Need Your Thoughts On A New Welder
/ Need Your Thoughts On A New Welder #1
Avenger
North Idaho
LS XR4145C
For the last several years, I've been doing all my welding at my neighbors shop. Since his son has come home from the military, the shop has been taken over by him and his vehicle projects. Currently, there is an engine block on the welding table. I have several welding projects to get to, so I need to stop relying on my neighbor and get my own welder.
I dont have the power in my garage for a decent welder. But I do have a 7500W Generator I plan on using. Only problem I see so far is the 30amp/240 outlet.
I went to my local welding supply store and spoke with the guy behind the counter, he told me that I should get the Miller 210 stick welder. I like stick, but I also like Mig (GMAW). The multi process welders he offered were well outside my price range. I figured I could simply get the stick welder to get me going, and get another wire feed later. So I ordered the Miller. That was two weeks ago. Yesterday I called and asked if it has come in yet. He said that Miller is having some issues with their supply, and my order is backordered for an unknown amount of time.
This is no good. I need a welder.
The guy behind the counter said he would look into other, more available, options for me and get back to me. I also started googling.
My Googling lead me to the Harbor Freight Vulcan Omnipro 220 multi process welder. They currently dont have them in stock, but apparently will sometime soon. I poured a bunch of research (reading reviews, watching videos, etc) and found it to be a decent welder for the price, which is at the very top of my budget.
Then the guy behind the counter called me back with news that he can get me the ESAB Rouge ES (though not sure which one) for about $700. But its stick only.
Here is my dilemma: I would prefer a multi-process welder, but will my generator even run that welder? Is it a good welder, coming from Harbor Freight? The ESAB seems good, in name, but is also very small and not multi-process. Will my generator run that welder?? 6011 and 7018 1/8th inch.
All these welders specify output power with amps. And only volts for input. But putting a welder on a 30amp circuit seems lightweight to me. Does it to you? Would it be worth attempting to run a 50amp/240v circuit from the other side of my house, into my garage though finished walls (about 90ft run)? Would that even be enough??
What would you do? What welder would you get and how would you power it?
EDIT: Do you recommend another name for a multi-process welder at about the $1000 mark?
/ Need Your Thoughts On A New Welder #2
I think this is a hard question to answer without knowing what sort of welding you need to do on what sort of material?
Great question, and I apologize for not including it. I weld mostly mild steel that is relatively thick. Things like brackets and repairs on implements. My current project is making new lower links with the European style hooks. Its 3/4in thick.
I will bevel the two and fill with weld.
I also make things, typically smaller, like tables and shelving. I use tig or mig for these lighter jobs. I'm a home brewer, so tig welding stainless is also in my wheel house. However, I have not done any tig welding in years, since I built my brewery.
Mostly my welding is for my tractor and implements.
/ Need Your Thoughts On A New Welder #5
Although you don't have a welder, it seems that you know what you want and need. Is running enough power to your garage totally out of the question?
Buyers remorse is especially bitter when it comes to tools and worse when it comes to fairly expensive tools that either won't do what you need well, or that don't last or are not serviceable.
I can't assess your generator, but I can recognize that your beyond just "dabbling" with welding. It may take some time, but work on your electric situation, then go save up for a good blue, red or yellow welder that you can confidently use for many years to come. 👍
/ Need Your Thoughts On A New Welder #7
Everlast Powermig 230i is $1049 @ Everlastgenerators.com. i have the 251SI DC MIG/TIG, and 255EXT AC/DC TIG, and 60S Plasma and am very pleased with all. I picked up the water cooler for the 255EXT at their last sale. Time to build a TIG cart.
/ Need Your Thoughts On A New Welder #8
When I bought a welder for occasional use I chose a Miller Thunderbolt stick only machine. The primary reason I did not buy a MIG was I felt my unseated, uninsulated building in upstate NY would have been a poor environment for storage of MIG wire and the sheath and gun. Rusty welding wire is no fun.
