Need Your Thoughts On A New Welder
   / Need Your Thoughts On A New Welder
Avenger: seems to me you're doing your homework here. if your existing house main can accommodate, think your decision to wire an appropriate 220 garage receptacle is a good one. for your run, you should find ample gauge info for 50A circuit run of that distance, looks like you already have
just a thought while you're considering the garage wiring.... i was in a similar situation yrs back wanting to add 220v woodworking, ect, machines to my limited space garage. since i was upgrading my house main circuit box @ the time, i decided to run an appropriate gauge cable to the garage for a 100 amp box there. from that garage 100A box, i ran dedicated 220 & 110 circuits for my machines (mounted on mobile bases so i could still park vehicle, etc)
since you're investing in a fairly heavy gauge cable for your run to the welder, with not a lot more, you could at least anchor a 100A box in your garage, then run your welder circuit.
just a long worded way of suggesting future options for you in a limited space but with ambitious shop designs. best regards
I started thinking the same thing. But the money is pretty tight as it is. That might be something I consider in the future. I know its better to "buy once, cry once" but I gotta get up and working. Besides, I only have 200amp service to the house. Maybe a 100amp service to the garage from my main panel will be better suited when I upgrade the service from the meter, to something like 400amp. But now we are talking some serious money. That will need to be hired out.
Thank you for the advice though!
   / Need Your Thoughts On A New Welder #22
If the run is easy use a 2 2 2 4 alum cable and a 6 or 8 space mail lug, 6 is super cheap. Start with a 60A in the main. Its a 90 wire under this circumstances but the 60 is cheap and will work dandy. A circuit of 75 to 100 ft and the loads wont know they not right at the panel.
As to the specifics of a single welding circuit a 10/2 copper cable for almost all machnes except for heavy 250 feeders with hi duty cycles and up to 50A breaker. This will run Stickmate class machines and anything smaller that comes with a 50 plug. Nice thing about a panel is you can add an air comp circuit, a weld circuit and have a couple 120V for tooling and none of these type tools applied to any existing house circuits.
Most of the work in a common garage now really done from 15 and 20 circuits, even modern welders 20A@240, even 5 hp comp under 25 run A and the all those loads running most of the way on number 2 vs branches of 12 or 14.
   / Need Your Thoughts On A New Welder #23
Something to consider with this is because you have a 90A wire dont mean you ever pull that,,, same for common 120V, having a 20A breaker is different than a 20A load. Only place breaker really provides thermal protection is for multiple outlets on a general circuit and panel to panel feeders.
   / Need Your Thoughts On A New Welder #24
The biggest hesitation I would have about buying a HF welder is not the quality, but the service repair if needed. I would be more inclined to buy a Chinese welder from a welding shop that would be able to service the unit if it broke. Lincoln, Hobart, Miller all have big service networks. Just one more thing to consider.
   / Need Your Thoughts On A New Welder #25
Installing a 100A sub panel does not necessarily require hiring out. And definitely doesn't require a 400A service. The sub panel is just a way to distribute power. I have 2ea 100A sub panels in my home and a 100A sub panel in the barn. The house came with the 2ea sub panels that were part of a remodel. I installed the 100A sub panel in my barn, and daisy chained subsequent 60A sub panels to a shed and shop. Main thing to remember is that sub panels must have separate neutral and ground conductors (2-2-2-4 AL), and the ground bonding strap must be removed from the sub panel. A separate ground rod to the ground bussbar in the sub panel is preferred, but not necessarily required. Your retired electrician friend can help to know if your local code requires the additional ground rod.
   / Need Your Thoughts On A New Welder #26
400 Amp service to your house, to feed a 100 Amp service panel in another building, is total overkill!
You can very reasonably run your 100 Amp service to the garage from your existing 200 Amp panel.
You could use 3 -#4 copper in PVC.
   / Need Your Thoughts On A New Welder #27
In order to overload a 100 amp panel you would need the oven on, the range top and the hot water and the clothes drier all pulling at same time plus you welder cranked up using max amps.
Face it, most welding will be with 1/8 rods, intermittent at that, and you'll rarely be welding while there is a roast in the oven.
Also I've noted that most smaller welders (even rated for 200 amps) generally only have about #10 or 12 wire going to the plug.
The main thing is to use proper circuit protection for the gauge wire installed.
I'll bet that for most DIY welding projects you will rarely draw any serious amperage and for sure your 100 amp main can handle it above the normal household draw.
   / Need Your Thoughts On A New Welder #28
Per OM for Power MTS 251si:
3.Power Input Cable and NEMA 6-50P Plug. This is the standard plug for welders operating on 240V in the US and Canada.
4. Fuse. 30A, slow blow. (internal) This controls the main power to the panel and fans... It’s a standard automotive type 30A slow blow type available at many auto parts and electronic supply stores.
If the wire feeder quits feeding, and all other signs are correct, it may be another fuse issue. The unit has an internal fuse on the board which is a 5A fuse."
Seems we don't need as much supply current with IGBT welders as with our buzz boxes, of which mine want up to 40a and I give 'em all a min of 50 with 10-50 gear (all the way adapter as needed for MIG/plasma). btw, lotta book to read, but all one could ask for. (y)
   / Need Your Thoughts On A New Welder #29
Unless you have an electric furnace (not just a heat pump) or other very large loads even 200A service is way more than you will ever need. 200A@240V is 48KW. The maximum my house has ever drawn is about 20KW and that was for no more than about 2 min. That is with the well pump, septic pump, 2 electric water heaters and some other stuff running. Most of the time the load is under 5-7KW.
So, you do not need to upgrade your service. I have a 100A breaker in my main panel. It goes to a generator transfer switch/sub-panel. From there it goes to the panel that feeds the rest of the house and to a panel at the barnyard (50A). The panel at the barnyard goes to two additional panels (40A and 50A) and several circuits (15A or 30A). This is all fine, because there is never enough load to exceed any of the breakers. Many of the breakers would need to be at full load for any breaker to be overloaded. If that were to ever happen, that breaker would trip to protect the wiring/circuit.
Your welder is a significant load, but 30A is all it is likely to draw and probably not for too long at a time, unless you are into production welding. That is similar to a water heater or heat pump. Your service and main panel can handle it, no problem.
   / Need Your Thoughts On A New Welder #30
Exactly correct!
Nissan Forklift (A55973)
Nissan Forklift...
2015 Ford Escape AWD SUV (A59231)
2015 Ford Escape...
2020 CATERPILLAR 336 EXCAVATOR (A60429)
2020 CATERPILLAR...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
NEW Thiessen Track Closer Disk (A56438)
NEW Thiessen Track...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
