Kioti Grapple Buyer beware!!!!
/ Kioti Grapple Buyer beware!!!! #1
BCT235
Bobcat CT235 hst
Hi all. First Post here. I am kinda new to the Tractor game. I First had a Bobcat CT122 then upgraded to a 2009 CT235, i love the tractor perfect size and power for what i need.
I purchased a Brand New Kioti Grapple they just came out with last fall. First off i was really supprised it would not fit my Bobtach system. i had to Make some significant grinding to get it to fit flush. I called the dealer i purchased it from and he said this is normal on new to old equipment, so i went with it. It is a Kioti dealer i purchased this from fyi. So now just got the Chance to really use it, the Power company came by and made a mess under the power lines so was clearing some Small logs, and some large mulch from the brush crusher. After 5 hours of use, one of small tines the top section of the grapple busted off.
Ok So i just sent a nice message to customer service at Kioti. Saying how much i like the grapple and explained the same things i just laid out here. Wow was i really surprised at the response i got. i will share it. and some pictures i have of the grapple.
as stated im new to this kind of thing so was posting to see if this is normal for most other equipment manufactures or not?
Here is what Kioti sent me. I sent them back i will NEVER own another piece of there equipment again if this is the way i will get treated.
Luke,
Thank you for contacting KIOTI Tractor. KIOTI does not recommend the instlallation of KIOTI implements on any equipment that is not manufactured by and specifically for a KIOTI.
Unfortunatly, KIOTI will be unable to provide product support in this situation.
Regards,
[IMG alt="Logo
Description automatically generated"]https://apis.mail.yahoo.com/ws/v3/m...n&downloadWhenThumbnailFails=true&pid=2[/IMG]
DAEDONG-USA, INC.
KIOTI TRACTOR DIVISION
Steven Hopper
Customer Relations
6300 KIOTI Drive Wendell, NC 27591
877-GO-KIOTI
KIOTI.com
/ Kioti Grapple Buyer beware!!!! #2
I understand their position, but this appears to be a manufacturing issue that should not be dependant on the equipment it is mounted to. I'd push on the dealer for a warranty issue, but then they'll probably claim you modified the grapple to make it fit. Kind of why I like 3rd party equipment, if the equipment is stated to work on a particular brand of tractor then the manufacturer has to stand behind their product without weaseling.
/ Kioti Grapple Buyer beware!!!! #3
Looks like a weak spot from the design of the parts as they were cut. Likely the assembly welder was supposed to weld past that joint and didn't get the memo.
I'd forget about the dealer and just weld that piece back on. You will need to weld past that spot on all the other tines as well. That is a weak spot on all them.
Then maybe look over the rest of the design and see if there are any other similar issues.
/ Kioti Grapple Buyer beware!!!! #4
From what I understand, Kioti makes the tractors for Bobcat, but Bobcat sources their own loaders.. That said, SSQA is a standard and you should not have had to grind on anything to make it fit. Who was at fault for that is another story though.
2nd, Kioti should absolutely stand-by their product no matter what tractor its on (as long as its 'reasonable use') and replace it or repair at least the upper.. Keep pushing the dealer you bought it from to make it right.
/ Kioti Grapple Buyer beware!!!! #5
Thats AR400, not sure if he'd have the experience to do it correctly.
/ Kioti Grapple Buyer beware!!!! #6
Who knows. I'd make sure what steel it was before any welding. If it is AR400 most any diy welding guy can easily weld that piece back on, weld the other tines and check for any other issues.
I'm a problem solver. This gets him back in business instead of fussing with an incompetent company.
Right off Lincoln's site:
AR400 is a quench and tempered steel and may be difficult to weld due its high strength and hardenability. The base steel around the weld rapidly heats and cools during welding, resulting in a heat affected zone (HAZ) with high hardness. Any hydrogen in the weld metal may diffuse into HAZ and may cause hydrogen embrittlement, resulting in delayed underbead or toe cracks outside of the weld. To minimize heat affected zone cracking:
  • Use a low hydrogen consumable with an -H4 or -H2 designation
  • Preheat to slow the cooling rate. Note that excessive preheat may anneal the base material
  • Slow cool. More time at elevated temperatures allows the dissolved hydrogen to escape
  • Peen the weld beads to minimize residual weld stresses
  • Use the lowest strength filler metal meeting design requirements. If making fillet welds, the weld can be oversized to give the specified strength
  • Minimize weld restraint
/ Kioti Grapple Buyer beware!!!! #7
boy that sucks that it broke and sucks even more manufacturer will give you no consideration. Hopefully your dealer can come through for you.