/ Need Your Thoughts On A New Welder #9
Imo Hobart is the way to go, I have a 210 mvp for mig, 190 with spool gun for aluminum, 235 lx ac/dc for stick and a lincoln 140c for flux core light duty out door welding. For heavier steel I'd try and run it off a 50amp breaker as I have tripped 30 and even 40 amp breakers when it's cranked. My only complaint on Hobart is the tap settings for amperage. Side note I'm not very familiar with hf welders except the cheap ones. Funny story I was welding for a buddy at his place with his hf flux core welder touched some rather hot steel burnt right through the lead, funny to see they use cocktail straws for the liner. For comparison at my old job I've ran over the leads of a lincoln mig welder with a fork truck did nothing and still functioned flawless.
/ Need Your Thoughts On A New Welder #10
i'd look into wiring a 220 dedicated circuit to your garage if there's room on your existing main.
years ago, i converted my garage into a working shop. i almost went with 110v machines using existing garage circuits....but decided to run 220 circuits & sure am glad i did. personally wouldn't want to run a gen every time i needed to weld.
if you consider, post here the distance from the main to the receptacle to get the correct gauge wire. important to get that right for safety & working requirements of welder. it pays to do the homework 1st :) good luck
/ Need Your Thoughts On A New Welder #11
Welding from a genset is a pain, especially tedious fab work.
/ Need Your Thoughts On A New Welder #12
Avenger,
I’ve only welded off my generator (Predator 8500 w/40 amp 220v outlet)- it worked but I’d be very concerned if I was using it on something like the omni pro with all of the computerization. Maybe an inverter generator puts out a clean enough output for all those ics but I’m pretty sure my Predator doesn’t-wouldn’t want to find out the hard way . Bottom line-is there any way you can get 220v? Dryer outlet with very heavy extension cord? Something else? I’d do the run you propose otherwise-just gage appropriately for the run length.
Take a hard look at the Viper welders-I have the Viper MiG 180 (also does stick) and have been very happy with it-at quite a bit lower cost than the same capability Lincoln or Hobart. Yes, it is Chinese but the quality has been good enough for me so far.
I have two 50 amp 220v dedicated welding outlets in my shop- one at front, one in the middle. 50 amp, 220v should cover any welder I’ll ever own.
You’re welcome to come try it for youself if you want-it’s only 15-20 miles. PM me if you want.
/ Need Your Thoughts On A New Welder #13
"220" requires a real long cord.
/ Need Your Thoughts On A New Welder #14
I am not sure about them all but some of the new inverters designed to run from gensets. Units like the Maxstars were touted as able to run from crummy power. But,,, having said that a shop without adequate power is difficult to work from and running service to it would be on top of my short list before I even consider striking an arc.
The upside is many modern welders now run from 30A which makes it slightly easier but I still run number 2 alum to those buildings usually fed by 60. Can run a couple hundred ft and still be plenty usable. The benchmark is still 50A circuit for welder and a little to spare for air comp. The number 2 is a 90A wire and could be changed up to that although I have never had to do it.
/ Need Your Thoughts On A New Welder #15
Pound for pound/dollar for dollar I doubt that you can beat the Hobart MIG welders!
I have the Hobart Handler 190 MIG (30A, 240V)
It is a transformer style welder (heavy).
I bought it new in the box, delivered to my door, 2 years ago on a deal complete with aluminum gun.
Sold the aluminum gun on E-Bay, so am now in my Hobart Handler 190 for $444.
Minimal cost, for a great MIG machine!
/ Need Your Thoughts On A New Welder #16
agree Hobart welders are quality. have a Stickmate arc ac/dc & couldn't be more pleased
to OP: what's the distance from your house main to possible garage 220 recep? (assuming there's room in your main box)
Thank you all for the responses! I really do appreciate it.
Sounds like I need to run a dedicated circuit. The panel is on the exact opposite side of the house from the garage, and the "shop" is on the far side of the garage in the last bay. Long run. I measured it at about 75ft. I believe, for a 50amp circuit, I'll need 6/3 wire. I found this on Amazon: Southwire #63950002 125' 6/3 W/G NMB Cable - Electrical Wires - Amazon.com
Its expensive, but I believe it is the right wire for the job. If not, please correct me. I'm no electrician, but this project sounds simple enough.
