New trailer for the gator
/ New trailer for the gator #1
nikdfish
Person Co. NC
John Deere 3038E & 1025R FILB
A while back we picked up an XUV590E S4. The S4 is 12' long, 56.5" wide and the only trailer of ours that could haul it around was the 18' aluma car hauler, which was not real convenient (big, wide & pull out ramps). Anyway, we went trailer shopping & the wife decided she liked the red Texas Bragg with a 14' x 76" deck & 2' expanded metal side walls.
It is a tandem axle (brakes on one axle) 7K (5500 lb. payload) 14' with a 4' drop down ramp. The ramp is expanded metal w/ 2" tube struts. The deck is 2" southern yellow pine. I will need to add some D-rings, it has 4 stake holders but I'd prefer D rings. I'm sure it will get used for stuff besides the gator. We should probably get rid of the little 5'X8' sno-bear trailer, as trailer parking space is getting a bit tight (this is trailer #5).
Pics from the trailer lot web site - but are of our trailer (the vin matches).
/ New trailer for the gator #3
Nice trailer! How about a pic of it loaded with your XUV590E S4?
/ New trailer for the gator #4
So you Gator doesn't have doors?
One of my riding buddies has a trailer like that; he has a Ranger with cab and doors and has to leave the driver's door open when he drives up onto the trailer because once inside he can't open the door due to the tall sides.
/ New trailer for the gator #5
One of my riding buddies has a trailer like that; he has a Ranger with cab and doors and has to leave the driver's door open when he drives up onto the trailer because once insider he can't open the door due to the tall sides.
Then leave's door open during transit and unloading?
No doors, mesh side curtains.
/ New trailer for the gator #7
We have a similar trailer with also a right front side ramp.. I had my neighbor weld 8 or 10 3" eye bolt "loops only" to the top rail. No need for D rings on the floor. Our 835i is secured by straps to these loops. These also work nicely for the ATV's during the hunting season.
Pics of S4 on trailer. No problem moving along between gator & trailer side.
Good clearance on approach angle with truck air suspension in high position, close clearance on approach angle with truck air suspension in lowest position (per an observer). Of course this could also be changed by changing the ball position on the hitch. No deflection of gate components observed during load/unload.
Added some 3/8" D-rings with 3/8" grade 8 bolts. All attachment points were on frame or immediately adjacent metal (no wood). I wanted 4 at the corners for gator tie down, then added a couple more up front. May add a couple more at the back for symmetry.:unsure:
Probably going to add something around the top perimeter for tarp/net tie-downs for uses other than gator transport.
After using the trailer a few times I decided to add some assistance to the tailgate. With my history of back issues I really don't want to tweek it inadvertantly. So I added garage door springs to help with some of the load. In addition to the springs themselves, I also installed safety cables that run through all the hardware & springs. If something breaks or lets go then at least it will be restrained.
Total cost was about $35. I used 100lb. springs but probably could have gone with 150. As it is, the assist is enough that I don't have to use the handle at the end of the gate but can just grab the lock plate with one hand & pull it up without strain.
/ New trailer for the gator #12
Nice work, but how are those cable going to arrest the gate from falling in case something breaks?
As lazy and safety conscious as I am, I would have used linear actuators. Although you would still have to push a button......
The cables aren't for the gate, they are to keep bits & pieces of spring / fittings from flying around if something breaks while the springs are under tension. You don't want to get slapped by a spring or a bit of spring launched shrapnel.
Getting things together for another trailer upgrade, adding brakes to the second axle. It's our only tandem axle trailer that doesn't have brakes on both axles. Parts should come in next week, will post as things progress.
Parts came in, but one of the brake assemblies had partially disassembled itself in transit (big box, too much free space). Etrailer is sending a replacement (yeah! I don't have drum brake tools), but things are on hold until it comes.
OK, I got started on the install in the AM to avoid the heat that was coming. I jacked the trailer by lowering the tongue to the lowest position & placing jack stands at the rear. I then cranked the tongue jack untill the tires were clear of the ground.
I figured I'd do one side & then the other. I'll get started with the wiring while doing the left side as that is where the connection box is located.
Started by removinng wheel & the idler hub
at this point I could go ahead & bolt on the brake assembly to the brake flange.
and then the brake drum with pre-greased & installed bearings
Then I initiated a new brake wire connection at the wiring junction box. I'm add a 12 AWG silicon coated wire run for the new brakes. I added it to the stud that holds the brake wire from the 7 way plug.
At this point things were starting to warm up enough that my glasses were catching too much sweat, so I did one sanity check before head into the A/C - test fitting the wheel.
It didn't fit.
First thought was I ordered the wrong hub size (5 on 5) even though I double checked measurements multiple times. So I measured my hub adjacent lugs again, 3" center to center, then measured the lug spacing on the received hub. They didn't match.
A "5 on 5" should measure 3" between centers on adjacent lugs. The received hub measured 2.75". That measurement should belong to a "5 on 4.75" hub.
I then actually took a closer look at the box the hub came in
Doh!
The Etrailer inventory sticker & bar code says "5 on 5" but the Axle Teknology label actually indicates 5 on 4.75.
Made a call to E-trailer. After I described what happened they asked if there was a colored dot on the drum & what color it was. I told them there was a green one & they replied "It should have been red, sorry it's the wrong size, we'll ship out replacements". So now I'm waiting on their arrival to finish up. I'll get started on the the other side & finish up wiring while I'm waiting.
to be continued ......
/ New trailer for the gator #17
Nice work so far.
I've always wanted to add electric brakes to a small dump trailer I have. It's designed for off road, but could be made street legal with the addition of brakes and lights. I want to make life easier on the antique truck I use to tow it around on occasion (mostly the trailer is used off road, behind my tractor). You inspired me to contact eTrailer and see if they have something that will fit.
Well, looks like the replacement drum/hub assemblies should be here monday. I did a bit with the brake wire layout & had enough to include a home run ground line back to the junction box. No need to ground to the frame. The ground line will get ID flags to differentiate it from the brake run.
OK, finally got back to working on the trailer. The hubs came in and were correct (even tested wheel fit to be sure). Before starting on the hubs, I finished wiring in the ground line to the junction box & did final layout and brake wire connections.
The left side got "in-line" connections with brake & ground lines which then continued over to the right side for connection there. Wires were zip tied to the top of the axle to stay safer from possible snagging. I then installed the drum hub. All electrical connections are done with crimp connectors with adhesive lined heat shrink.
I removed the old idler hub from the right side, then installed the brake assembly and drum hub. I then made the electrical connections & secured the wiring.
The last steps are getting old & new brakes adjusted to the same drag, then mounting the wheels & putting it away.
ETA - after adjustment, tested the install by pulling the pin on the breakaway box. New brakes locked up properly.
Last bit was to get the wheels back on. Found out the conical lug nuts supplied with the new hubs were A bit large on the flat end to fit in the 13/16 socket I was using. Threads were the same as those on the idler so I just reused the old lug nuts so everything uses one size. Torqued all to 90 ft/lb and called it a day.
2007 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2007 WELLS CARGO...
Kubota Diesel Engine - Pump Takeout (Skid Mounted) (A63689)
Kubota Diesel...
SANY EXCAVATOR (A63276)
SANY EXCAVATOR...
2015 FREIGHTLINER M2 4X2 S/A 26FT REFRIGERATED BOX TRUCK (A59914)
2015 FREIGHTLINER...
2018 Case 650M OROPS Dozer (A62679)
2018 Case 650M...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
