Qapla
Veteran Member
If I counted right, one array has 30 panels and the other has 33. Why the difference? or was my count off :confused3:
Since some if you guys seem to be well versed in Solar ... any idea if and how and how much it would cost do put in Solar to power my 5 ton A/C-heat pump package unit?
can you talk about the micro inverters?
I get that they generally have proprietary cabling and connections to the panels, but how does the AC side work. Do you simply use a junction box and wire nut 3/4/5 (whatever) AC leads together to join that many micro controllers all putting out 2 amps into a single 6/8/10 (whatever) amp AC lead? I assume they phase correct on there own somehow with electronics?
do you just run those AC legs back to a receptical/service panel to connect to the house/barn/shop?
is it possible to pull direct DC off the microinverters for battery charging or DC lighting? can you use a backup battery bank and microinveters together?
