Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting)
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #41
I had my dealer weld 3 hooks to the bucket before I took delivery of my L2800 HST. Have been that tractor with those hooks for about 15 years pulling trucks out of the mud and every other task I can find for them. Best accessory I bought.
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #42
Thought I'd post an example of using bucket hooks with forks. I had to move our wishing well over our septic candy cane pipe for repairs. These are from when we put the well back into place before repainting it.
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #43
Its more often my bucket is attached, so I was thinking of adding some bolt on or weld on hooks for using China.
However, I also have pallet forks- and I guess I could also just wrap chains on those….
eh… any pros/cons I’m not considering?
(Mahindra 1640 if that matters for the feedback)
Never wrap chains on forks. It's not safe.
Somebody on here will now post: " I've been doing that for 80 years"
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #44
Seems like someone could fabricate someone kind of hook or chain stop that would slip into the notches on the pallet fork frame?
Something like this could be made to use a chain on the fork:
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #45
Ok, sorry for a dumb question, but I might use this project as an excuse to get a small welder. Is this a decent application for stick welding? I ask as Ive seen some mention of stick being less than ideal for thinner material…. Not sure if the bucket “lip” qualified as thinner :)
It is a decent application for a qualified welder.
Welding on lifting eyes is not a beginning project.
Serious stuff if your welds fail.
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #46
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #47
Why would you do that vs welding a grab hook on the bucket.
Why would not? Is your tractor the only place you use a chain?
My guess is if you question the need for a chain shortener, you rarely use a chain!
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #49
Hooks or chain slots on bucket are most useful thing I did to grab/hold/lift things...
bucket-jpg.684518
slots-3-jpg.684517
eyes-3-jpg.684516
The chain slots were just fabricated from some 2 X 2 X 1/4 inch angle iron... The shackle eye was from same angle iron just welded back to back...
Very nicely done. Glad you used Grade 8 bolts.
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #50
I did not read all the previous comments, so this may have been mentioned before. I have a 2" Trailer Receiver Tube welded to the middle of the top lip of my bucket. Allows the use of 2" receiver with chain hook welded on. Also allows use of 2" Receiver with ball size as required. Handy for moving boat / trailer etc. Quick change.
Also have pallet forks, which I find invaluable. One instance where chain on pallet forks could be used (so far I have just used rope) is for planting trees. Spread forks apart and tie rope / chain to each side of large root ball, one rope to each fork & it is very easy to lift the root ball / tree and set in prepared hole.
The Boom in the pic is more elaborate and stronger, but something similar can be made by inserting the upper tube for a boom in the receiver tube and running supports to the lower lip of the bucket.
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #51
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #52
Decent project but make sure you practice on similar materials first and test your welds well before you subject them to use.
On the problems of thinner material - it's all about control.
The only welder I bought was an Everlast PowerArc 300. Amazon had them on sale for $270 summer of 2014. Goes up to 300 Amps. Should be good for over 1/2". And being stick I can weld outside and not worry.
I practiced on 1/4" and thicker till I could get a decent weld (Thank you and rest in piece ShieldArc).
My first actual "project" I was welding 10 gauge steel (9/64ths) to 1/8 on a rotary cutter deck. Kept blowing holes on my 1/8.
Since then my son's have used it on much thicker stuff and I've put together some small projects.
If your going to get "into" welding decide how far "into" you want to get.
Mig is like a glue gun compared to stick.
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #53
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #54
I am well pleased with having my hooks on three links of grade 8 chain and bolted to the top corners of the bucket.
The chain allows them to swivel as needed.
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #55
I weld stuff so it never occurred to me to bolt them on. I can find a handful of 1/8th some wire or the other on the welding trailer. I would have to sift through a bunch of homer buckets to find the right size hardware to bolt stuff to the bucket.
As far as what preference I vote forks. The machine I use forks on mostly is a CTL and the forks do a better job of controlling the load when I'm bouncing around the place than chains do, plus I don't have to get in and out of the machine to fiddle with hooking and unhooking. OTOH I grub a fair amount of timber off the mountain. That there is why god invented chains.
Well, I'll be jiggered. Just reread the post title for comprehension (I don't read stuff in parenthesis as a general rule). Let me take another swing at it.
I try not to dangle a load on a single fork. The way my rack works if I slap the forks together in the middle the bottom slides aren't hooked to the rack which is exciting but dangerful. Anyway the point loading on the one fork gets it out of kittyhunkus with the other and then if I go to lift a pallet sideways on the hill I have to come at it the way that works with the hi lo and that is always the other way around from where I am.
On another note, I was admiring some of these pix. I forgot how buckets come with paint on them.
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #56
Yeah, but my stick welds are pretty and strong. :)
Note how crummy of a job the Korean with his MIG welder did with the original pad.
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #57
Chains slide on forks. Weld 3 hooks on the bucket. Cheapest thing you can do to the tractor.
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #58
OP, pallet forks can be relatively heavy. You may realize that when picking up something on the heavy side.
I have heavy duty pallet forks. I rarely put them on the tractor (Mahindra 5545). I use them a lot on the skid steer.
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #59
I added two grab hooks to my bucket. I lift things with the bucket, pallet forks, and grapple. It can be good to have options without swapping the FEL attachment.
/ Chain hooks on Bucket or just use pallet forks? (For misc chain hoisting) #60
I've never had the need for hooks on my bucket. Usually if something is that big that it wont stay in the bucket, forks with chains hooked to the mask is better anyways. My bucket and forks are quick attach so it takes no time to switch them out and the mask on my forks is way stronger than any bucket anyways.
UNUSED WOLVERINE SB-12-72W 72" HYD SCREENING BKT (A62131)
UNUSED WOLVERINE...
2018 Chevrolet Trax SUV (A61569)
2018 Chevrolet...
2013 John Deere 1770NT Planter (A63109)
2013 John Deere...
2001 Challenger 35 ton Flatbed Lowboy Trailer, VIN 1W8B21D261S000473 (A61166)
2001 Challenger 35...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A61569)
2009 Mariah SC23...
2019 CATERPILLAR 262D SKID STEER (A62129)
2019 CATERPILLAR...
