Simple Framing Question
   / Simple Framing Question #1
Diggin It
Super Star Member
I'm thinking, I'm thinking!
LS MT125 TLBM
I'm planning a shed roof/awning, whatever you want to call it that will attach to the existing house roof and garage wall. I need a wider than 8' span between the posts for a variety of reasons. Due to prices of graded, stamped lumber, I'll be using rough cut stuff from the mill guy down the road, either red or white oak. There are no permits or inspections here. Top will be metal roof on purlins, no decking. Rafters will be about 8' long on 24" centers.
Span between posts will likely be closer to 12' which may be too wide for a rough cut 2x6 or 2x8. If I add diagonals as shown to reduce the span to around 10' or less, is it more likely to stay up, or fall down?
   / Simple Framing Question #2
For sure diagonals will help.
A lot depends on anticipated loads.
Are U down south? or in northern Maine?
No matter, if 2 X 10's were optional I'd opt for them and feel quite safe, but I'd shy away from 6's.
   / Simple Framing Question #3
The way to get more strength out of less lumber is to use a truss, which is the direction you're heading. What you want is called a box truss, see if you can find plans on the Internet, state extension offices used to put plans like that out.
My back of the envelope is you need a doubled 2x10 for that span if it's just straight lumber.
   / Simple Framing Question #4
Depends on where you are located (snow loads) for one.
You are better off with a 2x8.
Does the roof have pitch, or is it flat, like shown in sketch
Still early planning so pitch isn't really defined yet, probably 3/12 or so. We get snow and have had 10-12" a couple of times, but it's almost always gone in a couple of days. Most years, no snow at all, or 2-3" at most in any one snowfall which melts before the next one. In 25 years, I don't think we've had a snowfall over six inches more than a half dozen times.
There are some weird angles involved that I can't draw in with MS Paint, but really it's just a simple shed roof/awning to keep rain away from the doors, windows and foundation.
I'm just trying to figure out if I can do it at all right now or if I have to wait for sanity in the lumber stores .... which might be a while.
   / Simple Framing Question #6
2x6’s would work, but remember it only takes one heavy wet snow.
2x8’s are a better choice. Whats he want per L.F. for 2x8 compared to 6’s?
   / Simple Framing Question #7
Adding the angle braces does not decrease the span between load bearing points...use a bigger timber or a flitch plate etc...
   / Simple Framing Question #8
Can you consider a 2x8 trujoist? The wooden equivalent of an I-beam. Dont know if the price of enginered lumber has gone up like the dimensional lumber. You can then box it in with rough sawn if you like. Apply blocking at the posts with gorilla glue and screws. Should also apply diagonal strapping under purlins to midpoint of span to prevent outward bow and pull out at wall.
Another option would be to use a steel barjoist at the posts, and 2x8x12 purlins on 24" centers for the 26ga roof deck. no rafters. The comnercial built horse barn on our property was built this way. Posts on 12' centers. This way the end band does not carry roof load between posts. 8' bar joist trusses are not very expensive.
If using redoak, best to build while still green, or you may be predrilling screw holes. I used 1x6 rough sawn red oak to floor a tack room and let it dry first to prevent shrink gaps. Could not drive a single nail once dried. Wound up drilling every plank.
Two 1 x 8 oak side by side and staggered to emulate engineered beam? Attached to each other with timber-lok type screws.
Two 2 x 8s in Oak would be too heavy to lift into place. Might be able to do 3 1 x 8s though with a lifting sling.
   / Simple Framing Question #10
Put one 2x8" on the outside of your upright post and one on the inside and a another on the top(may need a 2x10").Very strong and do one piece at a time.
   / Simple Framing Question #11
Use liberal amounts construction glue to laminate them along with heavy gauge screws.
