Hydraulic Hose Guard
   / Hydraulic Hose Guard #1
rScotty
Super Member
Rural mountains - Colorado
Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
I got a roll of 1" black nylon hose protector on Amazon:
Electriduct 1" Nylon Protective Hose Sleeve - 25 Feet - Black - $30.00​
Then whether I use OEM or have replacement hoses made locally, I simply slip a length of this nylon over the hose and zip tie it to the metal ends before reinstalling. It makes hoses last twice as long.
The trick - for me at any rate - is to have is to have a roll of it on hand. You can buy it OEM on some hoses - for about 4x the cost.
   / Hydraulic Hose Guard #3
I keep rolls of various ID’s around for hydraulic hose as well as a myriad of other applications.
   / Hydraulic Hose Guard #4
   / Hydraulic Hose Guard #6
What is pictured, is a very different product than what rScotty is recommending.
His recommendation is for a nylon fabric type hose (Amazon).
Aha. I googled Amazon ca hose protector and spiral wrap came up for me.
The fabric wrap is way cheaper and EASIER to install
   / Hydraulic Hose Guard #7
   / Hydraulic Hose Guard #8
Yes,..... I bought the spiral wrap once, but......never again!
   / Hydraulic Hose Guard #9
   / Hydraulic Hose Guard #10
Disconnect one hose end fitting and slide the fabric protector on, reconnect hose end fitting.
Very simple!
With quick connectors that's easy. Hoses going from a pump to motors, for example, aren't removed so easily.
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
Cattle Chute (A50121)
2015 Peterbilt 320 Heil Front Loader Garbage Truck (A50323)
2015 Peterbilt 320...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2013 Ford F-150...
