Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting)
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #61
Chain grab hooks attach to the FEL bucket, not the FEL.
Two bolt on chain grab hooks from the premium supplier, Dan's Bolt On Hooks, cost around $30. SPLURGE.
However, I also have pallet forks- and I guess I could also just wrap chains on those….
"Wrapping" is not a good idea. However most chains used with tractors have a slip hook on one end and a chain grab hook on the other end. So you could use the chain slip hooks to create a tight, noose.
I cannot immediately think of a situation where Pallet Forks would not obviate the need for bucket chain grab hooks.
I'm thinking you might mean Ken's Bolt on Hooks? If that's the case I would also recommend them.
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #62
My BX doesn’t have much capacity, but I have found several uses, for my welded on hooks. The BX has a fold, on the top edge of the bucket. We welded hooks onto backing plates. Then, we welded a piece of flat stock behind the lip, to support the edge of the lip and backing plate.
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #63
I put two grab hooks on each side of the top of the bucket. When I pile fence rails, lumber or tree branches, I'll first lay down two chains at 90 degrees, the grab hook distance apart. Then I pile the material neatly, and pull up with the tractor. The near chains each go to one of the hooks, the far chains wrap over the bundle, and go to the other hooks. The chains keep it all together while I drive.
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #64
Nice welds!
Just make sure you have rear ballast (ballast box is best, IMHO) when you do any lifting
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #65
Nice welds!
Those welds get comments everywhere I go. Wish I could do half that nice. I generally use my backhoe for ballast.
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #67
Practice, practice, practice....
I can stick stuff together, but it’s going to take a lot longer than you’re suggesting! I leave a LOT of room, for improvement.
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #68
When you want to lift the maximum weight,, and have the most control of the weight,,
the lift point should be close to the tractor as possible.
I have hooks on the bucket, but, I also have hooks that liftfrom a point that is closer to the tractor than the bucket pivot.
These lift hooks result in the maximum amount that my loader can lift.
Since the hooks are attached to my QA adapter, I can also lift with the bucket removed from the tractor.
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #70
Lots of good advice in this thread. I recommend read it all before welding anything.
I took the simple approach for a quick-n-dirty one time use. But then I've never replaced this because it simply continues to work. With only about 700 lbs lift capacity on this elderly Yanmar, this is sufficient.
Cold Shuts (chain repair links) that I already had
bolted into pre-existing holes in a bucket that was already badly beaten up when I bought the tractor in 2003. I've never bent anything, hook or bucket, over 15 years using this.
Initial use - before I had loader forks:
673366-img_3091bucket-logs-jpg.39929
Heaviest lift I've done. Label on tank says 650 lbs and I had to reach over to the center of the trailer to lift it. This didn't bend the Cold Shuts.
p1210480rlifttank-jpg.121491
Typical use.
p1060289runloadtiller-jpg.199681
If there weren't already holes along the top of the bucket I would have welded on proper hooks. But this serves well, for my very occasional use. There's no need to improve on it.
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #71
Thanks to everyone that recommended our products :love:
Please remember when shopping and comparing that we have the only USA forged grade 70 Weldable Grabs available, this is what we use on our Bolt-On Hooks now and we also sell 5/16" and 3/8" sizes for welding.
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #72
According to my point of view. It is good to work with welder to get useful and better result.
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #73
... And here's what NOT to do. A failed experiment.
I cobbled together some scrap materials, zero cost. Not shown here but I also cut 2x4's to fit into the bucket vertical to avoid crushing the bucket. (which was already trashed by some prior owner).
Forks made this way were pretty useless. They wouldn't stay aligned.
I soon bought a $180 pair of clamp-on bucket forks, with the optional adjustable separator between them that keeps the forks aligned. This works well.
(also shown - the bolted-on Cold Shuts I'm still using several years later as chain hooks).
p1030820rforks1-jpg.60440
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #75
I have done many mods on my CUT but HOOKS was the first 'add on' once I had finished my DIY cab, and a very often used.
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #77
Yes! A hitch ball I added to the other Yanmar. It's low enough to get under a parked small trailer.
kimg2005rhitchonym186dbucket-jpg.511565
If you buy a hitch mount you should buy a forged unit, not a cast unit.
Even though they are both steel, the cast can crack and your load run off with out you!
You should also alway use a safety chain.....
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #78
Chain or forks? Why not both?
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #79
If you are using the chains to secure - no problem.
If you are lifting with the chains, they should be attached to lifting eyes or hooks - not wrapped around the forks.
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #80
You talking in general terms, or responding to my post (since you quoted it). If responding, look at the pic again.
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61574)
2021 Mercedes-Benz...
John Deere 4300 32HP Loader Utility Tractor (A61572)
John Deere 4300...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2014 ISUZU NPR 4X2 18FT BOX TRUCK (A59911)
2014 ISUZU NPR 4X2...
