New Purchase
/ New Purchase #1
blue9steel
Kubota L3302
I've recently purchased a six acre horse property. Previously we were at boarding facilities but now with our own land I'm going to need equipment in order to take care of the numerous other property maintenance tasks. Definitely not something I want to try and handle with a push mower, wheelbarrow and a shovel, heh. The property is on a hillside with about a 200' elevation change from bottom to top, so there is some slope to work with though it's nothing too serious. Rough guess and an online calculator says 17 Degrees but I'm not sure it's actually quite that bad, that's likely worst case. I'm a first time tractor buyer and it looks like the only close tractor dealer is Kubota. I've done some preliminary research online as well as talking to the contractor who put in our perimeter fence about what kind of equipment to buy but I'd like to get opinions from you folks. Deciding between a BX, B, LX or L series tractor isn't an easy choice. I've tried to lay out everything in terms of capabilities:
NEEDS
1. Mowing all the non-pasture areas, maybe 2 Acres worth. Possibly also some pasture mowing if they sit too long unused.
2. Moving gravel. We have decent drainage since we're on a hill but it's Western Oregon and we get a lot of rain. Add in big horses and you get mud.
3. Maintaining the steep gravel driveway. Need to smooth out ruts and keep it drivable.
4. Some ability to deal with snow so we can get in and out of here in the winter. We don't get a ton of it, but it's enough I need at least some capability.
WANTS
5. Ability to level areas and maintain walkways for the horses.
6. Some digging capability would be nice for drainage work, planting trees, etc.
7. Ability to deal with stumps or large rocks
OPTIONAL
8. Ability to drag the Outdoor Arena
9. Likely need to be able to drag a horse shelter to a new spot, though we could rent / pay someone as that is an infrequent task.
10. No woodlot but we do have fruit trees so there are maintenance tasks in terms of planting, pruning, etc.
11. Digging post holes for fencing. Our current setup is good and I could hire this out, but it would be handy.
12. A wood chipper to deal with tree limbs and other wood waste.
Hopefully that's enough info to get the conversation started.
/ New Purchase #2
Congrats on the new place.... sounds like a beautiful setting. Where are you located? Lots of snow, or very little?
/ New Purchase #3
A big B at least.
You failed to mention $$$$$ and new or used.
Digging almost requires a backhoe, a 5 to 15 K option.
Right now even used are expensive. Pre pandemic used could be bought for a little less, now even older tractors are expensive.
/ New Purchase #4
I have had dealers call wanting to buy my 2008 CX105 and say they'll pay more than I paid for it two years ago. I'm keeping it !
/ New Purchase #5
If you don't have much prior personal experience operating a tractor, it makes it that much more difficult to figure out what you really need.
I'd think you'd want a loader to move gravel and manure. Would you be moving large round bales? There may be a certain amount of weight to what you plan to move that steers you towards certain models and away from others. Look at the weight of what you plan to move and then look at the loader capacity of the models that interest you to narrow your choices.
4 wheel drive/Ag tires for the mud, IMO.
Landscape box (some call it a box blade) for the driveway maintenance.
PHD for fencing.
Land plane/drag-but I will leave it to others to say if you can maintain your drive with the same attachment used for your arena. I would tend to think the box blade would be better for rougher work.
Backhoe for trenching and stump removal or consider renting a unit from time to time.
Cab for the snow? Snow blade or blower? Suggest you use the search tool here and start reading the snow removal threads.
Kubota has a nice equine discount for Kubota branded equipment for members of the National Cutting Horse Association. Your dealer may or may not be familiar with it, and you may have to educate your dealer to get the discount. Kubota financing might sway you in a different direction. It depends on your own situation which is best.
New prices are a lot especially if you buy all new attachments.
/ New Purchase #6
After my recent experience with Kubota I can tell him he will need that discount. Forget about the financing.
That is the most backwards, pathetic thing I have ever heard someone say in regards to doing business with someone who's business it is to know that in the first place. I thought the auto industry took the cake for being substandard but this is hitting new lows.
/ New Purchase #7
I would say you wouldn't want anything less then an L series. Reason being is you need adequate weight to maintain gravel driveways. I had a conversation with my local dealer last year and he told me that if I wanted to get real work done don't waste my time with anything less than an L series tractor.
