T-posts in hard ground - a hack
/ T-posts in hard ground - a hack #1
beowulf
Central California Foothills
Kubota L3410 HST, J Deere riding mower
I am in the process of cross-fencing a part of our property (T-posts and barb wire). The ground is a bit hard now (and the area is steep) and after pounding in about 15 of the estimated 90-100+ posts I will need, I decided that my 78 year-old arms and shoulders needed to find a better way. I started using my cordless drill with a 1" bit (the extra long ones) and along my string line I drilled down about 10" first for each post. Then pounded in the posts. I also brought out some water to pour into the holes but it was not needed. It still took a bit of effort but was so much easier. A smarter guy would have put the posts in earlier in the year, but that guy was late to the party.
/ T-posts in hard ground - a hack #4
Careful with the post pounding Beowulf, I tore a rotator cuff doing exactly the same thing.
recovery took forever.
/ T-posts in hard ground - a hack #5
Adapt and overcome. You have a challenging task. No way I could manual drive 100 T posts in any amount of time considered efficient. :(
/ T-posts in hard ground - a hack #6
X2 on the water hack. I even put a quart or half a gallon on the soil the day before pile driving 8"x8" posts. It makes a world of difference to dry clay soil, which is rocklike around here.
I can't wait to try the drill method for T-posts. Thanks!
All the best,
Peter
/ T-posts in hard ground - a hack #8
you didn't want to press them down with your bucket? also I have seen some people who bolt a spear on their bucket and they sink it in a foot or so then you put your post in the hole and press it some more with the bucket.
Very steep - no way to get a tractor near there - it was even hard to stand as I pounded.
Yeah - very challenging - without the drill hack I would have not gotten this far - I think I have about 55-60 or so in already. The good news is that from now on the ground is a bit more level - not level - just not so steep. I will get back at it in a few days. I need to pick up some more posts. And they are costing about $1.50 more per post (6') than I recall.
/ T-posts in hard ground - a hack #18
The one Agri-Supply sells is hundreds cheaper. I won't buy squat from Northern Tool, all their offerings are overpriced.
/ T-posts in hard ground - a hack #19
Draagging that pounder weighing 30 pounds plus the Tposts, beowulf would be exhausted. Jon
A standard t-post driver weights about 20 pounds so 10 more pounds and you don't have to repeatedly pick up and drop it. I think its a clear winner other than cost.
2005 JOHN DEERE 700H LGP CRAWLER DOZER (A64279)
2005 JOHN DEERE...
2019 John Deere R-4038 (A61306)
2019 John Deere...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
2015 IC Corporation PB105 School Bus (A61568)
2015 IC...
2356 (A64281)
2356 (A64281)
2016 Ford Escape (A61574)
2016 Ford Escape...
