To Geothermal From Propane
/ To Geothermal From Propane #21
I am not sure a "tractor forum" is the proper place for this, but here it is anyway: I have a 17 year old geothermal system in my 3000 sq ft house. I installed this system myself using parts bought from a supplier that has since closed up. I have been happy with it, but could probably get better efficiency with a new system. My house is 40 ft from a 400 acre constant level lake so I pump water out of the lake, thru the heat exchangers (two compressors) and back to the lake. I have a six zone system with six thermostats, six fans in the plenum and six duct runs. There are two return air registers (upstairs and downstairs).
I want to replace the six zone control system with a more modern one, as well as the compressors and air handler. Does anyone have any experience or recommendations for a control system that will handle six zones?
/ To Geothermal From Propane #22
I'm still just evaluating GT for my needs, so can't provide any answers, but have found that the forum over at Green Building Talk to be very helpful.
/ To Geothermal From Propane #23
We have had GEO since we moved in to our 3286 sq ft home built in 1995 (built it myself). It has a WATER FURNACE 3ton unit with a 4ton horizontal loop. The unit has electrical backup heating elements, but they have never kicked on. We live in Illinois and it has gotten down to below 0 F. We too have the hot water aux heat which basically preheats the water going into our hotwater heater (a by product of the system when it is running). Our GEO is on a separate meter from the electric for the rest of the house. The wife checked a couple of months ago and the heat AND air conditioning for our home for the previous twelve month period was $360. We never open our windows.....if it's cold the heat runs; if it's hot the air runs.
Today it was 26 F and our air conditioning was running from about 11am till near sun down thanks to the large windows we have on the south side of the house. I have often wondered how much we would save if we didn't let the air condition run during the winter.
/ To Geothermal From Propane #24
I sure wish we had more info RE: these Geo systems during the summer months.
Heat here is no problem, but during the summer months we really use some A/C. For some reason GEO has not caught on here for cooling.
My family had a GEO powered A/C in the early 80's but it was not as efficient as we had hoped b/c it was not installed correctly. It used an open source well and discharged into a pond.
/ To Geothermal From Propane #25
Hello wngsprd,
What company manufactured your new unit? I have been thinking about changing over to geothermal for a long time. When I do it, I'd really like to get it right the first time.
Island Farmer
It was a close call between the Water Furnace and the ClimateMaster Tranquility. We went with the Tranquility 27 due to our belief we would have better support in our area. It has run well and quietly, and matched up with our existing zone control board, hot water heater, and needed only minor modifications to connect into the ductwork.
/ To Geothermal From Propane #26
the main point i was trying to make, was how much more eff the new systems are than they were 15-20 years ago: going from a 20 year old geo system to a regular heat pump, and the bills dropped: IF he had gone with a new geo system, i am sure the bills would
have dropped even more..installation and maintenance are the biggest problems with
a geo system: people will say they know all about them, and they don't...
heehaw
/ To Geothermal From Propane #27
Thanks for the additional information.
Our unit is a GeoComfort... Nice unit... My advice here is buy for the dealer and service, most units are pretty comparable nowadays. Dealers - they vary widely!
I started this thread to give some real numbers about installing a geothermal system this fall to try and offset the rising propane costs. To give you some hard numbers behind the reasoning and the results I wanted to post an update. So far we have used only 90 gallons of propane since it was installed in October (hot water, stove, fireplace, grill) - and that includes the volume shrinking in the tank when things get cold. That 90 gallons cost us $270...
Until now we have not gotten an electric bill for the geothermal system... that's because November's bill, although it was a meter read actual bill it was unusually warm so it really was a poor estimator of cost. December's bill, while the weather was still warmer than normal, was an estimated bill based off last years readings / usage. So - we expected a real punch in the gut for January since it would, in essence, be "correcting" us for 2 months of above baseline electric usage for the geothermal... and although this winter has been "warmer" than usual - there have been several cold windy periods.
Well - the bill just came... but let me give you a frame of reference since the January bill also includes all those Christmas lights AND my wife being home from school so the TV is on more, etc. Also - keep in mind, with geothermal I have not been setting the house back during the day (or at night) because I work from home and last year with propane, set it back to save money and froze during the day.
Last year the January bill was - $117.62
Two years ago it was - $138.89
Now - keep in mind those previous years we were paying an additional $250 per month for propane.
