Dump trailer direct wire?
   / Dump trailer direct wire?
To add a suggestion to the instructions that nikerret suggested - If you are thinking about doing the wiring to your dump trailer so that it is "keyed" (i.e. only live when the truck is running) or switched power otterboxes make excellent water/dust resistant housing for relays and such.
I wanted auxiliary power distribution for my truck to power lights and air bags and put all of the relays and the necessary bus bar in an otterbox, with the solenoid and main fuse mounted adjacent to the relay housing.
Not adding a solenoid or any other complexity to the system.
Just heavy gauge wire (protected by a breaker) back to a plug. SO I can run straight to the dump trailer with sufficient current to keep that battery charged and/or run pump direct from truck.
These are the same pumps used on 350/3500 and 450/4500 dump truck bodies. They dont have their own batteries. Just heavy gauge cables going from the battery to the pump. I basically want the same thing just a little farther from the battery.
Actually this is one of those times I wish PTO options out of the T-case on the truck were a little more common. Because I'd just hang a pump off it....and give myself a set of remotes on the back of the trucks flatbed and run the trailer just like I do off the tractor
   / Dump trailer direct wire? #12
I have a battery on my dump trailer that has been there for about 10 years. I installed an Anderson plug on truck and trailer with 8 awg wire. I plug the trailer in when I hitch up. I use the trailer sometimes once a month and sometimes 10 times, sometimes not for 3 months. As long as I plug-in when I hitch up it works great.
   / Dump trailer direct wire? #13
i have an electric forklift battery connector by my 7 way light connector. #1 wire from battery. frame ground. my liftgate is on the same wire. do a voltage check at the hyd motor to confirm 11 volts when starting to dump a heavy load.
   / Dump trailer direct wire? #14
Now that I've scrolled down past all your post signatures (kidding, kidding), I'll add 2c,
Keep the battery. It will be a nice buffer, allowing local, high-amp discharge to power the hydr pump, then taking slower recharge from your truck in between dumps. And you can easily control the battery charging situation by just deciding when to have it plugged in. It won't need to be anywhere near fully charger to still give good performance as long as you have it backed up by the truck on your fancy new cables.
When I use my neighbors dump trailer, it usually has a dead battery in it, or no battery at all. SO I throw in a dead battery of my own (as long as it has at least 10V on it) and run jumper cables from my (running) tractor battery. I tried it once without a battery present in the dump trailer, and it was much harder on my tractor battery/engine, and all the jumper cable connection points.
I want to do this also, and get a hitch-mounted winch. But maybe also set up a high-power 12v flood light setup that I could run off the truck too.
   / Dump trailer direct wire? #15
My dump trailer battery charges off my truck when it is hooked up and running. It also has a small charger in it that I plug up some of the time to keep the battery charged. No problems for years. Never replaced the battery.
Mine charges off the truck too. But the small 12ga wire through the 7-way is only capable of so much.
   / Dump trailer direct wire? #17
I ran across that post when I was searching the subject. Basically the same thing I am doing. Curious why you used 2 breakers....at the truck and at the trailer?
Since there are batteries, at both ends, I didn’t want either connector to be hot, when disconnected. My thoughts were it would be safest to be able to kill them, without disconnecting from the battery. If the plug got compromised, I wouldn’t have a hot whip flopping around.
I saw the kit you linked but dont have an amazon account....and couldnt find whether or not it was pure copper wire or CCA/DCCA
It‘s DCCA.
Now that you have had some time since you have done yours....is it still preforming as expected? Anything you have changed or would do different if you do it again
The ends were crimped and not soldered, on the kit. They corroded and I had to cut the corroded part out. I then had all of the connections soldered. My setup stayed connected, quite a while and was exposed to a lot of rain. I also cut the ends a bit shorter and built a jumper, so I could stow them, easier.
The DCCA has been fine. When I bought the kit, I couldn’t afford to build it with copper. That would be better, but not enough to justify the cost difference. Doing it, again, I would solder it, right from the start.
The breakers are awesome. I have never had an issue, in that regard. They do their job and are robust enough to hold the current, even during hard pulls.
