Coming soon list
/ Coming soon list #121
Seems to be working now, maybe a cache issue on my side.
The MyHome works great.
/ Coming soon list #122
I'm struggling with controling email notification on Watched Threads. (Firefox and Ubuntu, uptodate).
I've found a control to UnEmail every thread, but can't seem to selectively control turning on Email notification like ur TBN had.
Is this fix on the list already, or is 3930D just blind to the new controls.....
Rgds, D.
/ Coming soon list #123
^^^ One way ... (there may be others).
Go into the thread itself. Upper right corner, click the 'Watch" icon. A dialog box appears and you can select to watch it with or without email notifications.
/ Coming soon list #124
A minor issue.
The PM button is hidden behind a red square dot that shows the number of PMs stored.
(OK, mea culpa, I should have erased my old PM's)
On old system I'd get a notification to my google inbox when a new TBN PM was posted.
Will this still be a feature?
/ Coming soon list #125
A minor issue.
I believe that there's a setting in your home page.
/ Coming soon list
A minor issue.
The red dot goes away. You can mark PMs read and the dot goes away.
Click on "selected" and a bar appears at the bottom which will let you select all and then mark all as read.
/ Coming soon list #127
Thanks DI.
On my already subscribed threads I can UnWatch them, then Watch, to get the dialog box you describe. Once selected, then "Email" appears beside that thread in my Watch list. I'll know soon enough, but I'm now wondering about the Check Box that is sitting beside "Email" - do I need to now Check that too, or is that Box related to something else ?
Rgds, D.
/ Coming soon list #128
I discovered a new feature! A photo in a post can be scaled down. While composing a draft, click in the photo then drag a corner to make it smaller.
After its posted, click in the photo to see it full size.
But I tried putting a second photo in that post and scaled that second one down to about 20%. This made the post fail to load, something about 'protocol violation' in place of the post. Strange.
Does this load correctly for others, after I took out the second photo?
Edit. Bah. More strangeness. The link doesn't show my post, it shows the first post in the thread. Click within this box to jump down to post #10, what I intended to show.
/ Coming soon list #129
Are the pictures broken for everyone else or just me? I haven’t been able to view any images since the change.
/ Coming soon list #133
Would it be possible to enable editing on all the posts we've made, even the old ones? I've got several that need updating, and I don't seem to have permission to do so.
/ Coming soon list
Since so many geezers with weak eyes hang our here, could the default font be a bit larger?
On which device?
I already made it bigger in desktop by 1pt over the old forum.
/ Coming soon list
Will think about both suggestions.
/ Coming soon list #139
x2 on the ability to edit. I have never understood the reasoning behind that prohibition. I am a member of several forums that allow indefinite editing and it IS useful sometimes as information can change or become irrelevant.
I have also noticed this format will take away the spell check underline as you are typing. Same thing happens at the new GTT forum and they have never fixed it. You can right click and uncheck the spell check then right click and recheck it and it will come back but that takes time and is an annoyance for those of us that are mostly thumbs.
/ Coming soon list #140
I disagree with wanting to edit old posts. If you need to update information in an old post, just quote yourself and add the disclaimer in your reply that you are updating the information and give a reason why.
2019 Nissan Kicks Hatchback (A66738)
2019 Nissan Kicks...
2025 Pallet of Miscellaneous Duplex Polyester Webbing Slings (A66734)
2025 Pallet of...
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
1995 Khronert 307 SS Single Comp 6,500 Gallon Insulated T/A Chemical Tanker Trailer (A68183)
1995 Khronert 307...
2009 HEIL CRUDE PUP TRAILER (A67714)
2009 HEIL CRUDE...
2009 IMPERIOAL DT7126T 12FT CUSTOM DUMP TRAILER (A66091)
2009 IMPERIOAL...
