Hydraulic Hose Guard
/ Hydraulic Hose Guard #1
rScotty
Super Member
Rural mountains - Colorado
Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
I got a roll of 1" black nylon hose protector on Amazon:
Electriduct 1" Nylon Protective Hose Sleeve - 25 Feet - Black - $30.00​
Then whether I use OEM or have replacement hoses made locally, I simply slip a length of this nylon over the hose and zip tie it to the metal ends before reinstalling. It makes hoses last twice as long.
The trick - for me at any rate - is to have is to have a roll of it on hand. You can buy it OEM on some hoses - for about 4x the cost.
/ Hydraulic Hose Guard #3
I keep rolls of various ID’s around for hydraulic hose as well as a myriad of other applications.
/ Hydraulic Hose Guard #4
/ Hydraulic Hose Guard #6
What is pictured, is a very different product than what rScotty is recommending.
His recommendation is for a nylon fabric type hose (Amazon).
Aha. I googled Amazon ca hose protector and spiral wrap came up for me.
The fabric wrap is way cheaper and EASIER to install
/ Hydraulic Hose Guard #7
/ Hydraulic Hose Guard #8
Yes,..... I bought the spiral wrap once, but......never again!
/ Hydraulic Hose Guard #9
/ Hydraulic Hose Guard #10
Disconnect one hose end fitting and slide the fabric protector on, reconnect hose end fitting.
Very simple!
With quick connectors that's easy. Hoses going from a pump to motors, for example, aren't removed so easily.
/ Hydraulic Hose Guard #11
Just takes a wrench to remove a hose end fitting.
/ Hydraulic Hose Guard #12
Log loaders get severe use. Around the grapple they use a heavy plastic spiral wrap.
/ Hydraulic Hose Guard #13
My tractor and loader came with that fabric hose protector on all of the hoses.
/ Hydraulic Hose Guard #14
Good planning. McCarr has this under "Abrasion resistant sleeving". I keep a selection of sizes on hand for a variety of protective uses, including hydraulics. My favorite positive is that it will stop a hydraulic fluid jet if the hose ever ruptures.
/ Hydraulic Hose Guard #15
I used the spiral hose wrap - like Big Barn pictured. Purchased at local "hydraulics shop" - House of Hose, Spokane, WA. Used on all exposed hydraulic hose.
/ Hydraulic Hose Guard #16
/ Hydraulic Hose Guard #19
The price went up to $35 on Amazon because all you guys looked at it. :rolleyes:
I bought the exact same thing last June from Amazon for $27--Delivered. šŸ˜Ž
Here's a snip from my order.
2021 Ford Mustang Mach-E AWD SUV (A61569)
2021 Ford Mustang...
2015 BOBCAT T590 SKID STEER (A62129)
2015 BOBCAT T590...
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
New/Unused 2in Ratchet Strap (A61166)
New/Unused 2in...
New/Unused Electric Golf Cart (A61166)
New/Unused...
2022 New Holland C327 Compact Track Loader (A63118)
2022 New Holland...
