Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #7,061
Top view
/ Let's talk flail mowers #7,063
That pic is from Deere site.
Here's the one I'm looking at
May I ask for a picture of your own Quick hitch model? So I can fully grasp what your worried about please?
/ Let's talk flail mowers #7,064
Wow, *Now* I understand. That’s a seriously long slot to have a pin slide fore & aft in!
That is definitely a speed bump to adapting for a quick hitch setup with that amount of slop.(for lack of a better description.
/ Let's talk flail mowers #7,065
Lost out on the cheap mower to someone else. The search continues
/ Let's talk flail mowers #7,066
I've been contemplating the purchase of a Flail mower for quite some time. I mow roughly 3 acres mixed hills and flat lands. Does anybody mow hills with their flail? How does it perform and compare to other options?
Mike
/ Let's talk flail mowers #7,067
Finish flail mowers and rough cut flail mowers work well with hilly terrain. As with any tractor of any size you would want to back up the hill and mow down the hill if it is above 15 percent grade anyway with NO mowing across the slope.
I towed the 48 inch motorized flail mower previously owned by my father up his 15 degree lawn slope with his heavy lawn tractor with no issues.
/ Let's talk flail mowers #7,068
Good to know, thank you!
When mowing on a hill, do you raise the Flail on the 3-pt when backing up the hill and then lower it to mow down hill?
I'm liking this option more and more.
Mike
/ Let's talk flail mowers #7,069
I mow up & down hills with serious pucker factor. Cross hill on serious slopes isn't recommended no matter the mower, but I’ve done it. On my former L3200 & old 917 flail a couple of times I was mowing the sides of ditches so steep I lost traction with the high side tire. Put it in 4wd & backed out even slower than I went in.
Never lift your impliment if stability is sketchy it will raise your center of gravity. A flail won't be much better on smooth slopes. A rotary cutter can fold in half under some circumstances if you cross a ditch or something. But those have to be pretty harsh.
/ Let's talk flail mowers #7,070
Hello and good evening Mike,
In any case you want and need a mule with loaded tires when dealing with slopes
as it adds to the machines stability with or without an implement.
You can if you want to do it that way sure, you only have to raise it a few inches but as fallon says its better to leave it on the ground and the rear roller will not mind.
The rule of thumb to follow is; do not back up the slope if you can slide on the sod with a boot and the heel holds moisture especially if you have turf tires. Better to have have loaded R2 tires(Ag lug tires) as you need more traction.
If you travel at 2 miles an hour up hill you are moving at 3 feet per second rounded so you can travel down hill at 2 miles an hour and have a very fine mowing with a brush mowing flail.
Just do not try to mow fast as you need to be sure to wear your seat belt and have the rops up and locked and the brake pedals locked together to avoid slipping across a pedal and locking one wheel.
/ Let's talk flail mowers #7,071
Hello all:
I recently purchased a Ford 917 (22-184) and am waiting on side slicers from Flailmaster to replace the worn out duckfoot cutters. It's all greased up and running smooth. It seems I have to have the roller all the way down and my top link extended a bit (belt drive housing is flat to sloping away from the tractor) to keep it from scalping behind my Kioti CK3510SE. I thought it might be a bit much for the machine, but the only time its bogged down is when it found thick plastic mulching my property's pervious owner left for me. It can produce quite the rooster tail in orchard grass with the trash door off!
I have seen it recommended over and over again, usually by leonz, to pick up a kevlar belt. After spending a good deal of time searching by part number (137203) and by specs (57-58" B-size/type, 2-band) I haven't been able to find one that seems right. Messick's offering is priced like Kevlar, but looks to simply be an OEM replacement.
Does anyone have a link or suggestion on a local store that may have a proper kevlar belt. Also, is the original belt actually the BX-type, since it appears to be cogged?
Thanks for the help, I've spent a good deal of time reading over this and 917-specific threads. Cheers!
/ Let's talk flail mowers #7,072
/ Let's talk flail mowers #7,073
Thanks. It looks like your efforts produced the same results as mine. Lots of singles. I'm trying to find a 2-band belt. It that possible, or do I need to just get a matched pair of singles?
/ Let's talk flail mowers #7,075
Just go to any farm equipment dealer and they can get you most any banded belt you want.
/ Let's talk flail mowers #7,076
Hello all:
My 917 came with an actually new belt when I got it... I’ll try (during daylight this weekend) to rotate it to see if the writing is still on it for ya. I don’t recall the brand name of it either.... I didn’t write it down in my notes when I got it - bummer for both of us. BTW my posts with photos about this unit ....(scratches head) I want to say are back around the 6200-6600 post count?
/ Let's talk flail mowers #7,077
Thanks all. I've had no trouble finding standard replacements, hence the part number in my original post. I've just seen kevlar belts recommended and tought someone might have found one for this mower, since its a common one. I'll just keep a standard replacement handy.
/ Let's talk flail mowers #7,078
.........................snip........................... It that possible, or do I need to just get a matched pair of singles?
I did not bother with matched pair $ingles, just got two standard belts for my 917L (which I think is clearly a different model than your 917).
Seems to work fine and why not - it's just a mower!
/ Let's talk flail mowers #7,079
There definitely are some noticably different versions of the 917. Pretty noticeable differences but similar vintage, quality & engineering.
I got 2 single belts from the same batch. Pretty sure they were Kevlar, but it's been a few years. I'd recommend just getting a pair from the same batch & calling it a day rather than hunting a much more rare (and probably expensive) dual belt. If you get different length belts the tighter one will take all the power & wear out or snap, leaving the remaining belt to a quick death as well. Belts on a mower aren't super precision though, so as long as they are pretty close you'll be fine.
My new $7k Peruzzo flail came with 4 single belts on it. I haven't touched them in the 3ish years I've owned it. I put new single belts on the 917 because the ones on there were belts you would expect on a $100 beat to hell mower. Only had to touch em when I replaced the rotor bearings.
/ Let's talk flail mowers #7,080
You don't need kevlar belts, just run a good quality banded ag belt like the one you have. Banded belts are very robust, there are 12ft mowers with 3 rib B58 belts, as long as your pulleys are aligned you should have no issues.
2005 JLG G6-42A Telehandler (A62613)
2005 JLG G6-42A...
Camco Running Gear (A66408)
Camco Running Gear...
KMC Strip Till Rig & Planters (A64126)
KMC Strip Till Rig...
2016 Ford Fusion S Sedan (A59231)
2016 Ford Fusion S...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
NEW, ATS Mini Excavator (A62679)
NEW, ATS Mini...
