A newbies DIY solar install
/ A newbies DIY solar install #161
I have a deposit in on the F150 lightning. Really intrigued by the stated capability to act as whole house battery backup. Thats 98 or 131 kWh of battery sitting right there, might as well use it during an outage (assuming you also have another backup vehicle, should you drain the EV fully over a few days).
My 6500 watt gasoline Generator kicks pretty hard when the 3/4HP well pump comes on, but it does it.
/ A newbies DIY solar install #162
I have used 3500 watt generators to run well pumps. it really depends on the individual well. and ours were deep 240 units, not jet pumps
I've used a 3500 watt generator too. Pump motor is 240 volt A.C., 1 H.P. submersible sits at 400 feet. The pump control does have a big fat capacitor to help with the starting current.
/ A newbies DIY solar install #163
Nice.
Is it possible to take a pix of the capacitor setup to assist? What brand and rating too. It would help so many of us out on this power the well ordeal.
/ A newbies DIY solar install #164
/ A newbies DIY solar install #165
Nice.
I would imagine this is the standard three wire pump with the control box which has the capacitor and start relay in the box instead of in the pump. Mine is a two wire with the capacitor and start windings in the pump. Either way both pumps (2 or 3 wire with control box) draw the same starting and running current.
A 1 HP submersible running amperage is between 8-9 amps, starting probably 15-16 amps, so a 3500W is about 16 Amps 240V so its right on the edge.
What is interesting is if you see the pump manual from Goulds and Franklin Motors - page 15, generator recommendations based on pump size, they state for 2 wire pumps to increase the KW by 50%. That must be due to the start capacitor in the pump vs near the electrical panel/control box?
  • gould pump manual.pdf
/ A newbies DIY solar install #166
I used a 3500W generator as backup with a 3/4hp well before I got batteries. That generator occasionally would throw its breaker when the well started up and I'd have to reset it a couple of times.
/ A newbies DIY solar install #167
<snip>On another slant -
Has anyone seen a good DIY solar carport implementation? If so any good links?
I've got to replace a carport that was about 20x40. Basically I need to roof over the area to keep stuff underneath protected from the Mississippi sun and rain.
The previous carport was only paneled down on one side so I'm not looking for a complete enclosure.
I could orient it in a solar friendly angle.
But I'm thinking those big panels on frames could easily be adapted to a carport roof.
And I am thinking the carport isn't wind rated enough to add solar panels to it and withstand a Cat 1 hurricane or even close. I hate the idea of adding solar panels just to have them blown away at the first hint of a storm.
You may have a substantial carport, but I am envisioning one of those kinds like a lot of people are installing these days that just bolt to a slab in a few hours of time.
David from jax
No, I was thinking of a solar install with parking underneath.
This was a nice site to see this morning. I know of 2 people that lost panels last night. Lot's of downed fences, trees, etc. Highest wind gusts recorded in our area were 85 mph. We never lost power but the outage map showed 27,000 without last night.
What I was thinking of was building about this much solar panel, 5' to 7' off the ground on the low end (south) and whatever on the high end (north).
attachment try 2
With a little (2'? 4'?) extension of metal roof on the north for additional rain protection.
The entire structure would be built to "solar specs", (wind rating and snow/ice load) over the present parking lot.
/ A newbies DIY solar install #168
I had thoughts of having my ground mount be up higher so that horses could use it as a sun shade in the summer, but the standard mount needs to be installed near the ground and raising it would completely change the engineering calculations for wind.
There obviously exist these things (local businesses have large carports of solar) but considering the prices I'd definitely get something engineered even if you DIY the work.
/ A newbies DIY solar install #169
bummer, dead link.
/ A newbies DIY solar install #170
I wonder about that too. I've seen where animal or tractor shelter where it's regular construction with rafters, and also purlins going across the rafters, with the panels screwed into both the rafters and purlins. The panels acted as the roofing material. Good ventilation below and some protection from sun and rain.
/ A newbies DIY solar install #171
The car ports that I looked at were long on big galvanized, and large (long) and deep concrete footers to keep everything anchored. Wind force (i.e. pressure) is nothing to be sneezed at, especially if it can get to the underside of the panels.
I have trouble imagining that a normal run in shelter is going to be robust enough to hold up to a 100+mph windstorm, and that is a pricy roof...
All the best, Peter
/ A newbies DIY solar install #172
All the best, Peter
I wonder the same thing, but most of them hold up without solar panels on the roof.
/ A newbies DIY solar install #174
I think solar is a rip off
Probably true, as a lot of people have their hands out when you are doing the install, much like most anything else that is "up and coming". Even still, there is still money to be made (or saved) which is why people are doing it. If it weren't for the initial outlay of cash, more people would do it and the already crumbling electrical infrastructure would become a thing of the past, thereby mandating everyone to install solar.
