F2880 rear hitch
/ F2880 rear hitch #1
Fields_mj
Central Indiana
Ford 1710, Kubota F2880, White FB16
Does anyone have any ideas for a rear hitch on a Kubota F series tractor? I'd like to add on to my (new to me) F2880. Mine currently has the factory rear weight installed. Idealy i would like to mount a 2" receiver tube just to make things convenient.
Primary goal is to be able to pull my lawn rake so I can pick up most of the mulched leaves in the fall and grass clippings when I get behind on mowing.. I would also occasionally pull a small 4' trailer around the yard. Ideally I'd also like to pull my lawn roller so I can flatten out mole damage without having to get my 1710 out, but the roller is close to 1000 lbs and I'm not sure the rear end of an F series will handle that, especially when turning around.
Any thoughts and opinions would be appreciated.
Thanks,
Mark
/ F2880 rear hitch #2
I purchased a 2" receiver hitch from Harbor Freight for $25. Bolted right on my F3680 several years ago.
/ F2880 rear hitch #3
I have a F3990 and used a bolt on pin hitch to the rear counter weight. I reinforced it with welds. I use the hitch for a 52 inch lawn sweeper. It works well.
/ F2880 rear hitch #5
Factory wight. I'll try to get a pic
/ F2880 rear hitch #6
Yes its been awhile.
INTERNATIONAL 700 SERIES 6 BOTTOM PLOW (A64278)
INTERNATIONAL 700...
Wooden rocking horse (A64557)
Wooden rocking...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
2019 BOBCAT T595 SKID STEER (A65053)
2019 BOBCAT T595...
2020 Chevrolet Tahoe SUV (A64557)
2020 Chevrolet...
YALE FORKLIFT (A63291)