Routing the wire though the house is simple. The ceiling in the basement, much of it, is unfinished. So running it up there is easy. And down to the panel is easy. Going though the finished wall into the garage, I'm guessing I'll need to demo some drywall. But, once I'm though that wall, I the rest of the garage is still unfinished. Should be an easy run to where the outlet is.
Unfortunately, there is not much room in my panel. But I can combine some breakers and use one of these: Eaton BRD230250 Breaker, 30/50A, 2P, 120/240V, 10 kAIC, Quad, BR Series: Amazon.com: Industrial & Scientific I already have one in my panel. Then all I need is the outlet, cover, and box. Seems simple enough.
As for the welder. I reached out to Mark @ Everlast, who I saw posting in other threads here. Having seen Everlast welders on Amazon, I decided to take a closer look. They are actually running a sale right now too! I poked around, reading stats and reviews, watching videos, etc. I settled on the Everlast PowerMTS 251Si with TIG Package. PowerMTS 251Si with TIG Package | Everlast Generators It's a bit over my budget, but crypto has been good to me lately, so I offset the cost with my gains in that realm.
I got an email from Everlast shortly after ordering that welder that they are backordered a few weeks. Then I got a response from Mark @ Everlast. He told me that I certainly will not want to run that welder off my generator, that I'll need a dedicated circuit. Which, of course, means more money, and time. But I think it will be worth it. He then informed me that if I want to TIG weld aluminum, I'll want the Lightning MTS 225 With TIG Package, on sale now, for only $2k! But it TIG welds in AC and DC. I dont think I'll need that. I dont really think I'll be welding Aluminum, and If I do, for some reason, I can get the spool gun.
As for pulling a permit, and doing the work myself, etc. I will be doing that. I also have a friend who is a retired electrician, who I'm sure will be able to help me. Though, I have yet to ask.
I've looked up the codes, and everything seems easy enough.
Thank you again for all the responses. I really do appreciate it! (y)
/ Need Your Thoughts On A New Welder #18
TIG of aluminum requires A/C (hence my 255EXT). But you can MIG weld aluminum with DC. Requires 100% Argon gas, and usually a spool gun, though i made a 10' MIG gun setup for aluminum wire. YouTube can help. The 251Si can MIG aluminum with the right wire and gun set up. The 15' gun i use for steel wire was $75. Converting the included 10' MIG gun was about $30 for the new liner tube and feed rollers.
30A RV extension cords are pretty cheap.
/ Need Your Thoughts On A New Welder #19
I bought the MTS 251si some time ago and love it. Came with 300a MIG & jumbo TIG torch and I bought smaller ones for lower power welding (<150a). My 220v outlets are wired for 60a w/50a breakers and 10-50 to 6-50 adapter for 'welder' plugs.
All my welders (Miller, Airco, NGC/Miller, HFT, & imported plasma) have one plug style or the other. I use a 20' 6 Ga 10-50 extension cord that handles more like a stiff garden hose but stores easily and allows me to plug-n-play outside of the barn or garage.
/ Need Your Thoughts On A New Welder #20
Avenger: seems to me you're doing your homework here. if your existing house main can accommodate, think your decision to wire an appropriate 220 garage receptacle is a good one. for your run, you should find ample gauge info for 50A circuit run of that distance, looks like you already have
just a thought while you're considering the garage wiring.... i was in a similar situation yrs back wanting to add 220v woodworking, ect, machines to my limited space garage. since i was upgrading my house main circuit box @ the time, i decided to run an appropriate gauge cable to the garage for a 100 amp box there. from that garage 100A box, i ran dedicated 220 & 110 circuits for my machines (mounted on mobile bases so i could still park vehicle, etc)
since you're investing in a fairly heavy gauge cable for your run to the welder, with not a lot more, you could at least anchor a 100A box in your garage, then run your welder circuit.
just a long worded way of suggesting future options for you in a limited space but with ambitious shop designs. best regards
