Adding rear remotes to a Kubota L3240
   / Adding rear remotes to a Kubota L3240 #21
With all your hydraulic versatility and capabilities, did you ever consider a connection for a hydraulic motor case drain? Common with skidsteers. There are FEL mowers and 3pt hydraulic equipment that need case drains. Even small hydraulic motors can benefit from a case drain. Be an easy, usually small, low flow, unblocked return line to tank.
Been several times thinking a hydraulic motor powered equipment or mechanism would be handy but not having a case drain handy an obstacle. 3/8” flat face QDs?
With only about 8gpm flow I doubt I'll run any motors on this, if the need does arise a case drain is an easy addition. Just have to add a "T" to the return to tank line.
Yes 3/8th QC's, thought about 1/2 but they are kinda bulky and honestly unnecessary for the remotes. If I do a power beyond line I'll make those 1/2.
   / Adding rear remotes to a Kubota L3240 #23
Holy cow. Nice job. I have a plasma table also. Sure makes custom fab easy. I think yours does a better job on bolt holes than mine does though. I usually have to run a drill bit thru afterwards as I get a slight slope on really small holes.
the thicker the metal, the nicer my cuts.
still, with all the parts and hoses, must have cost some $$$$
i have 2 rear remotes that came standard on mine, but I kind of wish I ordered the 3rd sometimes.
Thank you, I haven't added it up but would guess less then $1k, from kubota it would have been over $2500 and only 3 remotes.
I did already have the diverter from another project so that helped, and I can make up my own hoses which saves some money.
What plasma table do you have? I'm still getting mine dialed in on holes. There a little taper on the smaller ones but not bad, I just oversize the holes slightly to compensate.
Mine is a Precision Plasma LLC, gantry kit running CandCNC Linux CommandCNC with a Hypertherm PM105
   / Adding rear remotes to a Kubota L3240 #25
I have a Dynatorch 5x10 table And a hypertherm powermax 1000 torch system.
the Last project I did was a side rail system for a flatbed truck. The design work and planning took twice as long as the job. Designing a latching tailgate really took some time.
My artistic side isn't really there yet, so far I stick to light production parts, mostly for trash trucks (the reason I have the table).
One day I hope to get better at the artistic drawing stuff.
I cut this out for my friends wife, she drew it up.
Most of the time its boring stuff like brackets
I see your little Nissan 20 in the pictures, I have its bigger brother a 50 diesel.
I finally wired up the diverter valve, only took about 3.5years. I was able to design and print a button mount that attaches to the lever. The button is a push to lock/push to unlock and has an indicator that lights up when activated.
I hid the relay and all other wiring under the range selector cover along with the switches/wiring for the work lights.
It'll be nice to be able to fully run my rear blade now, the one remote is always attached to the top link so I have a manual diverter on the blade for the gauge wheel.
Man Cave Metal Sign (A57454)
Man Cave Metal...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2004 Freightliner FL70 Garbage Truck, VIN # 1FVABTCS64HM47795 (A57453)
2004 Freightliner...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
True 750 Elliptical (A56860)
True 750...
