T-posts in hard ground - a hack
/ T-posts in hard ground - a hack #1
beowulf
Central California Foothills
Kubota L3410 HST, J Deere riding mower
I am in the process of cross-fencing a part of our property (T-posts and barb wire). The ground is a bit hard now (and the area is steep) and after pounding in about 15 of the estimated 90-100+ posts I will need, I decided that my 78 year-old arms and shoulders needed to find a better way. I started using my cordless drill with a 1" bit (the extra long ones) and along my string line I drilled down about 10" first for each post. Then pounded in the posts. I also brought out some water to pour into the holes but it was not needed. It still took a bit of effort but was so much easier. A smarter guy would have put the posts in earlier in the year, but that guy was late to the party.
/ T-posts in hard ground - a hack #4
Careful with the post pounding Beowulf, I tore a rotator cuff doing exactly the same thing.
recovery took forever.
/ T-posts in hard ground - a hack #5
Adapt and overcome. You have a challenging task. No way I could manual drive 100 T posts in any amount of time considered efficient. :(
/ T-posts in hard ground - a hack #6
X2 on the water hack. I even put a quart or half a gallon on the soil the day before pile driving 8"x8" posts. It makes a world of difference to dry clay soil, which is rocklike around here.
I can't wait to try the drill method for T-posts. Thanks!
All the best,
Peter
/ T-posts in hard ground - a hack #8
you didn't want to press them down with your bucket? also I have seen some people who bolt a spear on their bucket and they sink it in a foot or so then you put your post in the hole and press it some more with the bucket.
Very steep - no way to get a tractor near there - it was even hard to stand as I pounded.
Yeah - very challenging - without the drill hack I would have not gotten this far - I think I have about 55-60 or so in already. The good news is that from now on the ground is a bit more level - not level - just not so steep. I will get back at it in a few days. I need to pick up some more posts. And they are costing about $1.50 more per post (6') than I recall.
/ T-posts in hard ground - a hack #18
The one Agri-Supply sells is hundreds cheaper. I won't buy squat from Northern Tool, all their offerings are overpriced.
/ T-posts in hard ground - a hack #19
Draagging that pounder weighing 30 pounds plus the Tposts, beowulf would be exhausted. Jon
A standard t-post driver weights about 20 pounds so 10 more pounds and you don't have to repeatedly pick up and drop it. I think its a clear winner other than cost.
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
UNUSED MINI HYD AUGER (A64280)
UNUSED MINI HYD...
2012 Peterbilt 337 G and H 8000 Container Handler Truck (A64194)
2012 Peterbilt 337...
UNUSED SDLANCH 25'X33' METAL SHED (A64281)
UNUSED SDLANCH...
UNUSED 4' X 300' ROLL ATS POWER GRASS PROOF CLOTH (A64281)
UNUSED 4' X 300'...
2013 Chevrolet 3500 Dually (A62613)
2013 Chevrolet...
