Hydraulic Hose Guard
/ Hydraulic Hose Guard #1
rScotty
Super Member
Rural mountains - Colorado
Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
I got a roll of 1" black nylon hose protector on Amazon:
Electriduct 1" Nylon Protective Hose Sleeve - 25 Feet - Black - $30.00​
Then whether I use OEM or have replacement hoses made locally, I simply slip a length of this nylon over the hose and zip tie it to the metal ends before reinstalling. It makes hoses last twice as long.
The trick - for me at any rate - is to have is to have a roll of it on hand. You can buy it OEM on some hoses - for about 4x the cost.
/ Hydraulic Hose Guard #3
I keep rolls of various ID’s around for hydraulic hose as well as a myriad of other applications.
/ Hydraulic Hose Guard #4
/ Hydraulic Hose Guard #6
What is pictured, is a very different product than what rScotty is recommending.
His recommendation is for a nylon fabric type hose (Amazon).
Aha. I googled Amazon ca hose protector and spiral wrap came up for me.
The fabric wrap is way cheaper and EASIER to install
/ Hydraulic Hose Guard #7
/ Hydraulic Hose Guard #8
Yes,..... I bought the spiral wrap once, but......never again!
/ Hydraulic Hose Guard #9
/ Hydraulic Hose Guard #10
Disconnect one hose end fitting and slide the fabric protector on, reconnect hose end fitting.
Very simple!
With quick connectors that's easy. Hoses going from a pump to motors, for example, aren't removed so easily.
/ Hydraulic Hose Guard #11
Just takes a wrench to remove a hose end fitting.
/ Hydraulic Hose Guard #12
Log loaders get severe use. Around the grapple they use a heavy plastic spiral wrap.
/ Hydraulic Hose Guard #13
My tractor and loader came with that fabric hose protector on all of the hoses.
/ Hydraulic Hose Guard #14
Good planning. McCarr has this under "Abrasion resistant sleeving". I keep a selection of sizes on hand for a variety of protective uses, including hydraulics. My favorite positive is that it will stop a hydraulic fluid jet if the hose ever ruptures.
/ Hydraulic Hose Guard #15
I used the spiral hose wrap - like Big Barn pictured. Purchased at local "hydraulics shop" - House of Hose, Spokane, WA. Used on all exposed hydraulic hose.
/ Hydraulic Hose Guard #16
/ Hydraulic Hose Guard #19
The price went up to $35 on Amazon because all you guys looked at it. :rolleyes:
I bought the exact same thing last June from Amazon for $27--Delivered. šŸ˜Ž
Here's a snip from my order.
8053 (A61166)
8053 (A61166)
For Sale L4479 Snowblower and Subframe
For Sale L4479...
2010 Chevrolet Tahoe 4x4 SUV (A61569)
2010 Chevrolet...
1998 JOHN DEERE 120 EXCAVATOR (A62129)
1998 JOHN DEERE...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
