A newbies DIY solar install
/ A newbies DIY solar install #141
PG&E wasn’t maintaining their grid before solar, don’t expect them to start now. $86 is a normal monthly bill, if you gotta pay that for just being connected, why bother getting solar.
/ A newbies DIY solar install #142
Has anyone in California purchased a whole house battery backup without solar to get through the safety-shutoffs? California is against all internal combustion it seems, so not sure if you can get traditional whole home generators.
/ A newbies DIY solar install #143
There's a guy on youtube Ray Builds Cool Stuff, lives in Northern California, building a whole house battery backup. At least, from my understanding, that's what his initial purpose was. To tied them over when the grid is turned off because of high winds.
/ A newbies DIY solar install #144
I chatted with a Tesla battery vendor at a home show a few months ago. After I explained my needs - including the ability to run a well pump - he said their batteries could not do that - i.e., could not "start" my well pump. I assumed that is correct as he is in the business of selliing batteries and I was a potential customer.
/ A newbies DIY solar install #145
Only solar I have is a multi panel Zamp unit on my RV. Keeps the house batteries topped off and I'm good with that.
/ A newbies DIY solar install #146
So, even natural gas engines are forbidden as a backup source?
/ A newbies DIY solar install #147
well pumps can easily be started with soft start and certain inverter setups. just depends on how much money you want to spend, I can't speak to the product he was using though
/ A newbies DIY solar install #148
Tesla batteries can certainly start well pumps. Like air conditioners, well pumps have large startup amperage draws, and are therefore hard on battery systems. I believe that the current Powerwall LRA (locked rotor amperage) rating is 118A. If you need more than that, there are a variety of pump soft start options out there, or you could just buy a second Powerwall which would boost your start capacity to 236A.
I think that sizing a battery system comes down to figuring out your peak draw (well, AC, etc.), minimum viable energy (what do you absolutely have to have on), and how long you expect to be without power. Our worst case events are fire, earthquake, and severe winter storms. For the first two, we expect to be without power indefinitely. (Weeks to months)
I know of a couple folks who have Tesla Powerwalls without solar, but they are all urban. Even in the wintertime, having solar enables some recharging without resorting to generators, so almost everyone that I know with Powerwalls have solar to recharge the Powerwalls. Time of use power charges in California make the use of batteries to shift solar production to cover peak charge time periods desirable. (Solar to battery/house during the day, battery to house in the evening, with the grid getting any excess solar.)
We are quite happy with our battery system, though it took awhile to get it installed as Tesla was/is selling so many Powerwalls.
All the best,
Peter
/ A newbies DIY solar install #149
All the best,
Peter
Thanks Peter for the info. I am not certain what information the Tesla sales person at the home show asked me for re the well start-up issue. Possible that I shared info about the well (1.5 hp, 420 feet down). I don't know if it was important to his statement that the battery would not work for us (he seemed very certain and answered immediately). I know I had a lot of questions as we were interested in the product. I will revisit the issue and do a bit of checking online.
We do okay with short power outages as we can hook a generator up for fridge and freezer and light duty - lights, etc., and we can do without water for a while, but for longer outages a battery system would be nice to have as we have solar and could recharge that. Otherwise, a wired in whole-house generator is another option.
/ A newbies DIY solar install #150
Beowolf,
I got the same feedback from Tesla on the Power Wall to hook into our solar - we have the same pump size 1.5 HP, down 375' - it draws 22-23 amps on start up 13 amps running.
We had a 6500W starting, 5500W (or 24 AMP 240V) continuous genset, which really struggled with the pump so we barely used water during an outage, so I upgraded to a 7500W (32 Amps 240V ) continuous 9500 starting and it handles it fine.
/ A newbies DIY solar install #151
Battery backup will definitely run a pump, but it's got to be sized for it. I use Enphase's system; we had to go with 2 of their batteries (10kWh each) to be able to manage the desired backup loads (I ended up putting in 3 for 30kWh for more headroom). I can't speak for power walls but I'd imagine it's similar.
/ A newbies DIY solar install #152
AFAIK the prohibition against small off-road engines doesn't have any real effect before 2024, and it only affects portable generators starting in 2028.
I don't think it affects stationary generators like whole-house units (which presumably are rarely used... unless it powers your off-grid house lol).
/ A newbies DIY solar install #153
Again, just for what it is worth, Tesla did upgrade the surge power ratings on their Powerwalls a few months ago, so the comments may have been (were) valid at the time.