It takes two more connectors and more time, but I like having the jumper, instead of the long ends, at the connection point.
My truck has a high idle system. I can let the truck idle, at 600 RPM, if it’s a light load. The high idle allows for 900 RPM, minimum. After that, I have a potentiometer that I can dial from 900-2,400 RPM.
We put a meter on it, to see if having the truck connected was doing anything and if using the high idle mattered. It did. Huge advantage. I don’t recall the exact numbers, but when we tested with an empty box (16’ of 7g steel), the trailer battery, alone, went from around 12.5 volts to around 7 volts, as it pulled power. With the second battery (truck battery) connected, but the truck off, the voltage only dropped to around 9 volts. With the truck running, at regular idle, the voltage only dropped to around 12 volts. With high idle maxed out, it was around 13 volts, while lifting. Obviously, a loaded bed would pull more power.
Volts X Amps = Watts. The pump needs a certain amount of watts, to move the load. If the voltage drops, the pump will pull more amps to make the same power. If you can keep the voltage higher, it requires less amps, to do the same work.
For me, this setup has paid for itself many times over. I have the 7-way plug charging (it’s just a trickle charger-will keep a full battery topped off, but won’t charge up a depleted battery) and a solar panel (7.5W with a controller, again, just a trickle charger). My trailer is legal to haul 5 tons. I can get 4-6 dumps, at maximum weight capacity, on a full battery. I do a lot of commercial hauling. With the plug setup, I can go a full day and never have a low battery.
Of course, this is harder on my truck alternator (only a 157A unit) than it would otherwise work. To me, it’s a calculated cost of doing business.
Last week, I did a job where we demo’d a house. The dump was only two miles away. I was able to dump four heavy loads, in the morning, then dump several loads of heavy dirt, in the afternoon. We got the dirt from a mile away. That’s not much time to let a different method charge up the trailer battery. When I got to where I dumped, I kicked the high idle up. Even a load I put too far forward (my first time on an articulating loader) was lifted, without fuss. Without the 2 AWG setup, I would have been home, at lunch, while someone else hauled dirt.
I see people recommending no battery, on the trailer. For me, I want it to stay. I’ve even considered adding another trailer battery. Where I live, we have major temperature extremes and often, in the same week. That’s hard on batteries. It’s less hard on them, if you can keep them topped off.
   / Dump trailer direct wire? #18
Removing the battery also removes the emergency brakes if trailer disconnects. The 12v power plug could be damaged if it's not parallel to trailer pull direction.
   / Dump trailer direct wire? #19
You don't even need a heavy wire to charge. Install an automatic resetting circuit breaker and run it. I've done it on my dump trailer for over ten years without an issue.
I didn't read it all but if you want to do away with the battery in the trailer you will need heavy gauge wires running from both the positive and negative from the truck battery. I once bought a retired rescue truck (think rescue squad) that had heavy cables coming from the trucks batteries to the control panel in the box, they did wrap the wires with a protective sleeve.
There were only 18 posts prior to yours. Everything you mentioned was addressed.
Yes there is a charge wire. It's only 12 ga and really limits the charge ability. The trailer already came with an automatic reset breaker for charging. It has always worked.
This is not a new problem with dump trailers. Fact of the matter is, if you own a dump trailer, at some point you are gonna experience a battery that just don't have enough juice.
In a perfect world, you'd just sit there till the truck charged it enough, or you would be in reach of an extension cord and charger. Worst case, you are hand unloading.
Yes, I know I will need "heavy" wire. Hence why I ordered a kit with 2ga purr copper welding wire.
I am glad you went 10 years of your factory battery without any issues whatsoever. Most don't get that lucky
Grecer Food Trailer (A55973)
Grecer Food...
2012 Ford Expedition 4x4 SUV (A56859)
2012 Ford...
yellow ball Trailer (A56859)
yellow ball...
https://www.facebook.com/LipoExtremeDropsReviews/
https://www.faceboo...
Hays LT1 Tender (A56435)
Hays LT1 Tender...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56435)
2023 Kubota...
