Kubota b2920 rear remote
/ Kubota b2920 rear remote #1
Kubota toys
Manitoba
Kubota b2920
Just had a thought for adding a rear remote but not sure if it will work. I have a valve off of an old stone picker that works to change the flow from one cylinder to another using a single remote tractor valve. I.E. pop it down would run picker table , pull it up would run the dump bucket. If I put this on my tractor could I run a set of hoses to rear and mount a block and use the up down of the joy stick to run rear remote just by switching flow ? Or is there something I am missing ?
Yes I have a loader now . That's what I was thinking. I could run hydraulic flow from the loader up down part of the joystick to selector valve which would split the flow either to loader cylinders or to the rear hoses. That way using the joystick control to work either loader or what ever I have plugged in to remotes, just not at same time .
