25 kW Solar power project in Iowa.
/ 25 kW Solar power project in Iowa. #121
If I counted right, one array has 30 panels and the other has 33. Why the difference? or was my count off :confused3:
Actually there is third array also with 33 panels under construction being completed before year end unless the weather gets too bad. If I tell you why I did that my wife would laugh at me. I din't want it sticks to possible future airplane runway. The longer arrays are ofset several feet west so they can be longer.
/ 25 kW Solar power project in Iowa. #123
Why thank you. We only use ceiling fans to augment air movement, but find that really only necessary when we have a lot of people. We do have propane fireplaces to take the chill off at times but mostly ambiance.
Amazing how costs have come down since I started my system (2006). Now I could get twice the wattage for 1/3 the cost for panels. Batteries may cost more. I'm very happy with my system.
Look for to seeing your progress and hearing how it works.
David Sent from my iPad using TractorByNet
We finished the last array today. I still have to connect all cables to the breaker box and connect it to the grid. That is few more hours of work I will do tomorrow.
Here is a summary of the project:
96 Canadian Solar 250W panels.
96 Enphase inverters. All divided into 9 center connected strings because of voltage rise is a big issue here.
Expected peak AC power about 21 kW. Expected yearly production about 32000 kWh or 88 kWh/day.
All panels are mounted on Ironridge rails supported by wood structure anchored by 52 reinforced concrete piers.
It took about 4 weeks of work of two people (my wife and I) to complete. Two weeks of drilling holes and making concrete piers and two weeks of building the racking and assembly of the system.
After adding all bills together it all cost $55348.01 or 2.31/W DC before tax rebate. Hopefully we get federal tax rebate of $16604.40 plus $3000 Iowa tax rebate.
Total cost after rebates $35743.607 or $1.49/W DC. We overshot original budget by about $2200 underestimating cost of some electrical gear and especially fees imposed by the local electrical coop.
I will post pics tomorrow.
Drilling holes for concrete footing. Week one.
Making footings. Week one and two.
Footings for one array. End of week two
DSCN2852.jpg.
Building first array. Week three.
Ditching for the main cable. Week three.
Last batch of panels on improvised forklift.
All done. Week four.
/ 25 kW Solar power project in Iowa. #126
Congrats!! Must be exciting seeing all the hard work pay off.
/ 25 kW Solar power project in Iowa. #127
Very impressive. Wind, solar, hydroelectric, wave energy... we need it all.
I'd sure like to hook up my all electric house to your array...cord might be a bit long.
And since you have good wind in your area, next step is to get a windmill in there. But for no moving parts, you can't get much better than solar.
Some think solar unattractive, but at the end of a big field,
is the corn going to complain? I wonder if passing airplanes will get "flashed" on a sunny day.
I hope this works out well for you long term. In the short term, thanks for doing your part.
It is all done. Just missing one grounding clamp and Enphase cable to one panel (I think that when they measured the cable the guy cut it on wrong side of the connector). The chunk of the cable with the connector and the coupler should arrive in mail in few days.
I was thinking about wind for some time but found the wind generators way too expensive and requiring maintenance 120 ft high. At the cost of PV panels wind is dead on arival.
/ 25 kW Solar power project in Iowa. #129
Thanks for documenting all this, I'm bookmarking this thread for when I do mine.
/ 25 kW Solar power project in Iowa. #130
It is all done
Well, you're just about 1000 miles from me. Wonder what size extension cord I need...:licking:
/ 25 kW Solar power project in Iowa. #131
Looks great! It's been a terrible month for sun though..
I purposelly put the cost "as built" there so whomever is interested can do the math.
/ 25 kW Solar power project in Iowa. #133
Since some if you guys seem to be well versed in Solar ... any idea if and how and how much it would cost do put in Solar to power my 5 ton A/C-heat pump package unit?
Since you live in FL your unit does primarily AC I am guessing. If I am not mistaken 5 ton=17.6 kW. Heat pumps have about 400% efficiency therefore the unit has about 4.5kW compressor. Actually better approach is to figure how much space you have available in example on the south facing roof. Based on the size of the HP unit (I am guessing) you burn about 23000 kWh/year. PV system producing 23000 kWh/year would have to be about 15.5 kW. The actual cost would then depend on DIY or turn key and location. Roof being the cheapest. I got quote for turn key $3.90/W in Iowa before tax rebate. We built our ground standing system DIY for $2.26 before tax rebate. Gainesville has solar coefficient 5.17 in other words 1 kW of installed PV power would produce (in average) 5.17 kWh/day.
If you would do it DIY I would recommend microinverters. It will increase the cost by about 7% but you will not burn anything or kill yourself. It is much easier to deal with single panel producing 30V/9A then a string of panels producing 600V/10-15A.
/ 25 kW Solar power project in Iowa. #135
Just remember though about those micro-inverters is that the heat in the Fla Sun from May-Sept. will have them in the 110-120*F range or higher up on the roof under the solar panels. They have not been on the market long enough to make a judgement about how they hold up.
That would be my biggest concern.
/ 25 kW Solar power project in Iowa. #137
Still gonna get hot up on those roofs in June, July, and August. And somtimes we get really hot weather in Sept. as well, up to 110*F 'round about 1998 IIRC.
/ 25 kW Solar power project in Iowa. #138
can you talk about the micro inverters?
I get that they generally have proprietary cabling and connections to the panels, but how does the AC side work. Do you simply use a junction box and wire nut 3/4/5 (whatever) AC leads together to join that many micro controllers all putting out 2 amps into a single 6/8/10 (whatever) amp AC lead? I assume they phase correct on there own somehow with electronics?
do you just run those AC legs back to a receptical/service panel to connect to the house/barn/shop?
is it possible to pull direct DC off the microinverters for battery charging or DC lighting? can you use a backup battery bank and microinveters together?
Yes. Microinverters have special cabling with connectors spaced either portrait or landscape. It makes all connection quick and easy. You can chain up to 17 inverters/branch. Each branch has to have its own 20A breaker. They are grid comutated and produce "pure" sine wave. If the grid voltage drops below 210V or increases over 260V they disconnect from the grid. There is a possibility to use them also off grid. The battery feeds a "master" inverter that makes the microinverters think that the grid is up and running.
We have 96 inverters in 9 branches. Each branch is center connected directly to a breaker and via breaker box to the main cable and grid.
/ 25 kW Solar power project in Iowa. #140
According to the data with the A/C unit it has a "total unit amps" of 30.7 and it is single phase 220-240v
At 240 volts that would be 7369 watts needed to operate the unit.
I would assume that would be for A/C-Heat Pump operation since it takes an additional breaker to run the heat strips. The heat strips are actually optional and the unit can run without them. In fact, the heat strips could be connected to the grid while the A/C-Heat Pump is run from the Solar Power.
As far as roof area, I have an East/West roof - no South facing roof. However, I have 30 acres so finding a place to put a free standing array would not be a problem. I am also capable of DIY.
With this information is it possible to give a more bottom-line type figure for the panels and inverters needed. As far as a frame, I am sure I could build something if need be.
2012 International 4300 Reefer Truck (A63118)
2012 International...
2013 Ford F-350 Pickup Truck, VIN # 1FT8W3BT5DEA61959 (A61165)
2013 Ford F-350...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
UNUSED CFG INDUSTRIAL MX20R MINI EXCAVATOR (A62130)
UNUSED CFG...
2018 Komatsu D61PX Crawler Tractor Dozer (A61567)
2018 Komatsu D61PX...
2025 Poly Fuel Tank with Electric Pump (A61568)
2025 Poly Fuel...
