New Lawn for new house - looking for input and advice
   / New Lawn for new house - looking for input and advice #21
I'm trying something new this year.
No Mow May.
It's pushed by bee keepers to give the pollinators an easy spring.
I don't know if I can make it to the end of the month.
   / New Lawn for new house - looking for input and advice #22
   / New Lawn for new house - looking for input and advice #23
My experience with the box blade is that is great for moving material and getting a rough grade. I've never been able to get the surface level enough to seed. I built a small land plane out of scrap angle iron and concrete block weights and it's great for getting a good lawn surface. Unless you are a real master, the box blade will just be frustrating.
   / New Lawn for new house - looking for input and advice #24
I’ve had good success with 24-D and Sticker Spreader, but you also need nitrogen. Clover loves nitrogen deficient soil... so you need to fix that, or it will crowd out grass
   / New Lawn for new house - looking for input and advice #26
I had great success with a rock rake behind the tractor after rough leveling with a box blade. It's basically an auger with teeth on it, it pushes the rocks and debries if you have any to the side and fills in the low spots with soil. I then spread the seed and rolled it with a cultipacker to push them into the soil worked great did two acres no mulch in late August in Wisconsin Kentucky bluegrass and red fescue were the main seeds with some rygrass mixed in for a cover crop.
   / New Lawn for new house - looking for input and advice #27
I don't spray clover. I plant it.
I never understood being too picky about grass varieties in a rural 'lawn'. If I wanted to maintain a pristine lawn of Bermuda or Zoysia or St. Augustine, I would just keep the place in town. Nothing wrong with clover out on the farm if that is what grows in your area.
Note: for those of you up north, those names are grasses that grow well for lawns down here.
   / New Lawn for new house - looking for input and advice #28
Most of my “grass” is about half dutch white clover, with red and crimson on the tree edges and right-of-ways where I don’t mow as often.
   / New Lawn for new house - looking for input and advice #29
Agree. I'm a firm believer in Sticker Spreader or an equivalent.
   / New Lawn for new house - looking for input and advice #30
I view it as my responsibility. I don't maintain my property for viewers. I maintain my property for me. When people say "you sure keep your place nice" I just smile and say "it's my job". :)
The last time I lived in town was 1975 so I can't relate to that comparison.
   / New Lawn for new house - looking for input and advice #31
You like a lifeless, monoculture, desert of grass? Rabbits gotta eat man.
   / New Lawn for new house - looking for input and advice #32
Hi,
We recently finished building a house and I'm getting ready to do the lawn this fall. Currently, the area where the lawn will be going is mostly backfill from the house that was rough graded by my excavation contractor and an area over the septic field.
My equipment is an L3301 with a FEL and a box blade. I also have access to a landscape rake if I need it. Big implements like a pto tiller aren't really in the budget right now so I'd like to try and complete this with what I have. I could buy or build a drag mat if need be though.
My planned approach right now is to:
1) Remove all the large rocks/roots/debris from the area
2) Loosen up the existing soil with the scarifiers on my box blade and remove any existing weeds
3) Spread a layer of topsoil to a min of 6" depth over the existing soil and smooth it out with the box blade and raking by hand
4) Fertilize, seed and water
Am I missing anything? Can I do this with just my box blade and FEL? Any input and advice would be appreciated.
Thank you!
Retired Licensed Landscape Contractor here.
I wish you could provide pictures of your native soil.
If it is truly all gravel, grass is not going to grow well there.
If it is gravelly soil, you have a better chance. Some pictures of the conditions and a close up of the soil, a shovel full would help.
   / New Lawn for new house - looking for input and advice #33
I would buy, rent or borrow a drag harrow. Very handy device, and easily resold if you have to buy it and don't have a future use for it. Get a nice heavy one and the three point steel frame that allows you to lift when necessary.
These harrows have three different levels of aggression. Tines down and forward is the most aggressive. Then, tines down by backwards. Finally, tines up. They do a far better job that any landscape rake would do
I did a large lawn with a similar base. Acquired some horse manure and let it rot, mixing with lime to neutralize the acidity. Then spread it a week before seeding. Now have a perfect lawn!
   / New Lawn for new house - looking for input and advice #34
In SW Ontario, for a new lawn around a new house, a couple inches of top soil over the property and make a line 20' from the house all around. Sod this area. It will take tons of topsoil so be prepared and a few hundred pounds of grass seed to complete the property.
Spray remaining lawn for weeds Prior to grass seeding. Rake the grass seed in and then roll the area.
Do not roll when wet, you will pick up the seed!. Good luck. Give it 3 years to fill in.
   / New Lawn for new house - looking for input and advice #35
In gravel driveways is where grass thrives around here. I bought a 3 acre lot that had a short gravel drive, 7 years on you can’t tell there was ever gravel there unless you dig a hole. All I did was not stop it.
   / New Lawn for new house - looking for input and advice #36
25 yr landscape professional. Harley rake is the best option if you can rent locally. adding topsoil almost always causes problems with drainage if you don't till in. I usually only add about 2" to a 10"grading depth in order to not change the drainage characteristics too much. lots of ways to flatten but it really depends on how good you are in the seat. hydroseed will give you the fastest germination but you still have to water if any dry periods at all during growing in(even 1 day). Sometimes hydroseeders will offer a guarantee if it doesn't germ. they will return for free to spray again, but usually only if you have irrigation. Just rent whatever attachments you need, it still saves over having someone like me do it.
   / New Lawn for new house - looking for input and advice #37
I agree it's getting late to put in a lawn and would be tempted to sow cheap annual ryegrass as a cover crop.
But if you go ahead, or when you do, straw is your friend. Especially if there's any slope. Straw holds moisture for the seedlings, breaks the force of raindrops, adds organic matter, and slows surface flows that will cut rivulets or gullies.
   / New Lawn for new house - looking for input and advice #38
If you have a garden or fruit or nut trees, you want bees. The best way I know of to keep bees close by is to let them have access to stuff they like. They love clover. Parts of my yard are now white with clover blooms and I have to be careful when mowing so as not to run over bees.
Plus, wild stuff tends to grow less tall and dense, which means less mowing. Some parts of my yard only need to be mowed about half as much as others.
   / New Lawn for new house - looking for input and advice #39
   / New Lawn for new house - looking for input and advice #40
But that is Murphy’s Law in action.
You can not get grass to grow in gravel unless it is a driveway.
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
NEW Woods 6ft Finish Mower (A56438)
NEW Woods 6ft...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
2006 Ford Explorer 4x4 SUV (A59231)
2006 Ford Explorer...
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 TIELKE...
2009 Ford F-550 4x4 Ext. Cab Brush Fire Truck (A59230)
2009 Ford F-550...
