Hydraulic Hose Guard
   / Hydraulic Hose Guard #1
rScotty
Super Member
Rural mountains - Colorado
Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
I got a roll of 1" black nylon hose protector on Amazon:
Electriduct 1" Nylon Protective Hose Sleeve - 25 Feet - Black - $30.00​
Then whether I use OEM or have replacement hoses made locally, I simply slip a length of this nylon over the hose and zip tie it to the metal ends before reinstalling. It makes hoses last twice as long.
The trick - for me at any rate - is to have is to have a roll of it on hand. You can buy it OEM on some hoses - for about 4x the cost.
   / Hydraulic Hose Guard #3
I keep rolls of various ID’s around for hydraulic hose as well as a myriad of other applications.
   / Hydraulic Hose Guard #4
   / Hydraulic Hose Guard #6
What is pictured, is a very different product than what rScotty is recommending.
His recommendation is for a nylon fabric type hose (Amazon).
Aha. I googled Amazon ca hose protector and spiral wrap came up for me.
The fabric wrap is way cheaper and EASIER to install
   / Hydraulic Hose Guard #7
   / Hydraulic Hose Guard #8
Yes,..... I bought the spiral wrap once, but......never again!
   / Hydraulic Hose Guard #9
   / Hydraulic Hose Guard #10
Disconnect one hose end fitting and slide the fabric protector on, reconnect hose end fitting.
Very simple!
With quick connectors that's easy. Hoses going from a pump to motors, for example, aren't removed so easily.
Swict 78" Bucket (A50121)
Swict 78" Bucket...
2010 Ford F-150 XLT (A50120)
2010 Ford F-150...
Unused Delta Crash...
Feteral 8"x60' Transport Auger (A50774)
Feteral 8"x60'...
Harlo HP8500 Forklift (RIDE AND DRIVE) (A50774)
Harlo HP8500...
2021 Redirective Crash Cushion Guardrail (A51692)
2021 Redirective...
