either.
/ Our barn build #40
Thanks. That's actually not too bad of a price. I have been thinking about a barn / multi purpose building about that size. Way off in the future, maybe a year. You're making great progress for sure!
2022 John Deere 317G Compact Track Loader Skid Steer (A61567)
2022 John Deere...
378888 (A61166)
378888 (A61166)
KMC 216-18' HEAVY DUTY ROTOTILLER (A62130)
KMC 216-18' HEAVY...
2013 Dodge Durango AWD SUV (A61569)
2013 Dodge Durango...
2021 John Deere Z960M Zero Turn (A63116)
2021 John Deere...
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A62131)
UNUSED WOLVERINE...