Could become quite a mess!
David from jax
/ A newbies DIY solar install #175
Sort of like this?
or this?
That's sort of what I was thinking about.
/ A newbies DIY solar install #176
Not for us. We are saving about $4,000 a year and that will increase as utility rates continue to climb - and there are proposals now for substantial increases in rates. By the end of this year we will have saved $12,000+.
That said, it is important to educate yourself before talking to the solar companies - otherwise you are just a passenger on their bus. I learned all I could in advance - about panels, inverters, options, sizing a system, azimuth and angles, roof and ground mounts, maintenance, net metering, micro inverters, warranties on output and equipment, and more. I also contacted the local power company and learned what I could from their end. I was not an expert, but knew enough to understand what needed to be discussed. Then when the different solar companies came out the first thing I told them was that I had some knowledge of solar systems, and had some preliminary questions to cut to the chase, and I told them that if I could sniff any BS we were done talkng. It saved a lot of time. Even then one company tried to sell me a panel brand I did not want, and another company could not answer questions they should have been able to answer - sales people were sent out - not technically qualified people. I refused to go forward until they could send someone who could answer my questions - the next person was not any better. Finally, after narrowing it down to two companies I insisted on meeting their engineer - they agreed. All questions were answered, information was confirmed by emails, ambiguous contract terms were clarified, and, I told them how much I was willing to pay per KW hour, what panels I wanted (size and brand), etc. One company declined, two agreed, one of those said they would meet my conditions but only if I did it before the end of the year (which I wanted anyway because the tax credit would reduce the following year). Signed the contract, and all went well. (BTW - we purchased our system -did not lease)
/ A newbies DIY solar install #177
I wouldn't say rip off, but it's not for everyone. If you don't get a substantial amount of direct sunlight, the payback period is going to be so long as to make it impractical for anything other than making a statement of how green you are. If you do get a lot of sun, the system would likely pay for itself in a reasonable amount of time. Depending on the aesthetics, it could also be a plus should you decide to sell.
Probably not a good choice for me...northern state and the sun is so low in the sky from Nov. to March that we see very little direct sunlight in the winter. YMMV
/ A newbies DIY solar install #178
Can be. Not knowing your location it's too difficult to determine for you.
With my farm, solar here is 12VDC & 24VDC for all sorts of things. It's more auxiliary and/or supplemental for our uses. And in a power outage it carries us thru for a few days straight. It can't keep up long term with daily activities, but it can keep the necessities viable; several basic barn lights, fence energizers, water heaters, and charging Li cordless batteries for tools and other devices. The key here is what smart charge controller is in place. Very few can charge lithium batteries at all.
Sun during the day and in the winter months, we get wind at night. Thus, the wind style generators here in the mid-west at times generator MORE power than solar.
For wind power generation for home or farm, the vertical generators work the best, take up way less space, closer to the ground to maintain, and are not an eye sore either.
I've made my own looking much like this - - -
Depending on the DC motor/generator, one can get constant 400W of power in a steady breeze.
Mounting on 4x4 wooden farm fence posts is very easy.
I made mine with simple plastic gutters one can buy from Home Depot to shape the plastic blades.
The bearings are SKF or FAG from the MTD catalog at my local hardware store.
The motor is 24VDC 550W. The key point to know is the rotation of the motor to then properly shape the blades to the wind. This gives the most power. Doing the rotation backwards gives less power.
And ensure a blocking diode (schottky diode) is in the loop too for EACH unit ! Can't have them ganged together without them !!!!!
Now, if you are not talented and make something like this, then prepare to experience lots of loud wind NOISE. People make these from cutting half-moons out of 5-gallon buckets. ;)
Now, when those hurricane like winds come, the low height wind generators can have the bladed un-locked from their perch and simply removed. This way, no damage to deal with. We had that spat a week ago. 75mph to 110mph winds were clocked.
/ A newbies DIY solar install #179
I'VE BEEN CONSIDERING A SYSTEM, KEEP US INFORMED ON YOU PROJECT SO WE CAN LEARN. THANKS
2016 EH Wachs Trav L Vac Hydro Vacuum Excavator Trailer (A61567)
2016 EH Wachs Trav...
24in pin on excavator tooth bucket (A61307)
24in pin on...
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
2015 Ford F-150 IN-OP at time of listing (A63118)
2015 Ford F-150...
UNUSED REMOTE CONTROLLED DUMPER TRUCK (A62130)
UNUSED REMOTE...
