4570Man
Super Star Member
- Joined
- Apr 7, 2015
- Messages
- 19,068
- Location
- Crossville, TN
- Tractor
- Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
You did not mention if the garage was heated - if it is obviously less time needed for warm up, I start mine, lift the blower 900lbs and move it outside at idle - then raise to 1000RPM for a couple of minutes then to 1500 or 1600 for four or five minutes - my garage is heated so it's halfway there anyway, if it is snowing or raining I take my exhaust hose hook to exhaust open the door a little stick it outside and let it run inside - (haven't got around to the cutting the exhaust port in the door yet) - but it works just as well laying on the ground, I set it so it does not blow back in - exhaust hose is not that expensive they have worked well in commercial garages for years and will do so for you as well.....
I’d assume not. Otherwise skip the warmup and get to work.
