New Purchase
/ New Purchase #141
I would highly recommend going with a landscape rake with guage wheels for the drive way. I had a 5' Landpride LR1560 with the wheels on my B7800 and felt that it did really well on my gravel drive. The wheels made all the difference.
/ New Purchase #142
Congrats. I can see the logic in your choice of grading scraper, tractor and ZTR for your situation.
/ New Purchase #143
Dodge Man, I looked at and drove Kubota, Deere and Massey, thought I'd settled on Kubota. My neighbor suggested I check out Kioti.
Kioti? Made in Korea? Started looking on internet, saw a few bad reports but then noticed that the bad reports were several years old. All recent reviews were very good. Did a "build your tractor" type thing on their website and got sticker shock in a good way. I went and drove the CK and DK models and was very impressed. Would up buying the DK4510 and have been very happy with it.
Indy it sounds like you and I had identical tractor shopping journeys.
/ New Purchase
FYI, chatted with the Dealer some more today. I had mentioned my stability concerns when shopping and they were going to move the tires out to max width, but apparently they couldn't do that with R14s and I didn't want R1s for my application. We talked it over and he's going to add 3" spacers instead which I think is frankly a better outcome than the original plan anyways.
As for the L3302, I would have bought the L2501 but none were available. The dealer is crazy close to my house and has good reviews from the locals I've talked to so for now I'm just going to go with them and what they have. It's easy to get trapped in either an analysis paralysis loop or an endless series of justifications to get something larger. I get the L3902/L3560 argument but I'm just going to roll forward and see how it goes. If it turns out I chose poorly, then given the current market it should be pretty easy to upgrade.
Sticking with the bare minimum number of attachments for now, once I know more I suspect I'll end up buying additional ones. A brush hog seems likely, possibly others.
/ New Purchase #147
You will be very happy with your new tractor. Congratulations. You are going to find every reason in the world to use the tractor for everything humanly possible all the time.
Now you can start the addiction of spending thousands on all the attachments you are going to need and want.😁
/ New Purchase
Hah, I don't doubt it, who doesn't like playing with their new toys?
Well as long as we're waiting around for delivery, what are some other attachments I might want?
/ New Purchase #149
Pallet forks, my most used after the bucket.
Hooks, tool boxes and holders.
Lighting upgrades and add ons.
/ New Purchase #150
I think it will depend on what you are doing.
I would recommend upgrading to the heavy duty bucket. I have a lot of trees so I went with a 60" grapple from everything attachment, Land Pride RCR_2660 Rotary cutter, and a box blade from everything attachment. I would like to get a landplane for my driveway but can't justify the cost when the box blade will do the grading (but with more effort).
Some people recommend forks but I haven't yet needed it.
I would also recommend getting the rear remotes installed by dealer if you want them as well as bucket leveling rod indicator and third function.
/ New Purchase #151
I would start with those:
Box Blade
Grapple
4in1 Bucket
Bush Hog
/ New Purchase #152
A grapple:
/ New Purchase #153
You will not be sorry with the L3302, I think that's the sweet spot in the L-series.
Congratulations on the purchase.
/ New Purchase
I'm getting a Grading Scraper, a Box Blade seems redundant at least initially. Maybe I don't understand the difference enough?
Bush Hog is on my list, not sure I need it right away but I'm thinking eventually yes. Would allow taking down anything the ZT can't handle.
Grapple is very cool, I don't think I have enough uses to justify it right now.
Pallet Forks seem like they would be pretty handy, we already have lots of pallets around due to the hay storage. I don't move hay pallets much, but I could see doing a project and just throwing the stuff on the pallet, using the forks to lift it and take it to where we're going to work. You can use the bucket, but it would be somewhat less convenient.
Since we're getting a ZT I'm not sure a rotary cutter is that helpful.
/ New Purchase #155
Blue, as I said earlier you seem to already have a good handle on everything. Some members come on here and need a lot of hand holding, other members join and they are very self sufficient. You fall in the latter category.
/ New Purchase
Mostly just reading a lot and watching videos. I'm sure there will be plenty to laugh about when I first start trying to use the thing.
