Gravity ... who needs it?
/ Gravity ... who needs it? #1
Diggin It
Super Star Member
I'm thinking, I'm thinking!
LS MT125 TLBM
Apparently not this tree.
Well passed 45 degrees and has been for quite some time. Was told it's a Sycamore. Shadow under it hides the exposed roots and nearly complete lack of ground, having been washed out during higher waters. Fairly tall, at least 30', so there's got to be an awful lot of leverage at work.
/ Gravity ... who needs it? #2
This is a weighty subject. Looks like the trunk is right in line with that mass of rocks, causing a small, local diversion of gravity to a new angle.
I most often experience gravity fluctuations when shooting, causing a miss. This seems to be a steady situation.
Bruce
/ Gravity ... who needs it? #3
I've noticed that gravity has been steadily increasing over the last 30 years or so.
That tree must have a darned good root system leading away from the stream, to hold it up that well. I couldn't tell from the picture; is the top hung up in the other trees?
No where near. Out over open water.
A week ago, the water was up over the base of trunk completely. Three weeks ago, all of the rocks were submerged. Water is still a bit higher than 'normal.
/ Gravity ... who needs it? #5
By the looks in back ground more trees are feeling gravity pull.
/ Gravity ... who needs it? #6
I like gravity, it keeps me from flying off the planet (most of the time).
Be careful if you try to take it down, as removing weight will likely have it set back on the stump.
We had some storms after heavy rains about 7 years ago when I was back in NJ. Had lots of trees do this, as the ground got soft and the trees just fell into the lean. Looked weird seeing the many stump bottoms sticking up all over town and in the local county park.
/ Gravity ... who needs it? #7
Gravity who needs it? Have you looked at the towing things wrong thread, some people count on gravity a lot. I joke and say “gravity, natures tie down”.
/ Gravity ... who needs it? #8
Never mind that, just read the "aliens" thread just below this one. Gravity isn't real, and the world is flat. :eek:
/ Gravity ... who needs it? #11
You just wait until the pull of SUNSHINE takes effect! That tree is gonna suffer "the Bends"!
/ Gravity ... who needs it? #12
Gravity has been increasing since I was a teenager. Back then my scale said I weighed 120#. Now it says 160#. I’m still the same person so gravity must be increasing 😂
/ Gravity ... who needs it? #13
That's my argument, also... although if mine said 160 I would be in a lot better shape.
Maybe it's time for some new scales... :D
/ Gravity ... who needs it? #14
And somehow the ground is getting further away.
/ Gravity ... who needs it? #15
I have witnessed a conspiracy where new scales are made to mimic the ones we are replacing. Somehow, they manage to make the new ones read the same as the old ones. :eek:
/ Gravity ... who needs it? #16
Here is a cedar that defied gravity for many years:
I finally pulled it:
/ Gravity ... who needs it? #17
Yeah it’s flat. Ever been to Kansas?
Yep. I'll never forget the feeling of pulling into a wheat field, one mile square, with a 14 foot Gleaner combine. Goodland Kansas, or thereabouts as I recall...it has been over 50 years, but some of those memories remain.
/ Gravity ... who needs it? #18
View attachment 739956View attachment 739957
I find it a little sad that you pulled it, but I have a soft spot for weird trees. They seem like a testament to Mother Nature's adaptability and persistence to survive.
Here is an odd tree at my place that is still alive. Most of the leaves are on the small section that sticks out from the edge of the woods.
Here is another one that developed a major horizontal branch right at ground level for some reason.
/ Gravity ... who needs it? #19
Yep, I understand, but around here cedars grow like weeds and are a wildfire hazard.
That reminds me of this cedar:
But it also got pulled and put on the burn pile:
/ Gravity ... who needs it? #20
Indeed. Cedars are a fire hazard in rural areas; I removed several from my acreage years ago. There are a lot in my area; my guess is that it is the result of the early settlers clearing the land for pasture and cultivation, and the regrowth is dominated by cedars, all about the same size and age.
2025 HT360W Mini Stand-On Track Loader Skid Steer (A64553)
2025 HT360W Mini...
KUBOTA KX033-4 EXCAVATOR (A64279)
KUBOTA KX033-4...
2015 Ford F-450 4x4 Crew Cab Landscape Dump Truck (A64556)
2015 Ford F-450...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2018 Ram 1500 4x4 Crew Cab Pickup Truck (A64556)
2018 Ram 1500 4x4...
20ft T/A Utility Trailer (A64557)
20ft T/A Utility...