Our most recent, keeping the house 70 degrees all the time, generating free hot water geothermal electric bill - $223.18
Let me put this another way... for months of December and January - we kept our house at 70 degrees 24 hours a day - for only $50 per month. And we won't need another propane fill for 12 months - and then it will be no more than $300.
Gotta love heating with dirt!
/ To Geothermal From Propane #30
Have you factored in the increased cost of the system install into that math?
How many years to recoup that? just curious?
/ To Geothermal From Propane #31
Perhaps the issue with geothermal in warmers areas is that you don't get quite as much of a benefit? For example, I live in Pennsylvania and our ground temp (once you get well below frost line) is a pretty stable 55 degrees year round. That works really well for heat in the winter and AC in the summer. If you are in area where summer ground temps may be more like 70 or 75, perhaps its not as efficent for AC? On the flip side, in warmers areas, you may not see as much of a gain in heating since an airsource heatpump works better in warmer winter temps. That is just a guess but it may be that its not as popular in your area because the cost to benefit ratio is not as great?
There haven't been any increased costs... Just the company has been incompetent (that's not even a strong enough word)... In terms of payback... Our last propane fill was 2.94/gal... Which is way higher than our original math. Sticking with our original math, the unit is paid off in just under 7 years with 2.499 a gallon propane.
And that wasn't apples to apples - that assumed shutting the heat way back at night and me working out of the house chilled... Never mind the savings related to cooling. We almost never ran the central air before, now with this unit and the associated costs - we can run that in the summer and the free hot water alone will pay for it.
/ To Geothermal From Propane #33
Our groundtemp here is 68-72 deg according to the charts I have seen. Contrast that to average 90-100 degree air temps for a standard condensor. I have seen very little geothermal activity in the south.
/ To Geothermal From Propane #34
I think Tekmar makes such units. House Control 406
I built my own from a $80 PLC I bought on eBay. It automatically switches from AC to heat and vice versa, runs every pump at least one minute /day so they don't get stuck, integrates heat pump and water heater and controls heating temperature independently in every room of the house and garage. AC is not zoned for simplicity. It will not provide much saving due to the house layout. The house has floor heating. Total cost of PLC, relays, terminals, two dual temperature controllers, terminals, cabinet, power supplies etc. about $500. The problem is that I am only one able to fix it if something happens to it so it isn't for everybody.
We heat 3750 sq ft including 1400 sq ft of somewhat drafty garage. We AC about 2350 sq ft. Our estimated average heating cost is about 70-80/month. Maximum in the coldest month was $110.
/ To Geothermal From Propane #35
Geothermal doesn't pay for itself IF you ever need to have it fixed. High labour costs from most of the heating company that don't know anything.
/ To Geothermal From Propane #36
That si about right statement.
I wanted to install my system by myself but due to work commitments I had to hire installers. It took them two days to install all the pumps and wire it all up.
They left some air in the outside loop, several sweat joints developed leaks, one pump was wrong for cold glycol mix (couldn't pump the required volume when the glycol mix was more viscous). The heat pump would start several times a day to keep the heat/cold accumulator at required temperature regardless there was a demand for heating or cooling. The cold take off for AC was at the top of the accumulator instead on the bottom. The HP had to be switched manually between heat and cool mode. The lead guy charged 65/hour and the helper 45/hour. I was charged for 20 hour each. The charge was not a problem the quality of work was.
After complaining to them I decided just to get new pump from them and do all the repairs and modifications by myself. So far there was not a single issue in past eight years.
The installers understand the basics about pumps, loops etc but have no clue about controls and nuances of particular installation.
/ To Geothermal From Propane #37
Good reason to go always go with someone that knows what they're doing and will back it up. A company that I looked at here guarenteed their work for 10 years. They monitor their systems and will fix any system that is not performing within 10% of what they stated. Geothermal payback wasn't good enough for me since I'm on natural gas. If I was on propane the payback was MUCH shorter. I currently looking still at solar. Looks like ~15year payback.
Stout Rock Bucket Grapple HD72-3 (A66285)
Stout Rock Bucket...
2012 DRAGON  130BBL VACUUM TRAILER (A65643)
2012 DRAGON...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
2016 KUBOTA SVL90 SKID STEER (A65053)
2016 KUBOTA SVL90...
2015 Ford Transit Connect Cargo Van (A64556)
2015 Ford Transit...
New/Unused Wolverine 72in Quick Attach Ripper (A65583)
New/Unused...
