Spade/Trencher for M59
/ Spade/Trencher for M59 #1
caballero59
Buena Vista, CO
Kubota L39, M59, ZD326, Deere 6415
I'm needing to dig a shallow ditch for electrical and don't want to use the 24" bucket. Does anyone know of a company that makes a ripper/ditcher/spade attachment that replaces the bucket? It appears that Bro-Tek is only building wheel spacers now...
/ Spade/Trencher for M59 #2
How deep and wide? Maybe make something with angle iron to attach to the backhoe bucket...
Just wide enough so the dipper stick clears the trench.
/ Spade/Trencher for M59 #4
Ok that's wider then I was thinking....
/ Spade/Trencher for M59 #5
are you putting in conduit or direct burial wire and what size?
I'll put it in conduit. I see some rippers available but none that I've found for the M59. Great tractor by the way.
/ Spade/Trencher for M59 #7
Be interested in what you come up with.
Need a ripper for both the m59 and b26. Bought the qa ears for b26 for fabrication. Mainly for roots and rocks. BroTek design had a flatbar on the back of the ripper that helped open the ripper trench if I recall correctly. An option I like.
Have laid some direct burial cable with a subsoiler and J-tube. Thinking something like that. Rip the ground first, attach the J-tube and lay cable or pipe. Still on the drawing board.
Have/had 12” buckets on the Ford 4500 and b26. Still a lot of spoil to deal with and clay soils with head size rocks like to pack narrow buckets.
There is company that fabricates rippers for $1200 for backhoes I see advertising in CL. My m59 bucket is pin on. I think the bucket yoke and change to qa ears to get quick attach. The qa on the b26 is the best I have ever seen.
If not going deep maybe something that attaches to your bucket?
/ Spade/Trencher for M59 #8
I never did understand what a ripper tooth could do that a narrow bucket couldn't do better, but there must be some reason they are sought after...
A friend built a ripper for his M59 and was surprised to find out how much $$ he had into it when done. Here's a photo of one of the QA ears he ordered from Kubota for the project.
Nice build! The primary (and weighty) reason to steer away from a narrow bucket is the difficulty of unloading them in sticky soil.
/ Spade/Trencher for M59 #11
/ Spade/Trencher for M59 #12
Those ears do not look at all like the ones on my L48.
I love the ones I have.
Same as mini ex I think.
My M59 buckets are different from my KX-040. BTW practically every different class mini takes a different bucket.
/ Spade/Trencher for M59 #13
/ Spade/Trencher for M59 #14
I bought a ripper/trencher for my L45 from Michigan iron and equipment. I use it for ripping out big stumps and trenching for conduit. Its works great for both. With a bit of practice, its amazing how fast you can trench for conduit.
/ Spade/Trencher for M59 #15
How deep can you bury pipe with a ripper?
/ Spade/Trencher for M59 #16
I would estimate I could bury small conduit about 14" or so pretty efficiently. Much deeper than that and I would spend too much time cleaning the bottom of the ditch out with the back side of the ripper.
What do the good forum folks think about a 12" bucket as a substitute? Do they only unload in perfect soil conditions?
/ Spade/Trencher for M59 #18
Even if only half unloads, it’s better than a shovel.
Digging trenches so much easier than around stumps.
Had so much play with 4500 Ford BH it could really shake the dirt out of the 12” bucket.
Often thought of a bucket clean out stand or tool designed to drag around to clean a bucket from the operator station.
Reverse thumb to expel bucket material instead of clamping.
Seen a few attempts to mount a trencher on a backhoe or excavator. Seen a few worn trenchers come through the scrapyard that could be donor candidates.
Vibratory plow to cut and pack the sides of a trench.
Two large disk blades mounted concave to roll a trench.
Many possibilities to ponder.
The half mile of 13.8kVA line to my house was suppose to be 4’ deep in conduit. Mostly with trencher and mini-ex at the junction boxes.
/ Spade/Trencher for M59 #19
I have a 12” on my mini x. In perfect conditions it unloads but it definitely sticks worse than the 16” on my other machine.
PALLET OF 2 SHOP VACS AND SHOP BROOMS (A67714)
PALLET OF 2 SHOP...
2017 Mack Semi (A64047)
2017 Mack Semi...
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
2014 Jeep Grand Cherokee SUV (A66738)
2014 Jeep Grand...
CAT D6 SU Blade / Arms (A68134)
CAT D6 SU Blade /...
PORTA POTTY (A68842)