/ New Purchase #157
That's what you have to do so good job! (y)
There will always be that to but if you can't laugh at yourself every now and then then you're taking life a little too serious ;)
/ New Purchase #158
About 4 acres of it are in Horse pasture, main task there is putting in gravel on the muddy spots, the horses do the rest.
Congrats on the purchase, I'm sure you'll be happier with a bit bigger tractor in the end.
With regards to the horses mowing parts, they'll eat the yummy things, but leave all sorts of weeds and brush that will need mowed to keep the grass healthy (or at least mine do). My dry lots get too bumpy to use a ztr or lawnmower, so I use a bush hog (rotary cutter). General rule of thumb on rotary cutter is having at least 5 pto horsepower per ft of rotary cutter (ex. 4ft rotary cutter should be used with a 20 pto hp tractor or larger). I fence off my "lawn" and graze my horses in the lawn during daily turnout much of the year 'cause why run the mower when the ponies would like to eat it anyway. Might as well only mow the stuff they don't wanna eat.
I've found renting a legit backhoe or excavator is the way to go in my case. The three point mounted backhoes just aren't beefy enough to dig a 10 ft hole. I can usually get a horse burial dug by a neighbor on a legit backhoe for less than $150. Last time I rented an excavator to clean out the pond, it was $500 for the day to get one delivered that had tracks almost 6' tall on it... pond cleanout went FAST! (but that was a rarity since guy with that excavator sold it) -- little excavator can be rented around me for under $400 for the day.
As a horse person, the implement I'd think you'd want most is a ABI Dragmaster (also called a Kiser Dragmaster). I have one. I LOVE it, but you'd need a bigger tractor for using one. The profile blade on the dragmaster does an excellent job of getting rid of hidden "ruts" in your arena and pockmarks from the horse hooves. When we ride western, we dig up our arena deeper, but we also ride classical dressage (sometimes) and it helps immensely to get rid of the hidden ruts under the fluffy part of the arena footing. We have a sprinkler system to wet the arena footing to the right consistency, but we sometimes use the water on the dragmaster to "touch up" the middle especially when it's hot out and lots of evaporation is causing dusting during the middle of a clinic.
You might want a manure spreader. My personal preference for a spreader is a tiny thing that fits in the stall aisle (so it can be parked outside a stall and loaded directly when mucking out. They're ground driven so you can tow with tractor or with atv or lawnmower or side by side or golf cart. I have a huge PTO driven one, but frankly I don't think I've used it in over 5 years. Even if the horses mostly poo outside, you still end up mucking that out of the drylots, especially with stallions or geldings who still think they're stallions and make poo piles to mark their territory.
For maintaining the driveway, I'd look seriously at a landplane. I very very seldom use my boxblade on the driveway since it's quite damaging to the compacted base if you're not careful. I use the landplane a few times a year (basically every time you notice some ruts get the landplane out and do the drive way BEFORE it gets bad). I prefer a 10' landplane for driveway maintenance but that would be too much for your tractor.
If you have to clear out ditches, I'd look at a six way hydraulic blade that's at least a couple of feet wider than your tractor (so you can angle the blade and it'll clear out the ditch past where the tractor tire is... if the blade is the same width as the tractor, then you'd need to drive in the ditch to clean it out).
My splurge item might be a snow blower or a three point wood chipper. I don't have a snowblower since I moved to TX, but I really wanted mine back in Feb 2021. Yes, you'd only use it once every ten years, but depending on your driveway, your vehicles, etc it can make a pretty big difference in escaping down the driveway when you get a random snow of 12" that isn't supposed to happen. If you're comfortable driving on compacted snow on the driveway, then you can always just take the 4WD tractor for a few up and down the driveway trips and mash the snow down, but that leaves compacted snow that makes slick ice if you're unlucky. The wood chipper makes fallen trees disappear into itsy bitsy chips that can be spread around pasture to decompose naturally so they don't have to be burned or otherwise disposed of...
Red Oak Boards (A65640)
Red Oak Boards...
2004 Chevrolet Silverado 1500 Pickup Truck (A64556)
2004 Chevrolet...
2001 Club Car Carryall 6 Medical Utility Cart (A64553)
2001 Club Car...
Club Car Golf Cart (A66285)
Club Car Golf Cart...
2019 FORD F350 4X4 PICKUP TRUCK (A59914)
2019 FORD F350 4X4...
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