   / Simple Framing Question #12
3 layer 1x8 or 1x10 laminate beam may be cheapest way. Can also use 1x6 & 1×4 to get 10" width. Stagger all joints. Lots of PU glue. Tack together with #9 # 1 3/4" on first side, flip beam, #10 x 2 3/4" all the way through. This gives me an idea to replace the rafter beams on my shed.
I suggested steel joists because we have a terrible carpenter bee issue in our 20x50 shed. Had to wrap girts with flashing and replace wood king trusses with site built cfs steel trusses. Shed originally built in '98 or so (not sure as we purchased property from an estate).
Pics please when done.
   / Simple Framing Question #13
Why don't knee braces reduce the span? I always thought they did as well as providing lateral support. Deflection in the post is possible if it is undersized or if there is not 2 opposing braces?
   / Simple Framing Question #14
Do a little research on "basic structural loads and resistances" etc...
The "span" is between "bearing points"...Those angle brackets do absolutely nothing to reduce the span...
FWIW...for typical 45* angle braces to be truly effective they need to be through bolted to both the post and the beam...it does not take much lateral force to rip out tails or screws that applied from the face of the cuts...
   / Simple Framing Question #16
Those angle brackets do absolutely nothing to reduce the span but are important for side loads, like wind.
That depends on the spacing of the rafters etc and what is being applied on top...i.e., solid sheathing on say 2'OC rafters that are secured properly to the beam will eliminate the need for lateral bracing on the posts...same goes for lattice boards and metal roofing...for the most part they (post braces) are there for the looks...once the roof is on they do very little to add lateral support...and like I said in a previous post...through bolting is paramount for them to be effective...!
   / Simple Framing Question #17
You speak like an engineer, are you? People who use screws have a few loose ones unless they are listed for lateral loading. Screw one half way in and one sideways hit with a hammer and most will snap off. Lag bolting or thru bolting knee braces is the norm. In the real common sense world I feel that properly designed and installed knee bracing can support gravity loading and create an additional bearing point. Any structural guys here?
   / Simple Framing Question #18
If you sandwich a full length piece of galvanized sheet metal, 24 or 26 gauge, inside of your 1"x8"s, and fasten your "sandwich", you will add a lot more shear strength.
Years ago this was a common practice when adding an additional roof joist to an existing one for an add on a/c unit on the roof, 4/12 pitch, to support the additional weight of the unit and help out where the roof was cutout for duct work.
We use to also turn a 90 degree flange of about 1.5" for the bottom side of the metal.
Good luck, KC
   / Simple Framing Question #19
Like in a truss, the diagonal members are more for tension. The racking loads are tension on one side, compression on the other. If angle of support is 45 or less from vertical, properly anchored to post, sized for compression, and meet near center of span, then it can be considered to reduce span. Think post and beam construction. But such a structure will severely limit access. Better to just use a proper header beam sized for the span. The are other ways to support a span, such as a tension member on the underside with a center drop leg, or a fabricated pre-arched beam. But these are probably over designed for the OP's needs.
You can consider galvanized CFS for the span beam. I have built 6x12, 3x10, and 6x10 box beams from CFS studs and track. As well as the Howe truss pictured previously.
I am an engineer.....
   / Simple Framing Question #20
I'm not a structural engineer...I finished with a double major (civil engineering and architecture)...held a class A GC lic. in FL for 45 years...
IMO this is all moot...if the OP uses mostly clear oak members followings following basic soft wood framing practices...(for sizing members)...the oak beam is not going to deflect without an extreme live load...
Gravely Pro Turn 460 60in. Zero Turn Commercial Mower (A59228)
Gravely Pro Turn...
2019 CATERPILLAR 972M WHEEL LOADER (A60429)
2019 CATERPILLAR...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
2001 John Deere M665 60in Zero Turn Commercial Mower (A59228)
2001 John Deere...
2014 Nissan Rgue SUV (A59231)
2014 Nissan Rgue...
2018 Peterbilt 348 T/A Rollback Truck (A59230)
2018 Peterbilt 348...
