warming up in the garage and fumes question
   / warming up in the garage and fumes question #21
You did not mention if the garage was heated - if it is obviously less time needed for warm up, I start mine, lift the blower 900lbs and move it outside at idle - then raise to 1000RPM for a couple of minutes then to 1500 or 1600 for four or five minutes - my garage is heated so it's halfway there anyway, if it is snowing or raining I take my exhaust hose hook to exhaust open the door a little stick it outside and let it run inside - (haven't got around to the cutting the exhaust port in the door yet) - but it works just as well laying on the ground, I set it so it does not blow back in - exhaust hose is not that expensive they have worked well in commercial garages for years and will do so for you as well.....
I’d assume not. Otherwise skip the warmup and get to work.
   / warming up in the garage and fumes question #22
I do not let mine sit to warm, waste of fuel. I start the engine and let it have about a minute to fully circulate the oil then start moving while slowly raising and lowering the hydraulics with no load at first. Then after another minute or two start doing what I need the tractor for. As has been stated it can idle all day and the hydraulics will not warm up. Working it warms the oil up faster, just go easy for the first few minutes then get after it, if the oil has not circulated to all the moving parts within that amount of time there are other problems to worry about.
I thought that replies automatically were emailed. I didn't realize there were so many replies. I'll have to be sure to check the "email replies" box next time. It seems there are a variety of approaches but nobody is really adamant about warming it up before moving. I didn't even think about the fact that hydraulics aren't warmed up at all but I guess a warm engine can handle the hydraulic pumping better.
I had been lifting the ballast box fast-apparently not a great idea. I guess I kind if thought if I made it happen fast, there wouldn't be a chance for anything bad to happen. I know, doesn't make any sense.
Also, I had no idea about hooking up an exhaust hose. Great idea. I think I'll do that, but also, I feel much much better about just starting it up and slowly moving it outside after gently raising the ballast box and front loader.
I really appreciate all the replies! Thank you very much.
Oh, also, I do have the ballast box sitting on a dolly I made, but I'd still have to lift it as the exit from the garage is bumpy, at least in winter from all the ice on the ground,
The garage isn't heated. It gets some passive heat from ducts going through the garage, so it doesn't get as cold as the outside, but not as warm as the house.
I agree that a shed would be nice. Maybe next year? And if I every buy a house again there will NOT NOT NOT be living space above the garage for so many reasons.
   / warming up in the garage and fumes question #24
Regarding fumes.......This time of year you hear all kinds of warnings about combustion and exhaust inside your house. Occasionally hear about deaths caused by fumes.
I have used kerosene heaters in the house with the windows closed etc etc. So far, so good.
Does kerosene not put out as many or as dangerous fumes as the various heaters we are warned against?
   / warming up in the garage and fumes question #25
You should never operate a kerosene heater in a closed room.
   / warming up in the garage and fumes question #26
   / warming up in the garage and fumes question #27
Buy a bigger tractor and leave it outside. Big enough to even find it after the worst storm.
Just saying. Somebody has to spend your money on TBN.
The exhaust hose is a good suggestion and backing it out for warmup won't do any damage either.
   / warming up in the garage and fumes question #28
ABSOLUTELY TRUE!
Wow. No clue. I figured there must be combustion gasses but people burn them inside around here all day every day. I suppose people die from CO2 all day and every day too!
Everybody n this area is out of kerosene!
Thx, i'm glad i asked!
   / warming up in the garage and fumes question #29
   / warming up in the garage and fumes question #30
O.T. but is CO2 lighter or heavier then air?
Would vents along the floor or near the ceiling better protect from CO2?
2018 Dodge Charger Sedan (A55853)
2018 Dodge Charger...
UNUSED FUTURE 80R RIDE ON POWER TROWEL (A57193)
UNUSED FUTURE 80R...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
UNUSED FUTURE XJ3T-3T HYD THUMB CLAMP (A57193)
UNUSED FUTURE...
UNUSED FUTURE P45 56" HYD BREAKER HAMMER (A57193)
UNUSED FUTURE P45...
Kivel Quick Attach Forks (A56469)
Kivel Quick Attach...
