Want to buy a dump trailer, kinda torn here.
/ Want to buy a dump trailer, kinda torn here.
The non-reinforced sides will be ok (somewhat hesitant in saying that) as long as you dont have one side down, one side up and you are off-loading material from the down side. You might push material into up side and bend it. Or if you are loading heavy materials like irregular shaped logs. Once they are bent, thats a bad day. It would be ok for mulch, stone, most construction debris.
Although the Lamar trailer I posted is pricey, its built like a tank. The 14k model is built pretty nice, too.
Youll get what you pay for in most cases.
i called them and they’re still using the dexter axels. As far as the lack of uprights after seeing some in person they seem solid enough imo. They do the 10 gauge sides and 7 gauge floor. End of the day I don’t plan on beating the hell out of whatever I buy.
/ Want to buy a dump trailer, kinda torn here. #182
Man, kinda surprising how many details there really are to discuss about dump trailers here.
I'm not in the same league as what y'all are considering for the OP, but I sure do appreciate having my neighbors 6x10' 10k dump trailer available to me, had it all day saturday. Super easy to maneuver, actually it turns too quick when backing up.
By my math on the scales it only weighs about 2500 lbs empty, so the capacity to size ratio is just right, can fully load it up with 3-yards of whatever and safely haul behind my 2500HD. It dumps quick and strong as long as the battery is well charged.
This was a good bit less than 3 yards of gravel, they under loaded me, oy. (but fair price because of true scale weight).
Then the battery died here on this light mulch load. I got the mulch out by driving back and forth a bit, and then learned that you can't just let gravity bring a power-down dump trailer bed back down if the pump isn't turning. Filled the reservoir and blew the cap off, spraying hydraulic oil right in my face and all over the truck and trailer! ugh.
/ Want to buy a dump trailer, kinda torn here. #183
Fair enough, makes me think a gooseneck might be the better option for the tongue weight aspect.
I have never regretted my 22‘ Diamond C 19LPX gooseneck trailer.
/ Want to buy a dump trailer, kinda torn here. #185
That is pretty wild. Per your link it is obviously a PA intrastate thing. I am not aware of any other state in the nation that has that number as a threshold.
I was happy that I wasn’t mistaken for the last 4 or so years, lol. Like I said with the weight of newer trucks, it may not matter much soon anyway.
I live close to NJ, but turn down work there all the time because the contractor licensing is just silly.
/ Want to buy a dump trailer, kinda torn here. #186
Dang....I have been looking for a year for a trailer like that (only 24' or 26').
Most new ones are a 26 week lead time. Used ones either are junk or don't last
/ Want to buy a dump trailer, kinda torn here. #187
That’s funny. Most everything I saw was 20’, 24’ or 26’. I was about to order 22’ when I found this one at a dealer I am acquainted with and it’s been a good one. Good luck shopping. One will turn up for you somewhere.
/ Want to buy a dump trailer, kinda torn here. #188
My Load Max 24', 14k is very similar and has been a good one, 2016 model w/slide in ramps.
/ Want to buy a dump trailer, kinda torn here. #189
Kaufman builds a lot of 22’ instead of 20’ trailers, too.
/ Want to buy a dump trailer, kinda torn here. #191
Now thats EXACTLY what I want.
specifically slide in ramps.
I like my 14k with folding ramps a lot but I wish it had a dovetail vs a straight deck. The straight deck makes the tipping point worse on my tracked machines than it could be and my mower won’t hardly go on at all.View attachment 696398
/ Want to buy a dump trailer, kinda torn here. #192
/ Want to buy a dump trailer, kinda torn here. #194
IF I do it, I think that’s what I’ll go with, but trailers are crazy high prices now. Would prefer to find something in stock to avoid the wait, too.
/ Want to buy a dump trailer, kinda torn here. #195
Cannot view attachment?
But my thought was not even using the ramps.
A 24' equipment hauler with a dove.....the MX and my mini are 99% of my trailering. Neither need ramps. So if they are stand up ramps....they have to be used. But if they are stow-away ramps.....they aren't in the way and I can load /unload with one less step. Yet still have them for the 1% of the time I haul something different
/ Want to buy a dump trailer, kinda torn here. #197
If you do what? Inquiring minds wanna know....
Ok, lol
Replace my existing equipment trailer with new one. Trailers are very tough right now if ordering. Was talking to Kaufman on Monday and they had 3 price increases since January. Tube steel prices rocketing upward.
/ Want to buy a dump trailer, kinda torn here. #198
I think I'm going to sell my 7x14 12k dump to my buddy and have Appalachian build me a 7x14 15K dump derated to 9,995 lbs. I want the larger cylinders since Appalachian doesn't do scissor or front ram lifts.
Every dump trailer gets overloaded nearly daily. So may as well try to get in front of that by having the cylinders for a heavy lifting as you can get. I'm going to call them today and discuss and see if there there is a larger cylinder option that I can talk them into shoving under the dump. And 17.5" wheels.... and 7G floor.... And dual batteries.... and tarp.... and spare.... and aluminum ramps..... and rear drop leg loading supports....
/ Want to buy a dump trailer, kinda torn here. #199
I like Appalachian, but they are limited on options. I can respect that because I think they are trying to build simple, budget minded trailers. They are still selling "removable sides". Must be fun trying to pull sheets of steel vertically upward with a load of stone against 'em lol
I don't know what gauge their floors or sides are, they don't specify, at least in the sales literature I saw.
At $15,000 for their 25K dump trailer, that's a lot of load capacity for the price. If it had a 7ga floor and folding sides, I would be interested. Tandem Dual Gooseneck Dump Trailers by Appalachian Trailers
Can you let us know what you find out?
/ Want to buy a dump trailer, kinda torn here. #200
Just talked to the fellow and already got the quote. Missing on the quote is the de-rate the 15,000 gross build to 9,995 and also missing is the rear drop legs for loading equipment. There is also a 3% cash discount, so assume around $300 off for cash.
View attachment 696438View attachment 696439
2014 International WorkStar 7400 Service Truck, VIN # 1HTWGAAR1EH765285 (A61165)
2014 International...
(2) NOS-8 LUG- 7000Ib 74SC-93 HUB FACE DROP AXLES (A60432)
(2) NOS-8 LUG-...
(1) HE WASHING MACHINE (A60432)
(1) HE WASHING...
2013 Ford F-450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A59230)
2013 Ford F-450...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2014 American Signal Solar Towable Message Board (A59228)
2014 American...
