Yanmar tiller ID help
/ Yanmar tiller ID help #41
You guys sure know how to make an old man happy! I just got a Speeco Quick hitch for my Yanmar 1720D tractor so I don't have to climb up and down with a hammer to change tools! I too have an unidentified Yanmar tiller. Imagine my delight on finding this Thread! I needed to modify the 3 point hitch pin locations on the tiller to get it to fit the hitch. Now I can look for replacement panels, wheels or what ever to help it look, perfom and be better! Thanks!
/ Yanmar tiller ID help #43
You guys sure know how to make an old man happy! I just got a Speeco Quick hitch for my Yanmar 1720D tractor so I don't have to climb up and down with a hammer to change tools! I too have an unidentified Yanmar tiller. Imagine my delight on finding this Thread! I needed to modify the 3 point hitch pin locations on the tiller to get it to fit the hitch. Now I can look for replacement panels, wheels or what ever to help it look, perform and be better! Thanks!
So we have one vote for a RS1400 tiller.
Could you measure the two end-to-end panels from the inside and give a measurement please. It's one way to verify the model.
If it's a 1400 type, it would be a longer method to determine the exact tiller model.
The most popular sizes are the 1400 & 1600 numbered tillers.
1400 (no prefix letters, usually with numbers on a red background on a green tiller)
RC1400 (the classic)
RC1400K
RC1400K2
RS1400 gen-1 green
RS1400 gen-2 red
RS1400A
RS1403
RS1404
RSA1404
RSB1400
RSB1401
RSB1402
RSC1404
RSE1401
RSE1401K
It's possible there are more variations like a 1405, 1406, 1407. I just don't have those manuals.
/ Yanmar tiller ID help #44
Do you also need a Koyker 110 manual too?
Did you snag the YM1720 manual in the other thread?
  • 110.pdf
/ Yanmar tiller ID help #45
In my last reply RS-1400 from Fredricks equipment. They told me the rear wheels I wouldn't need. Spalding also Which was true and I better go get it. When they sent the correct Pto. shaft which I had to shorten the Org.. I told them to forget about the wheels. Which they was right of course. If I recall the only thing to worry about is the Gear oil or depenbing on the model chain Driven. My Tiller main Shaft bearing was the worst thing or only thing I didn't care for. Glad I cleaned and greased it. Last one Fred. Had. We had to go to a back warehouse and dig it out. Only lasted a couple days on CL. Yrs. later when I sold it and for what I gave for it. Big Plus ;)
/ Yanmar tiller ID help #46
Thanks for all the great info. The width measurement is 48.25 inches. I did get the Koyker manual as well as the manuals for the YM1720D. One of my neighbor's Mom translated all the decals on the tractor for me so I had an edge going in!
I'd like to remove the wheel adjuster if it's not needed but having the extra weight is a good thing? Right?
Does anyone have a picture of how it looked new or at least not beat up like mine! I'd like to spruce it up, when I have a spare moment somewhere between the Honey do list and the repairs needed to be done yesterday! LOL
Here are some photos of the numbers on the tiller as well as what remains of two decals on the back end.
/ Yanmar tiller ID help #47
Does anyone know what went through the "hole" in the middle of the rock guard on the rear?
/ Yanmar tiller ID help #48
Another question if I may? I'm assuming that the oil for the tiller gear boxes is 90w heavy duty gear oil? and also is the plug just above and right of the serial number the full mark? Thanks!
/ Yanmar tiller ID help #49
No hole in my RS 1400 I can recall. This pic I had out had me thinking that my tiller was bigger that 48". The Tines was my guess. My Rear tires are 49" and you can clearly see the tiller is bigger. Or the Tine width is with No tire tracks. You look to be leaning back as if the Top link needs to be shorter. May not affect anything there though. But watch the PTO shaft alignment and keep it level or straight as possible.
/ Yanmar tiller ID help #53
It apprears to be leaning back because the adapter for the quick connect adds about 4-5 " in length. I'm currently trying to modify the top link holes so I don't need the adapter. At the same time, I need to modify the rake and box scraper so all 3 implements will have the same top link to bottom pins length. Then changing tools will be a snap!
/ Yanmar tiller ID help #54
For what it's worth, my tiller is plainly and originally marked RS1300N it measures appx 53-1/2" outside to outside of metal covering, It tills 51" (1300mm). It is gear driven, no chain. It also has the little opening on the back shown in your picture but has an internal cover attached with bolts and wing nuts. No idea what it might be for.
/ Yanmar tiller ID help #55
Looking at a few old Pics. 48.25" is to small for a RS1400. My rear tires being 49' longest point shows that. And here another pic. of the 1400. The tine total width is in the mid to upper 50" looking at it. Here is a 1300 and the way the rear wheel mount looks different. no doubt about that. May look for a Ser.# on a Tine possibly?
/ Yanmar tiller ID help #56
This rear wheel Mount looks to be the same. RS1200 is what they call it. Had to make mounting brackets for a 3pt. like you QH...
/ Yanmar tiller ID help #57
I've replaced the tines once. Got them from Hoye as I remember. There's a serial number on the gear end (23721T)
/ Yanmar tiller ID help #58
,,, since the Yanmar logo marking and the color don't match up ... your tiller is difficult otherwise to identify.
20-some years ago and far away, in the PNW corner of the Left Coast (inside joke) an importer (not Ernie or Buck) posted a full photo series of the rebuilding process in 'his' rebuild facility with some 250 employees just north of Ho Chi Mihn City (Saigon).
This photo may resolve the mystery of the large unexpected Yanmar logo on this present tiller.
/ Yanmar tiller ID help #59
Figured that a Part # or Tine# would work!! I came up with a RS1200.
/ Yanmar tiller ID help #60
WOW, that is some really neat history. Look at all that new hardware being installed. :) That would be me on the left, ballcap, jeans and flipflops working on machinery in the garage.
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
2022 EZ-GO ELITE...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
2019 Chevrolet Silverado 2500HD Crew Cab Pickup Truck with Liftgate (A61573)
2019 Chevrolet...
12ft S/A Utility Trailer (A61574)
12ft S/A Utility...
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A62129)
2000 CATERPILLAR...
