Beginner MIG/Everlast Welder Question
/ Beginner MIG/Everlast Welder Question #1
mmranch
Gold Member
Crested Butte, CO
TYM T603
I have an Everlast Power MTS 251 Si welder that I bought a couple of years ago. I have been stick welding with it and all has been good.
I recently started setting it up to begin learning MIG welding. I have a spool of Hobart .030 wire and have installed that into the machine and torch. After removing the tip shield, there is a copper looking spacer thingy which the tip screws into. The tip which is installed says 1.0-.040. (this seems to mean size 1.0 to .040).
I also bought a package of Hobart .030 tips (says Miller compatible on the package). The Hobart .030 tips will not properly thread into the copper looking spacer which came with the gun. When comparing the threads on the larger tip to the smaller tip... the smaller tip threads look different than the larger tip threads.
1. I assume I must have the correct size tip for the wire I'm using? Or can I weld using the larger tip with .030 wire?
2. Should the MIG gun have threads which match the Hobart (Miller compatible) MIG tips?
3. I have tried multiple times to get on the Everlast forums but have been unsuccessful. Do the forums really exist?
Thanks!
/ Beginner MIG/Everlast Welder Question #2
/ Beginner MIG/Everlast Welder Question #3
/ Beginner MIG/Everlast Welder Question #4
Thanks!
I've not seen a post on any "Everlast Forum" that I can think of. Not sure where you posted. But I am responding here. Miller is not Everlast. Hobart/Miller are the same company. We use .08 and .06mm thread tips. Depending on the gun you have (they have had three different guns, all Binzel type though, but the 24, 25 and now 36) you could have either. Both will interchange with a variation of TWECO however, either the 11 series for the .6mm thread, or the 16 series for the .8mm thread (should be about the same length to respectively). The smaller .6mm thread will also cross to Lincoln.
/ Beginner MIG/Everlast Welder Question #5
I don't think there is adapter to use the Hobart tips (M5x0.8mm). I also have a 251Si with the 36 torch and changed the M8 tip holder to use Tweco tips (M6x1.0mm). I purchased a generic 5m torch set for steel wire and converted the original 3m torch to weld 0.045 Aluminum wire. If you are using 0.030 wire, you can use 0.030" (0.8mm), 0.035" (0.9mm), or 0.040" (1.0mm). Of course, it is better to use 0.030 or 0.035 tips, but the 0.040 will work. You can PM me for details on how to convert the 36 torch to use Tweco tips. As Mark said the 24 or 25 torches are already M6x1.0mm
/ Beginner MIG/Everlast Welder Question #6
I don't think there is adapter to use the Hobart tips (M5x0.8mm). I also have a 251Si with the 36 torch and changed the tip holder to use Tweco tips (M6x1.0mm). I purchased a generic 5m torch set for steel wire and converted the original 3m torch to weld 0.045 Aluminum wire. If you are using 0.030 wire, you can use 0.030" (0.8mm), 0.035" (0.9mm), or 0.040" (1.0mm). Of course, it is better to use 0.030 or 0.035 tips, but the 0.040 will work. You can PM me for details on how to convert the torch to use Tweco tips.
We have an adapter you can buy if that is needed. Just call ext 206. But it derates the gun.
/ Beginner MIG/Everlast Welder Question #7
Thanks Mark, but I'm set. Are you saying that using the series 11 tips drops the the 36 gun below the capability of the 251SI when running 0.035 solid wire, or 0.045 Flux core? It is my understanding that the 36 torch is 300A rated and is oversized compared to the capacity og the 251SI.
Thanks for all the ideas! Not near my welder at the moment.
I believe the gun that came with my welder is a 25 according to the sticker on it. I will dig into this later (family just arrived for the Thanksgiving holiday).
The Everlast forum question relates to the fact that there is a 'Forum' link on the Everlast site. I tried registering a long time ago and when trying to login and actually 'see' the forum, all I've ever gotten is a message about 'your IP address has been banned'... contact the admin. When I've tried doing that, I've gotten no response. There is no question posted because I can't get on to the forum.
Thanks again!
/ Beginner MIG/Everlast Welder Question #9
Unless you use the H version, yes. With the H version, it is about 230A approx. standard is 200A roughly.
/ Beginner MIG/Everlast Welder Question #10
Thanks for the info. If i run heavy wire, i will convert back to the M8 tip holder and tips
OK, the manual basically says when threading the wire, 'make sure that each rollers groove size matches the wire diameter'. Got it.
Question is... which is the correct roller groove size for .030 wire? The roller small groove is marked .9v, the big groove is marked 1.2v (what does .9v and 1.2v mean?). Just looking at it... I'm guessing the small groove is what should be used with .030 wire but I'm not really sure.
When I used the small groove... it drives the wire just fine (haven't done the slippage test yet) but the tightener is like at no tension at 0 or .5. Just want to make sure I'm using the correct groove.
Thanks again!
/ Beginner MIG/Everlast Welder Question #12
Neither. If you look at page 17 of your manual, it gives you the drive roll size equivalents and explains it here: https://www.everlastgenerators.com/...ownloads/28a199059840cb20c238e12127d601aa.pdf
Your unit is equipped with .035" and .045" drive V groove drive rolls for hard wire. It is a 250A machine after all, and puny .030" wire is no match for that type of amperage capability. .030" tops out around 150-160A on standard short circuit, 200 amp on spray...
/ Beginner MIG/Everlast Welder Question #13
I also typically use tension right around 3.5 .
Thanks for the info!
Sorry, I missed that little sizing box (my manual is a little light on the printing... like the toner was running out or something). So I'm guessing I need a different roller to accomodate this .030 wire or will this wire simply not work in this machine?
Thanks!
After re-reading again... I'm thinking this .030 wire will not work in this machine.
/ Beginner MIG/Everlast Welder Question #16
You need to watch some Youtube vids on wire tension adjustments. You may be able to squeak by for now running an 035 feed roll with 030 wire if you set it up right. In any event you have a lot of homework to do. Good luck and have fun learning.
/ Beginner MIG/Everlast Welder Question #17
I would bet the .035 roller (.9) will work just fine on .030 (.8) wire..... At least most MIG machine will accept it...
And wire size .023 or .030 or .035 or .045 should be select on material thickness and correct voltage (amperage), NOT on maximum out put of machine....
/ Beginner MIG/Everlast Welder Question #18
It will with the right size drive roll. A smaller gun will be helpful, but it definitely WILL work with the machine itself.
2022 EZ-GO ELITE...
UNUSED 4' X 300' ROLL ATS POWER GRASS PROOF CLOTH (A64281)
UNUSED 4' X 300'...
30" X 11' ADS DRAINAGE PIPE (A64281)
30" X 11' ADS...
2017 Jeep Patriot 4x4 SUV (A61574)
2017 Jeep Patriot...
Caterpillar E120B Excavator Service and Parts Manuals (A63117)
Caterpillar E120B...
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