IMHO I think you have right to be an unhappy camper. I know I would be.
good luck and interested to know your final outcome.
Thanks for that! and all the responses. I had to grind a support in the top frame as my Bobtach was wider than new ones i guess, also had to grind at least 1/4' or more oval out of it where the handles attached so it wit sit flush.
Was waiting for warmer weather and to get my 240 plug installed for my hobart 210mvp. i have experience on 115v so should not be a problem with the welding. I will as stated by a few defiantly put some gussets on those other tines just to make sure.
Other than that its a very nice Grapple, i will try and get some other pictures up. the originals were to large.
I did my research and watched tons of videos, i did do some back dragging with the top, and i always had the top fully extended not to put pressure on the rams. and always went straight back, no turning. Maybe just a week spot in the metal?
Oh and Yeah and i will tell him this is a Kioti tractor!!
Other than some oversized brush this is what i have used the Grapple for. I did move some small rocks, but they fit inside were not on the tines.
/ Kioti Grapple Buyer beware!!!! #10
I'm surprised, dismayed, that Kioti would not back their product.
/ Kioti Grapple Buyer beware!!!! #11
Just part of owning a grapple you will find all the design flaws and get practice welding. I agree it's frustrating when you pay for something and it's not 100%. Just remember rocks and concrete are really rough on stuff and require alot of maintenance.
/ Kioti Grapple Buyer beware!!!! #13
I looked for two years before I decided on the grapple I wanted. Land Pride 1560. 60" wide - 820 pounds of steel. I've had mine for ten years now. Not a moments problems. Used almost 100% to move really large rocks and lengths of Ponderosa pine trunk. Ten years ago - WR Long third function + Land Pride 1560 - dealer installed - - $4750.
/ Kioti Grapple Buyer beware!!!! #15
60'' EA wicked grapple 400# of the best made grapple on the market.
@400# it doesn't kill your lift capacity.
You happen to break it, (which is doubtful) and they'll fixe it !
I dug this boulder out of the ground with this wicked 60
/ Kioti Grapple Buyer beware!!!! #16
Hi oosik. Did you fab that metal mesh in your front guard yourself? Was just thinking I want to do that on my Bobcat.
OP, that was a poor response you got from Kioti, and almost disingenuous on their part, for not acknowledging the close relationship between them and Bobcat product, even if different loaders. Sucks, hope you get some satisfaction from dealer.
/ Kioti Grapple Buyer beware!!!! #17
Send a link for this thread, to Kioti, and your dealer. And if you are on any social media sites (FB, etc.), see if there is a group there, and post up Kioti's response.
If this is how they treat their customers, and what they think of their own products, let others know. There are better choices, not just for grapples, but tractors.
/ Kioti Grapple Buyer beware!!!! #18
wisconsitom - I took the OEM frame to a local welding shop. A young fellow, there, did the work. It's saved my bacon, at least, a couple times that I know of.
If you weld and have access to expanded metal - easy project.
/ Kioti Grapple Buyer beware!!!! #19
That's like an truck manufacturer voiding a powertrain warranty because you install a bed cover. I can't see any reason for this unless Kioti tractors run a low hydraulic pressure and they're assuming you hooked it up to a higher pressure tractor and screwed it up that way.
/ Kioti Grapple Buyer beware!!!! #20
Thanks oosik, very cool. I've often thought it would be too easy for pokers to get by the big bars on my guard.
Does this diminish your headlight power/usefulness much? I've got different tractor but like yours, added material would be in line with lights. Thanks
24in pin on excavator tooth bucket (A61307)
24in pin on...
2001 INT 4900 DT 530 (A62679)
2001 INT 4900 DT...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
2014 Caterpillar 308E2 CR (A64126)
2014 Caterpillar...
HEIN-WERNER 1TON TRANSMISSION JACK (A65643)
HEIN-WERNER 1TON...
SKID STEER VIBRATORY ROLLER (A62613)
SKID STEER...
