Price of pull type disc
   / Price of pull type disc #11
Bobcat CT4045 Dimension​
Bobcat CT4045 tractor photo
2019 -
4000 Series
Compact Utility tractor
Daedong built
Series:CT4045CT4050
Bobcat CT4045 Tires
Standard tires (ag):Front: 8-16. Rear: 13.6-24
Dimensions
Wheelbase:71 inches
180 cm
Length:125.5 inches
318 cm
Width:63 inches
160 cm
Height (ROPS):96.8 inches
245 cm
Shuttle Operating weight:3373 lbs
1529 kg
Hydro Operating weight:3523 lbs
1598 kg
Ground clearance:14.5 inches
36 cm
--- I’ve 700lbs of fluid in the tires. ---
   / Price of pull type disc #12
For that weight you must be looking at an Athens offset disc with 22” or 24” blades. The only way to pull it with your tractor is raised. They are rated for 90 hp tractor or larger.
   / Price of pull type disc #14
I use my TPH Disk Harrow for trail maintenance, firebreak maintenance and food plot preparation. Therefore I am more interested in cutting sod and penetration than smoothing.
I like a Disk Harrow no wider than the tread width of my rear R4/industril tires.
In food plot work, a Disk Harrow no wider than the tread width of my rear R4/industril tires fits between trees. A wider Disk hangs up. Backing up a Disk in the woods, especially on a slope, is difficult and time consuming. In accepting this limited width I can pull a Disk with larger diameter, heavier pans.
What do you intend for the Disk you are researching? Why are you seeking a pull-type Disc
with a a 7'-11" (95") width when your tractor is 63" wide? Will you mostly be smoothing fields in succession to a turning plow?
   / Price of pull type disc #15
Bearing in mind that the disc you are looking at is adjustable, with it set at it's most aggressive angle you could probably pull it for the first pass but that second and third pass where the disc gangs are bogging to the axles I doubt it very seriously at least not at any speed that you would be satisfied with, as someone else said earlier you can always let the wheels down so that you are limiting the depth of the disc penetration in the soil but that kind of defeats the purpose. IMHO you would be better served with a 3 pt hitch lift type harrow that is adjustable. Lastly Athens make great disc but they are very proud of them, check out Brown Disc and see if there is a dealer in your area , there are quite a few more but I haven't owned or know anyone who does so you just have to check them out, there is nothing worse than buying a piece of equipment and not having enough tractor to fully utilize it.
   / Price of pull type disc #16
We have an 8' offset disc. You can make one pass down a hard gravel road and leave it looking like a garden. 4x4 tractor 15,000# and that disc is all that tractor wants. It cuts great but it takes power.
   / Price of pull type disc #17
I had a Amco 9 foot offset disc. My Mahindra 6520, 4WD, would pull it okay, but I couldn't run it in the gear I needed to make the speed I needed to turn the sod completely over in hay pastures. I had the weight, but needed a few more horses.
But on my place, one pass and it was ready to plant a garden. You can see the dirt being thrown over here........
She was over 3,000 pounds.
What is the drawbar horsepower of your tractor? I think it will be iffy, but doable.
hugs, Brandi
Well I was just trying to get really heavy. My main focus is maintaining a stand of switchgrass which will be about 4 acres. I also want to disc my food plots combing 1.5 acres. This is a 10 acre field nice and flat.
Also discing for native forbs 50% disturbance. Maybe a couple acres.
I’d like to use it in my wooded plots I work on but I’d have to use a box blade and remove tons of rocks before I’d feel comfortable taking it over it. That’s another acre.
   / Price of pull type disc #19
I’d like to use it in my wooded plots.
In food plot work, a Disk Harrow no wider than the tread width of my rear R4/industril tires fits between trees. A wider Disk hangs up on trees, after the tractor is through. Backing up a wide TPH Disk in the woods, especially on a slope, is difficult and time consuming. Backing up a pull-type Disk might be impossible in the same situation.
Well I was just trying to get really heavy. My main focus is maintaining a stand of switchgrass which will be about 4 acres. I also want to disc my food plots combing (?) 1.5 acres. This is a 10 acre field nice and flat.
You will have to decide if a wide Disc to decrease time spent processing your fields, or a rear tire tread-width TPH Disk for processing land between trees is your priority.
1) For your food plots, consider a TPH Disc Harrow 72" wide, with 9" pan spacing, with pans 20" in diameter. I am sure you can pull this. You might be able to pull a TPH Disc Harrow 72" wide with 9" pan spacing, with pans 22" in diaper, but I am not sure. Note: you need to pull a Disc Harrow at the speed of a brisk walk to throw dirt.
9" pan spacing on the front gangs, 7" spacing on the rear gangs is also good.
2) For your fields consider a TPH Disc Harrow 84" wide, with 7" pan spacing, with pans 22" in diameter. The additional pans will yield more float, allowing the extra 12" of width and greater 2" of pan diameter.
I am trying to go really heavy.
You must pay for every pound.
Heavy Disc Harrows suitable for your CT4045 are going to price new at ~~$3,500.......
Brown Manufacturing is in Ohio, not that far from you.
Found this about 2 and a half hours from me. They said it’s still available but haven’t answered any of my questions on weight/pan size and spacing of the disc. Maybe they only made so many types in this 6’ size that could narrow it down? Looks heavy.
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
New/Unused Double Stall Portable Toilet (A57453)
New/Unused Double...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2024 Timpte 40ft Hopper (A56438)
2024 Timpte 40ft...
2014 Audi Q5 AWD SUV (A56859)
2014 Audi Q5 AWD...
2025 Nationcraft 8.5X36TTA3 38ft Tri-Axle Enclosed Trailer (A56859)
2025 Nationcraft...