Then that is who and what you need to go with unless he gives you reason not to.
NEEDS
WANTS
OPTIONAL
I have to hand it to you, you did a good job of thinking this through so far. Keep up the good work and research you're doing and if you haven't come across this thread then I recommend you read it:
/ New Purchase #8
If you are going to handle roll hay, you have to be able to lift and stack them. So the loader lift height and weight is needed. List the attachments that you will need and then match them with the tractor hp and size. Most small tractors will do most work, but the ability to stack hay is only for the larger one. Also, the size of the mower. Take you time and do your test drives. I run an LS XR4150, with back hoe, loader, and a lot of attachments. I have 6 horses, 4 ponies, and feed round bales, 4x5. The size of the rolls also make a difference. More weight, more power. Local dealer support is something, that you may or never need. For new owners, I think it is important. My son's 26hp Mahindra tractor can do a lot of things that I can, but can not move the hay and due to size his tractor can only mow about half as fast.
/ New Purchase
Ok, tried to address all of the above comments. I appreciate the feedback.
Location is Saint Helens Oregon. Elevation is around 350' but we get some wind coming up the valley from the coast so snow is more than normal for Western Oregon. Still, even with that, It'll likely be less than a foot at any one time. I need a small capability just to clear the steep gravel driveway enough so our 4WD vehicles can make up and down safely. Not sure if that means a snow blower or just a blade.
Money is flexible. I can afford whatever I decide on, but it's only six acres, no need to go crazy. I'd prefer to finance rather than pay cash for such a large purchase. My day job is incredibly busy so I'm planning to buy all new. I don't have a lot of time to spend wrenching on something used, at least not right away.
So far I think I need for sure an FEL, a mid-mount mower and a grader. I think a backhoe would be very useful, but not mandatory. PHD can probably wait. Given the amount of work I plan for what is essentially a hobby farm I think I can do without the cab and just get a canopy, rain being the most common weather issue. Not sure if I need a front blade, back blade or both.
I'm sure I could sign up for one or more horse associations in order to get the discount, not sure if that's the right approach or not given that it seems to impact the financing and warranty. Still, online reports seem to suggest a possible savings of 5%-10% over standard dealer incentive.
If I had a bigger place I'd probably get an L series, but I do need mower capability and it seems silly to go with a rotary cutter just for my 2 acres worth that aren't horse pature. I'm not sure I really need something that large. Frankly, if I didn't need to move a ton of gravel and grade the road I might try and get by with just a riding lawn mower, even though all the other tractor features will be handy for sure.
The local Kubota dealer is in town, so just down the road 10min or so. There are other dealers 45min-1hour away but it doesn't seem like it's worth that drive unless it turns out I don't like the dealer.
No need to work with roll hay, honestly I wasn't even aware they had any horse grade hay that came in rolls, the only roll hay I've seen is for cattle. We work exclusively with bales, preferably the 60lb granny bales so my Wife can move them around. We get about 350 bales a year for our two warmbloods, but will get more than that this year as we're going to be doing boarding for one other horse. Still, that's usually delivered and sitting in the barn, not a huge need to move it around much. That said, with the driveway we may not be able to get delivery as easily as both and may need to transport it here on a flatbed ourselves. I don't think I'll be buying anything big enough to move fully stacked pallets.
Local dealer apparently has some B2601s and an LX2610 in stock so I'm going to be looking at those likely this weekend to see if either would meet my needs. I suspect the bx23s is probably too small given the hilly terrain and the L series is likely more tractor than I need though I'll look at it while I'm there if he has any. Originally I was thinking an LX3310 might be a good choice but I'm sure if I need that or not.
/ New Purchase #10
Question for you. Is your wife going to be operating the tractor? If so, take her when you go shopping. I had a couple come in one Saturday looking for one for their horse setup north of Flagstaff. After taking with them, I suggested either a B series or an L series Kubota. I had them both operate each in the demo area. He on the L as her on the B. They then switched tractors. After a bit of time on each, the brought them back into the yard. I walked up to them and asked what they thought. The wife pointed to the L series and said "that one". I asked why and she said that she could see in front better and since she would probably be using it more to feed with she wanted it. I delivered it that afternoon.