Nevertheless, I think @Carl_NH's experience with a generator is typical; generally, you need more than twice the running current to start a well pump, and certainly more than the LRA. (Makes sense, as the poor well motor has to overcome all of the water weight (pressure) above it as it begins to rotate.) I have heard 5X running current as a rule of thumb, but the actual design is everything (copper/aluminum windings, brushed/brushless, 1800/3600 rpm, gas vs diesel, flywheel size, and how the rated power was actually defined).
With any inverter system, stable loads work really well, but loads that switch on suddenly, or rapidly on/off can cause stability issues. I read of someone with a 3D printer that had a nozzle heater that cycled rapidly to maintain temperature and that ended up causing flickering as the batteries tried to predict where the load was going.
My two cents for someone installing a battery system would be to ensure that they have whole house surge protection in the main panel as you are adding $$$$ of electronic equipment tied to your main power lines.
All the best,
Peter
/ A newbies DIY solar install #154
Beowolf,
Carl, I assume you are referring to a portable generator with 7500W - 9500 starting? I may look into that as I consider my options. Thanks for the information.
/ A newbies DIY solar install #155
Peter
I think well systems with storage tanks would make sense as they do not need to go on and off frequently - then the booster pump from the tanks to a pressure tank and then running into the house would be a 110 (?) and could be operated off a smaller generator. Our well does not have a storage tank but the the house my daughter is building on our property will have tw0 3000 gallon tanks - one for domestic use and one for Calfire.
/ A newbies DIY solar install #156
Wow, the local fire group wants 30,000 gallons of storage or 10,000 with black iron piped sprinklers in the house...
Yes, FWIW, My well pump is set to run for a couple of hours at a time, so that it runs infrequently.
All the best,
Peter
/ A newbies DIY solar install #157
All the best,
Peter
The local fire here requires a minimum of 2500 gallons dedicated to fire use. That can mean a 5,000 gallon tank with float switches set so that the domestic use never causes the level to go below 2500 gallons - the domestic use taps the top 2500 gallons. On the recommendation of a well guy we went with two 3000 gallon tanks - his reasoning was that he has seen 5000 gallon tanks bulge, and he prefers a separate tank for domestic and just let the fire storage tank sit - he says fresher house water that way. We also are required to have sprinklers - and a booster pump for those.
/ A newbies DIY solar install #158
Approximately 11 years ago, we installed a 68-panel, 17-KW system on a purpose-built tall building to get above much of the neighbor's tree shading.
The system uses Enphase brand microinverters (one under each panel) so that shading that panel only reduces its output. You may not have a shading issue.
The output of the microinverters is 240 V, so it is lots safer than a long high-voltage DC run.
Current Enphase systems provide for battery fallback if utility power fails. We have frequent and a few long outages. I see that you do not.
The gird-tied system banks and retains overproduction. We have 20 MWh in that bank now. Power company bills ~ $8/month for infrastructure.
The cost of electricity will go up, so the bank is earning interest. This system will (and has) powered an EV.
We have switched from oil and propane to 100% electric.
There were lots of good prior ideas and I have not read all of the posts which may cover my suggestions.
Suggestions:
Plan very carefully.
Use large conductors to reduce parasitic loss.
Plan for maintenance. (a squirrel got on our roof and chewed through two cables, requiring panel remove/re-install.)
Use the required anti-seize for the stainless fastener to the aluminum structure.
If it is an older roof, re-roof that part, at least, before racking and panels go on top.
Use tall roof-to-racking risers. Airflow under the panels cools them better on hot days and increases output.
Do it!
/ A newbies DIY solar install #159
Yes - it is a portable genset and the 32 Amps is @ 7500W and at 9500 surge is 43 amps and the pump draws 22-23 amps starting- 13 amps running - you can tell when it kicks on but it handles it fine.
/ A newbies DIY solar install #160
I have used 3500 watt generators to run well pumps. it really depends on the individual well. and ours were deep 240 units, not jet pumps
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
Polaris Ranger 4x4 (A61166)
Polaris Ranger 4x4...
John Deere 4044M (A60462)
John Deere 4044M...
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
Oxy-acetylene Torch and Regulator Rig (A63118)
Oxy-acetylene...
Preliminary Listing / Full Catalog Coming Soon! (A62180)
Preliminary...
