Pup trailers
   / Pup trailers #101
Do you use side dump trailers in North America ? As said before, we dont see them in Holland because our law allows 50 ton rigid truck GVW, but in Eastern Europe i see them a lot:
   / Pup trailers
Of course we do lol….we arent a 3rd world nation…..(YET)
I saw a lot of them being used in Western states I visited in summer of ‘21 on a large road building project. They were the “tub” type rounded inside corner type dumps.
   / Pup trailers #103
It often depends on where you are, what kind of trucks and trailers are popular. In the western states, belly dumps are very common. As you get closer to the West Coast, you see more side dumps. In the Midwest, you see lots of end dump trucks pulling trailers. But, you can see about anything being used if you look hard enough. Railroad contractors often times have end dump trucks with a turntable so they can dump to the side.
   / Pup trailers #105
We had several of the type Hay Dude posted. One driver was injured driving one once. He was hauling large quarried rock, eight to twelve rocks per 60,000# load. He was supposed to wait for an excavator to sort of curl over the top and act as a sort of roll over guard. He didn't and the off center load flipped the truck before the rock started to move. He had taken off his seat belt and got thrown around a bit in the cab. The only damage to the truck was some scratches and a broken mirror. Last I heard, he is no longer driving.
   / Pup trailers #106
Pretty simple - apply the trailer brake handle (johnny bar) and the brake lights come on - which begs the question: Have you ever driven an American truck on American roads? Or are you just speculating?:unsure:
Uh, not every tractor has a trailer brake handle. At least none of Old Dominion's trucks did when I drove for them back in 03'-04'.
   / Pup trailers #107
I never saw a truck equipped to pull an air brake trailer that didn't have one. Those must have been special order.
   / Pup trailers #108
It’s an option when ordering a truck.
   / Pup trailers #109
I know these, but this isnt a rigid truck with a pup trailer...
   / Pup trailers #110
My F-750 doesn’t have one. Then again pulling a trailer wasn’t it’s main purpose.
   / Pup trailers #111
I have not seen a truck and pup side dump in the Pacific Northwest. When that is needed there are plenty of the side dumps semi-trailers around to do the job.
   / Pup trailers
Not sure if ive seen one around here in the East, either…
   / Pup trailers #113
You dont see North American style side or bottom dumps here either.
By far the most common construction semitrailer is the conventional 3 axle rigid configuration with a 4x2 truck pulling it.
In Germany you will find 2 axle trailers with a 6x4 tractor, and in Holland you will find a 6x2 truck with pusher axle in front of the 3 axle trailer, to utilise the max combined weight of 50 ton.
Another method of utilising (close to) the max combined weight of 50 ton is to set the trailer axles more than 1.80m (6 feet) apart so 10 instead of 9 ton per axle is allowed, without exception with forced turntable steering on the 1st and last axle. This puts you on 49 ton Gcvw with a regular 4x2 truck in front.
   / Pup trailers #114
In North America, the cabover has pretty much gone the way of the Dodo bird. There are still a few around but they aren't at all common. Europe and North America are different in their approaches to trucking because of their different needs. Very little in the US or Canada is much over 150 years old and especially in the west, we have space to spare.
   / Pup trailers #115
Ya, interesting how things evolve. Lots more room in the US in cities & on roads. So we don't prioritize compactness like Europeans do.
   / Pup trailers #116
Speed limits and aerodynamics play a large role, as well. Many interstates in the West have 80 MPH limits. That means traffic is usually exceeding that speed.
   / Pup trailers #117
Any advantage in aerodynamics of bonneted American trucks is nullified by air filters, steps and other parts sticking out. And the gap between cab and trailer is a source of wind drag too.
   / Pup trailers #118
With rock, asphalt or sand, you dont need the length to get your payload, so its better to keep them short, which lessens the risk of overturning when the box is upright to unload.
Scania and Volvo made bonneted trucks on and off, mostly they alternate a generation because whenever either of the two starts making them again, they sell a few extra trucks to enthusiasts, but that effect wanes after a year or two so they stop selling them the next truck generation.
Even with space to spare on roads and industrial estates, when i see Ron Pratts recovery channel on youtube, its often a truck that couldnt make it through the corner on a residential building site delivery.
Good point about places being 150 years old, there are a lot of lanes in my area with big old oak trees on both sides, planted in the horse and wagon era. Those trees arent 150 years old, but even in the 50s they still didnt think big here, because motorised freight was scarce in the post war years... And treehuggers make it hard to make some room...
My father said, when he was young, the co-op delivered feed in 50kg bags with a 25hp tractor and a 6 ton wagon, and they just turned around between the house and the pig barn. When i was young, they had difficulties reversing the 49 ton steer axle bulk trailer in that same spot...
   / Pup trailers #119
Not much drag on this unit, and this is typical of modern designed tractors in North America. The trailers connect very close behind and often have skirts to help keep the underside of the trailer and axles from adding too much drag.
   / Pup trailers #120
There are a lot of undertrained drivers in the U.S. and Canada. It really doesn't take a lot of extra room to make a 90 degree turn with a truck, but it does take some. I am guessing that most of these trucks are not the dump trucks that built the roads and prepared the site, but are drivers delivering components for the actual building,
JOHN DEERE CP24 ASPHALT PLANER (A60429)
JOHN DEERE CP24...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A59904)
2018 KENWORTH T680...
Blast Off Hot Pressure Washer Trailer (A59228)
Blast Off Hot...
2020 INTERNATIONAL REEFER TRUCK (A58214)
2020 INTERNATIONAL...
(10) 10'-6" PVC CONDUIT PIPES (A60432)
(10) 10'-6" PVC...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
