Steering wheel knob placement
/ Steering wheel knob placement #61
Most newer tractors have hydrostatic power steering and the steering wheel will not remain in the same position. Your profile does not show what tractor you have so it's unknown if you have such a tractor. You can still put a knob on, just be aware that it will not remain at the same position.
So yes, it will move around. Here's 2 things I found about that:
A) You could minimize that by not turning your wheels to full lock and then holding your steering wheel in that position....because if you pay attention your steering wheel will continue to slowly turn in such a case.
B) If you find that suicide knob not where you want it, well you could use the "A)" up there to get it where you do want it. So, make a note how far out of position the knob is. Then turn your steering wheel to full lock, and gently keep holding it as it slowly turns the distance that you noted, which will bring the knob back to where you want it at.
/ Steering wheel knob placement #62
Everyone has their own opinions but I wouldn't be without my "suicide knob" when I'm sitting sidewise and blowing snow in reverse. Makes the work so much easier. As to it "floating" or changing position, GeneV covers that in his post, it's how I reset the position of mine. IMHO it's a worthwhile addition.
/ Steering wheel knob placement #63
The higher quality spinners don't have any exposed metal View attachment 734367
TSC sells the same spinner under its County Line brand for $17 (pic below). I have one on each of my tractors, even the GF 1800 front deck mower. They make maneuvering much quicker. Especially good for loader work, with one hand free to operate the joystick. For folks who are skeptical, I say try one. I bet you'll agree! :)
/ Steering wheel knob placement #64
If I had a Tractor Supply anywhere nearby that would have been the way to go. My nearest one is either 200 miles west or 200 miles east. Or there is this at $13.
I'm ordering one for my other tractor.
/ Steering wheel knob placement #65
unfurl="true"]https://www.amazon.co
Yep, that looks like exactly the same thing. That Amazon price is about what I paid at TSC when I bought mine a few years ago!
/ Steering wheel knob placement #67
Check at your local Auto Parts Store.
/ Steering wheel knob placement #68
I put a speed knob on my John Deere 4320 compact when I first bought it 16 years ago. I wouldn't be with out it. It makes the tractor more maneuverable quicker. The position does move around. I mounted it on one of the spokes of the steering wheel. It is slightly canted inboard. That leaves the rim of the steering wheel still accessible. It just takes some time getting used to. The biggest problem I have is when wearing a long sleeve shirt, I sometimes get my sleeve caught over the knob.
/ Steering wheel knob placement #69
/ Steering wheel knob placement #70
I just can't use one. I'm so used to operating without it it feels wrong. It just gets in my way if it's there.
With hydrostatic steering and hydrostatic transmissions there is really nothing that demands having a steering wheel at all. It is only tradition and probably a few dollars in added cost that keeps it there. I would be perfectly fine with a new tractor with full joystick controls.
/ Steering wheel knob placement #72
My Ford stays in the same orientation. It has a power assist steering box like the old cars. I have my spinner mounted in the three-O-Clock position and can move the knob up and down with my right arm for minor steering corrections. Or I can wind it vigorously when turning. I like mine. I usually hold onto a stainless steel handle I put on the left fender. I hold that handle with my left hand in rough ground. Helps keep me square in the seat.
/ Steering wheel knob placement #73
I put one at 3 o’clock and other @ 9 o’clock. Keeps left hand steering in a comfortable position as right operates attached implemen.
/ Steering wheel knob placement #74
I don't honestly see the purpose of using one of these. With the power steering I can turn the wheel with just the heel of my hand and I never need to hold it tightly. So I'm turning my wheel as if I have a knob, but don't.
Another reason is that like others have said, with the hydraulic steering it will usually always be anywhere but where you want it to be.
These things were invented before power steering and gave you extra leverage to turn the wheel. They were called suicide knobs because they could catch in clothing or break causing you to loose control of the vehicle in a turn.
/ Steering wheel knob placement #75
Would be interesting to know what percent of tractor owners on this forum have a spinner mounted to the steering wheel ?
For about 30 years I drove a tractor-snowmobile trail groomer, there was one other driver that would always install a spinner when he drove and I hated it so always removed it but it was one of those spinners with the metal frame work.
So after reading here about the plastic frame spinners bought one at tractor supply yesterday, if still don’t like it I will hopefully be able to return it and get the $16.99 back.
/ Steering wheel knob placement #76
I find it more convenient to grab the knob than steer with the heel, personally.
/ Steering wheel knob placement #77
If you are using one in cold temperatures a gloved or mitten covered hand will grip the spinner more securely than the palm of a glove or mitten on an open station tractor.
I operated a forklift (Hyster 225) at a lumber mill for about 5 years and palmed the steering wheel a lot. I had a ground in black stain on my left palm that took a week to fully go away after the mill shut down. It was 35+ years ago.
/ Steering wheel knob placement #78
I never thought about winter and gloves, but I'm not doing a lot of steering in the winter, mostly straight lines moving snow.
:p In another life I spent a lot of time of forklifts as well.
/ Steering wheel knob placement #79
Everybody gets a choice!
My wife didn't like the spinner on the lawn mower...so I took it off the Craftsman.
I would mow fields with the tractor / bushhog, while she was mowing the lawn. Worked good for about a month.
Then she put in her two week notice...
Guess I need to put the spinner back on (or else go get a new Zero Turn!!!)
/ Steering wheel knob placement #80
When I finish putting the power steering cylinder on my Yanmar YM2310 I was planning on putting a spinner on the steering wheel. They make steering easier for me. But all the ones I looked at stuck up too far and catch on things. Then, after looking at these posts, I looked again for spinners. And found a low profile one that looks like it will work great. Here's a link:
https://www.amazon.com/LRANFOW-Stee...ing+wheel+spinner,automotive,123&sr=1-16&th=1
So, if the thng will clamp on the wheel then there will be a low profile spinner knob that won't catch on clothes and that can be palmed.
Eric
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
2005 Oskkosh MK48A1 8x8 Articulating Tactical Truck w/ MK14 20ft. Flatbed Container Hauling Trailer (A66736)
2005 Oskkosh...
2015 Ford Transit Connect Cargo Van (A64556)
2015 Ford Transit...
2005 INTERNATIONAL 9400I (A67714)
2005 INTERNATIONAL...
2013 BIG TEX T/A UTILITY TRAILER (A67714)
2013 BIG TEX T/A...