/ New Purchase #11
I would just bite the bullet and go with the L3901 if you don't need a cab. Maybe look at the 02 series in this model. I wouldn't mess with a mid mount mower and just get a zero turn for mowing.
When I first tractor shopped I kept hearing the saying "Buy one size of tractor greater than what you think you need". How true that was for me.
Definitely use the NCHA membership to get 20% off the tractor and implements. NCHA
I sold my L3301 to a a guy with horses before I upgraded to my MX5400.
/ New Purchase #12
One of the main reasons I bought a tractor in the first place was living on top of a steep hill and having to maintain the gravel road on it.
If you have a steep driveway where the gravel tends to wash down the hill and you find yourself having to drag it back up, then the weight of the tractor, HP, and 2 WD vs 4WD start coming into play. In this application, I would lean towards an L series.
It has also been my experience that a rear box blade is the easiest attachment to work a gravel driveway because it holds the material in the box and is pretty self leveling compared to a rear dirt blade which, IMO, requires more skill to get the material where you actually want it to be.
You might could move some snow with a rear dirt blade, but not so much with a rear box blade.
Ask or search for recommendations in the snow removal forum. I tend to think the preferred approach will be to have a front snow blade and another rear mount attachment for gravel maintenance.
/ New Purchase #13
In stock? As "not sold" or just available to try out?
That's a key point because I read on here LONG wait times in some areas.
The BX23 would be good, if you had a large barn and wanted it for clearing stalls :) But I'm pretty sure it wouldn't be good for the rest of your uses.
/ New Purchase #14
Another consideration is that you'll probably get a lot of use out of the FEL in moving wet manure. You can get tire ballast, but in my experience, you'll also want some implement on the rear hitch for more stability. Instead of investing money in a ballast box, I tend to think that money is better spent on either a box blade or a rear blade in many situations.
/ New Purchase
You know, that's a pretty good point. I'll keep that in mind.
/ New Purchase #16
It’s so easy to spend other people’s money. 😉 A Kubota B series is plenty. I maintain 52 acres of very hilly, heavily wooded ground and 1400 feet of steep driveway with a 33 HP Kubota. Outsource any major earth moving. A compact tractor is not a dozer or an excavator.
/ New Purchase
The L3901 seems like an awful lot of tractor for my use case. Buying both that and a Zero turn mower is going be a large chunk of change. Other than "bigger is better" I'm not sure I understand the justification for that.
So far, gravel washing to the bottom hasn't really been an issue for the driveway, it's more about ripples, potholes and other forms of unevenness that occur over time as people use it.
Good question on the "in stock" comment. I'm not totally sure, I'll find out later this week when I go in to chat with them.
I do expect to move some manure around, though mostly just managing the compost area. Our horses spend most of their time outdoors in the pasture.
/ New Purchase
I'm on the fence as whether I should get the backhoe or not. It seems like it would be really useful, especially with a thumb, but it's not exactly a cheap attachment.
I need a tractor that covers 90% of what I need, everything else can be hired out.
/ New Purchase #19
I’ve needed an excavator maybe 4 times in the last 14 years and I either rent or hire it done. I don’t want to tie money up in stuff that won’t be used a lot, and to be honest, usually I need a bigger bucket than I could afford to buy.
/ New Purchase #20
Weight and engine power.
I’m actually going to recommend you take a loo at the MX as it’s larger size will help with stability in your terrain, it is larger than the L but not really taller so you’ll also have more stability there, and if you plan on feeding rounds or large squares you’ll have way more confidence moving and stacking with the weight of the MX and the 1065 (~2300lb capacity) fell than you will with the L and it’s 525 (~1100lb capacity). Just because it will lift an object doesn’t mean it won’t prematurely wear out carrying it around and bouncing through a field or down a dirt road.
ETA, when the end comes is also a consideration. MY MX has buried several horses and a few cows for neighbors. They aren’t easy to move either, especially the horses. Just like many things with a tractor, you won’t really know what all you need it for until you start using it.
